Question about Whirlpool GSC9455 Top Load Washer
Washer leaking some after everything is done washing? why ?
  • I don't know if this is the right modle number. but my washer is a whirlpool. It's a utlimate care 2. It's leaking out of the bottom some where. The hose fittings that i can see are not leaking. I can tell the leak is getting a little more each time i wash a load of clothes.
  • mseva Jun 04, 2008
    My washer is leaking from th bottom. I mnoticed it more during the rinse cycle.
  • 246 Answers
The most common source of leaks from the bottom on a regular basis is a bad pump. Add a little water into the unit. Pull it forward and tilt it back about 45 degrees resting the top against the wall. On the botom center towards the front, you should see a white plastic looking thing. This is the pump and usually where the water leaks from. You can get a replacement on from the manufactures web site or from local appliance parts stores.
Posted on Jun 15, 2008
Can't find pump filter on whirlpool duet washer front loader modle wfw94hexwo
Don't know the specifics for your machine but the filter is almost always accessible via a flap at the bottom front or require the removal of the kick plate at the bottom.
Oct 24, 2015 | Whirlpool Washing Machines
My whirlpool cabrio washer won't start but doesn't show an error code
How old is the machine if its and older modle the switch probably just went bad which is an inexpensive and easy fix
Dec 27, 2014 | Whirlpool Washing Machines
Washer wouldn't stop filling and leaks
Hello, here is a great link to check out everything you can think of on your washer repair and trouble shooting. Make sure you really check out the different areas to click on on this site..
Here is the link. I hope this helps you, mike
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
Oct 20, 2011 | Whirlpool LCR5232H Top Load Washer
Whirlpool Washer Model No. LXR-1564039, Serial No. CM-1564039, Type 107, Year 2006. Went using the extra large setting the washer leaks water from the bottom, however went filling for the rinse...
Although its difficult to say the problem may not be caused by the amount of water but the water temperature.
Most often rinse tempertaure is cold only, however the wash might be warm /hot. A great place to start would be when the machine is filling in wash watch the connectons from the taps to the machine for any leaks in the hoses or connections.
Hope it helps.
Nov 23, 2010 | Whirlpool Washing Machines
Leaking whirlpool washer
Probably the pump seal - you need to replace the pump, which is located at the front.
Apr 20, 2010 | Whirlpool LSR5132PQ Top Load Washer
I HAVE A KENMORE WASHER MODLE#110.22642100, AND THE CLIP TO THE TOP THAT MAKES THE WASHER SPIN BROKE OFF. I NEED A NEW ONE .
See the Sears Parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.22642100
Opening the appropriate diagram will show you a list of all component parts, Sears (alternative Whirlpool ) part numbers and the Sears Cost.
Jan 30, 2010 | Kenmore 24032\24036 Top Load Washer
Whirlpool GSC9455 Top Load Washer Logo
176 people viewed this question
Dan Webster
Dan Webster
Sal De
