Question about General Heating & Cooling
Cannot get the pilot light to ignite on my Valor Flamenco Unigas II when the ignition knob is pressed down. Have had the ignition battery out, but the voltage seems to be correct. Fire Serial No 005 344 No 488
Is the clicker making the clicking noise? If not, it is most probably the spark generator which houses the battery. The part is still available online for about £40. It did the job for me.
Posted on Dec 20, 2010
How do i reset my manint req's light after an oil change on a 2003 Honda pilot
Reset oil service light Honda Pilot. From years: 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010, 2011, 2012.
How do you reset oil service light Honda Pilot. From years: 2003, 2004, 2005.
  1. Turn off the engine. Press and hold the SELECT/RESET button in the instrument panel and turn the ignition switch to run (one position before starting).
  2. Hold the button for at least 10 seconds, until the indicator resets.
  3. Turn the ignition off and then start the engine to verify the indicator has been reset.
How to reset oil service light Honda Pilot. From years: 2006, 2007, 2008, 2009, 2010, 2011, 2012.
Resetting the Engine Oil Life Display if maintenance service is done by someone other than your dealer, reset the maintenance minder as
follows:
  1. Turn the ignition switch to the ON (II) position.
  2. Press the select/reset knob repeatedly until the engine oil life is displayed.
  3. Press the select/reset knob for about 10 seconds. The engine oil life and the maintenance item code(s) will blink.
  4. Press the select/reset knob for another 5 seconds. The maintenance item code(s) will disappear, and the engine oil life will reset to 100.
All information is taken from the Honda Pilot owners manual.
Mar 09, 2015 | 2003 Honda Pilot
I have a Valor Eminence Gas Fire which does not ignite when i try to put it on. Pilot light seems to be going but no gas. Can anyone help? I habe dusted the interior as per instructions but to no succes....
Be sure that after lighting the Pilot, that you turn the gas control knob to ON. Just lighting the pilot will not turn the burners ON. Once the control knob is turned to ON, you can turn the burners ON.
Hope this helped you and thanks for choosing FixYa.
Sep 16, 2011 | Heating & Cooling
Valor flamenco unigas 2 fire ignites but wont stay on, assume this thermocouple problem how is thermocouple replaced
Valor uses either a Thermocouple or Thermopile, depending on the unit. In some cases, it has both. And, yes, your assumption is probably correct. Some thermocouples are a part of the Pilot Assembly, which means you have to replace entire pilot assembly. If you check you Owners Manual in the Parts Breakdown section, it will indicate if it is or not and whether you need a Thermocouple or Thermopile or both.
If you're not familiar with repairing gas fireplaces, replacing the parts listed above, can be a little challenging. Especially if you don't have the proper tools. But, before you jump on this project, try cleaning the Pilot Orifice first. You can easily do this, using canned compressed air with a straw nozzle (like you clean your computer with) by blowing out the pilot tip. And while you're at it, clean all around the pilot assembly with the canned air. If cleaning the pilot solved your problem, you're back in business. If it didn't you'll have to go the other route.
Hope this helps you solve the problem. Please be kind enough to rate my reply to you. Thanks!
Mar 24, 2011 | Heating & Cooling
Attempting to light valor homeflame fire the pilot jets ignite but when i attempt to put fire on to full flame, jets go out.
Sounds like it could be your thermo-couple.
or the microswitch you will find the number for valor here
Valor Gas Fires
Jan 14, 2011 | Valor Toys
We have a fairly new heater. went to turn on the pilot light and it won't ignite. what do you think is wrong? gas has been turned on before igniting
Sometimes it takes a few seconds for gas to reach the pilot. When you place the thermostat knob/gas control in the pilot position you must then depress it (push it down and hold it down). Wait a few seconds while holding it down, then press the ignitor button with your other hand while continuing to keep the thermostat knob depressed. You may have to hold the knob down and press the ignitor several times. You should see a spark at the pilot if the ignitor is working properly. Continue to hold the knob down for 30 seconds after the pilot lights, then release the knob, it will pop up & you can then rotate it to lo/med/hi and the heater will come on.,
Dec 02, 2010 | Procom (177653) Utility Heater
Re Williams 3003622 Heater Please advise how to ignite pilot light.
You will first need to turn the control knob to pilot. Then depress the control knob button and hold it. Then press the push button piezo igniter several times until pilot lights or open pilot inspection cover and manually light pilot with match/lighter. You may need to hold the control knob for at least a minute. Then release the control knob and if the pilot stays lit then turn the control knob to on. If it does not light then repeat the process again.
Oct 27, 2009 | Williams 3003622 Ceramic Wall Mounted...
Instalation manual for valor flamenco unigas 111 balanced flue wall mount gas fire
hi there, did you mange to find a copy of the instructions for the valor flamenco unigas ii at all?? i need to replace the ignitor so would like to see a copy..
cheers
sharron
Mar 08, 2009 | Heating & Cooling
DOMETIC RM 7651l HAVE POWER AND GAS TO THE FRIDGE BUT WONT START (TWO MONTHS OLD)
Igniting a Dometic gas fridge
    Electronic Ignition
    1. Open gas cylinder or pressure regulating valve
    2. Turn on Electronic ignitor switch
    3. Turn gas control knob to the MAX position, press and hold down
    4. After ignition, hold down knob for a further 15 seconds before releasing. The neon light will stop flashing
    Piezo Ignition
    2. Turn gas control knob to the MAX position, press and hold down
    3. After approximately 10-15 seconds
      press Piezo knob several times until pilot light a lit
  1. Check the Pilot light is alight
  2. The flame can be controlled by aperture ©
    Should no ignition occur, repeat the ignition process after 1 minute
    (This could take longer than 10 seconds if the unit has been out of operation for a prolonged period or after replacing the gas cylinder. (Cause: air in the lines)
  3. Once sufficient refrigeration has been obtained in the cooling tank at the MAX position, the control knob should be turned to the MIN position by low outside temperatures or when the refrigerator is only lightly loaded respectively the ambient temperature is below +18c in order to avoid over freezing the contents.
I hope this helps you...
Regards
Wouter...
Sep 30, 2008 | Refrigerators
Heating & Cooling Logo
446 people viewed this question
Top General Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a General Heating and Cooling Expert? Answer questions, earn points and help others
