Bluetooth device is not detected by window 7......It was properly working in Windows xp.....Now a massage has been showing to plugin or switch on the blue tooth device..... My laptops model no.HCL ME B38 notbook..
    Master:
    Sergeant:
  • 381 Answers
Try to locate the bluetooth module manufacturer and then look on their website see if they offer win 7 drivers / support
Posted on Oct 10, 2010
Bluetooth not detecting
Bluetooth radio is not "Enabled" in Device Manager. Turn it on.
Make sure is is detectable and Paired with the other device.
Jul 04, 2015 | Fujitsu LifeBook LH531 14 inch Notebook...
CAN'T FIND WIN7 DRIVER FOR BLUETOOTH HBS-200 HEADSET
Unfortunately, Windows 7 removed native support for bluetooth headsets, for absolutely no reason.
The drivers are actually not needed for the Headset specifically, but rather for the A2DP and AVRCP profiles and audio sink. The downside is that Microsoft's Bluetooth stack does not support either of these.
So you need a Better Bluetooth Stack, so it understands all of the virtual Bluetooth devices.
These directions work for almost any headset that has issues when connected to Windows. Sadly, there is no really good well-defined set of drivers for Windows Bluetooth, so it will frequently take some finagling.
1: Find the correct and absolutely most-up-to-date drivers for your Bluetooth hardware on your computer. In -MOST- cases, the chipset is Broadcom, however manufacturers such as Dell and others tend to put some odd wrappers around the chip so their drivers are required. If not, the direct-from-Broadcom drivers will work.
2: IF the Bluetooth hardware is already detected by Windows, delete it from device manager. Reboot the computer if this was done.
3: On reboot, Windows may detect it and reinstall it fresh. This is fine if it does. Allow it to install and reboot if it requests.
Once the Windows stack is installed properly, you can install the updated stack. With Dell drivers and other OEM computer manufacturer drivers, Windows may not detect it to begin with, however having Windows drivers first is not necessary with these drivers.
4: Install the proper driver. With the Broadcom driver, this will only work if Windows has already installed. With OEM drivers, this is often not necessary. Reboot if necessary.
With the happy stack installed, and the headset paired, you will find that instead of just Handsfree Telephony and Headset services, you will also have Remote Control and Audio Sink services.
Headset/Handsfree: Mono 38kbps audio out and also a microphone input. This is what is used for phone calls. It sounds horrid, mind you.
Audio Sink: Stereo happiness and joy. No microphone input.
Once you have these devices, you do need to set your audio playback device appropriately for Stereo Happiness and Joy.
Mar 27, 2014 | Radio Communications
My Laptop specifications are, ASUS F80Q, dual core, 3 gb ram, Windows 7 ultimate. when i first installed windows 7 (long time ago) it detected my bluetooth device, but now in the middle suddenly it...
Seems like your Bluetooth and Wifi settings are disabled from BIOS.
On laptops usually there is a setting in BIOS where you can disable/Enable Wifi+Bluetooth. Shutdown computer Turn on computer and press "F2" to go to BIOS settings Find settings for Wifi+Bluetooth and set it to default.
Save settings and restart computer You will be able to see your Bluetooth and Wifi.
Hope this works
Jun 29, 2011 | ASUS F80Q-X2AM Notebook
On Windows 7 [64 bit] Interlink Nano Bluetooth [VP6494 SMK-Link] Drivers can detect the Nano Bluetooth Hardware, however the Bluetooth Software [includes the default software that was included in with...
try to uninstall the software, and installing it again in windows xp sp 3 compatibility, you can do so by right clicking on the installation exe of the drivers, select properieties, compatibility, windows xp sp3, check Run as administrator, OK. Install it now, and it could work now.
Mar 01, 2011 | SMK Link VP6494 MINIATURE BLUETOOTHDONGLE...
Belkin bluetooth mouse unable to work with windows 7
try installing the driver for mouse in a compatibility mode....
rightclick on driver file >properties >select compatibility tab > check mark in the checkbox "run this program compatible for" and select windows xp....
guess it ll work fine....
good day....
Mar 03, 2010 | Belkin Bluetooth f8t041-b Mouse
Canon Canoscan D1259U2F dont have any driver for Windows 7 64-bit
the only successful method I found for using CanoScan D1250U2F in 64 bit Windows 7 (I guess the same would be for 64 bit Vista) is to use Windows XP Mode in Virtual PC (attach the scanner as USB device and that's it - works perfectly)
I had a problem with Windows 7 detecting the device as CanoScan (needed for Windows XP Mode to detect is as USB device and allow attach) - the solution was to unplug the scanner, plug it in and CANCEL Windows 7 hardware detection process before it finishes - this leaves it as "CanoScan" device (auto-detect will leave it as "Unrecognized device" and with that unusable/un-attachable in Windows XP Mode)
latest versions of Windows XP Mode will make your hard drives accessible as network locations (no need for external media)
Jan 01, 2010 | Canon CanoScan D1250U2F Flatbed Scanner
Windows 7 and Dell BH200 Bluetooth Headphones
You have to set bluetooth as default audio device. For doing this, go to >Contro Panel> Sound and Audio Devices>Audio(Tab) and in Default Device choose bluetooth device.
In my case, I had problem when i installed SP3 on XP. I changed my bluetooth driver to "Toshiba Bluetooth Stack V6.00.10" and it worked for me.
Oct 30, 2009 | Audio Players & Recorders
DVD Writer not functioning properly in XP
Hi there.
While you are in XP go to the device manager, look down the list of devices for the DVD rom, click on the + icon next to the DVD rom, right click on the DVD and uninstall it, restart the PC and let windows re-detect the DVD and install it.
I also suggest that you clean the registry, download Ccleaner from here, install it and clean the system and registry.
http://www.filehippo.com/download_ccleaner/
Good luck and thanks for using FixYa!!
Mar 04, 2009 | Acer Aspire 4530-5889 Notebook PC
Help! Devices show as working, but "not detected" when opened
You could try to go into the registry and remove the usb enumeration folder "USB" .HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Enum\USB\ change permissions for it to be able to remove it. When you restart your computer all usb devices will be recognized and installed again. Let me know if this helps or not.
Jan 04, 2009 | Creative Labs Zen Sleek Photo MP3 Player
Computers & Internet Logo
140 people viewed this question
David Payne
David Payne
