SOURCE: I have a Briel Espresso
To get the nut opened you will need the exact tool.You can get the exact tool from local part store.But if the nut is too tight to remove then,apply WD-40 spray on the sides of the screw.The screw gets tight due to rust gets collected in its side.The WD-40 spray dilutes the rust on the sides of the nuts/screws and make the procedure simple to release the screw/nut.But spray the liquid on the side of the nut and let it remain there for few minutes then try if same problem then spray some liquid and try after few minutes.In 2 or three tries it will get release by the screw driver.--------------
For help from Briel:---How Do You Get Service?
If repairs become necessary or spare parts are needed, please contact via telephone at (1-800-763-6699) or via email [email protected], or please write to:
BRIEL Service Center--------
41 Woodbine St------
Bergenfield NJ 07621.------------
Email: [email protected] ---------
What if you have questions about your machine? ---------
You can contact our BRIEL offices via telephone at
(770-509-3006) or via email [email protected], or write to:
BRIEL/ The Smith Agency---------
P.O. Box 669307--------
Marietta, GA. 30066-0106----------
Thanks.
keep updated for any more query.you can rate this solution and show your
appreciation.
SOURCE: I have a delonghi magnifica
Here was an answer from wholetottalove.com:
DeLonghi recommends using Durgol, and you should descale/decalcify about once every 3 months depending on your water quality. Some DeLonghi machines even have built-in message systems to notify you when it is time to descale. You can purchase Durgol by following the links below. Durgol Express is ideal for coffee makers, and Durgol Swiss Espresso is recommended for espresso machines.
This site says you can use citrus based descaling solution to the directions on the bottle.
Good luck, and hope this helps.
SOURCE: I need a manual for
If you were to log on to the
manufacturer's web site, I think you will be pleasantly surprised as
usually one is able to download, by model number, Customer
Instruction Manuals, and a list
of Dealers for spare parts, as required. Just Google the manufacturer's name and
follow the links. Make certain you are directed to the manufacturer's
web site as some search engines direct you to other sites and they
charge for the information that is normally free of charge. I
hope this helps.
SOURCE: Our office machine Gaggia Titanium
Well, "Ventilate"simply means that there is an air pocket caught in the system and running waterthrough it can fix the problem. When the ventilate message appears, you willneed to run hot water through your steam/hot water wand as if you were going tofill your cup with hot water. If the message does not go away after doing so,you will have to run hot water through your wand continuously into an emptycontainer (emptying one full water reservoir if not more). Once yourdisplay screen reads "Select Product, ready for use," you will beready to brew delicious coffee again.
SOURCE: I am trying to use
Hello.
It sounds like the pump is not functioning at all, if the unit is under warranty then I would suggest taking it back ti the manufacturer. To replace this unit while under warranty would not be worth the time or cost in parts and labor.
Nothing can be done without having to dis-assemble the unit.
I hope this helps
Regards
GM
In order to keep your Tassimo machine
operational at full order, it is important to descale it every three
months. Descaling products are widely available from stores that sell
coffeemakers and espresso machines. Be sure that the product you buy to
descale your Tassimo machine is intended for this specific use only. Mix
the descaling product directly in the water container, following the
instructions provided on the descaling packaging. Then replace the water
container on the machine. Place a large cup or mug on the cup stand,
insert the cleaning disc, bar code down and close the brew mechanism. As
soon as the AUTO light illuminates, press and release the start/stop
button. This will fill the brew cycle with descaling solution. Empty the
cup and let the machine stand for 15 minutes. Then open the brew
mechanism and close it again, leaving the cleaning disc in place. Repeat
this step two more times for maximum descaling effectiveness.
Discard the remaining descaling agent from the water
container, rinse it well and refill with fresh, cold water. Clean the
machine by flushing water through it in the same manner and emptying the
cup as it fills. Make sure that all the descaling solution has been
completely rinsed away, and then flush two full water containers through
the machine before using it again. Remove the cleaning disc, rinse and
refill the water container and your Tassimo machine is ready to use.
Also, before you descale your Tassimo machine, always unplug it. Also,
never immerse the appliance in water and nor should you use abrasive
cleaning products or scouring materials on any part of your Tassimo
machine. This method works for most espresso machines,
including some of these popular models: the DeLonghi Magnifica
EAM3200S, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5400,
Gaggia 74507BCN Classic, Krups EA8080 Espresseria Automatic, DeLonghi
PrimaDonna ESAM6600, the BC0255 DeLonghi coffee machine and the Krups Nespresso CititZ XN 7006.
I
hope this helps.
