Question about PC Chips MB PCCHIPS SiS746FX M848A V5.0 462 Motherboard
PC Chips M848A Motherboard
New install in a new case. Old hard drive and Floppy along with CD. Replaced burned out EMachines board and PSU. Used the Athlon XP CPU from old unit. System powers up and appears to go into setup screen, but will not respond to keyboard commands at all. Lights on keyboard flash at startup to indicate process is working. Can't figure out how to get beyond this point.
  • Extincteur Jun 02, 2008
    Didn't think it was possible, but after the eMachines board and PSU fried, I think it took the keyboard and mouse with it. I tried a known good board and it worked, but my right mouse button didn't. Got it all straightened out and working fine. Thanks for the response.
  • Chris Hall May 11, 2010
    have you tried another keyboard?
  • 2,351 Answers
Try clearing the bios/cmos using the jumper on the board, page 10 in you're manual. Than try booting. See if you're keyboard allows you to get into the bios/cmos. I'm guessing you tried another keyboard? You can also buy a PS2 - to -USB Y adapter. This is what one looks like.
If you bought an AGP graphics card lately you might have also received a single PS2 to USB adapter free. Like this one.
It's not uncommon for the the lights to function & yet the keyboard not function. A single pin within the PS2 on the keyboard could be bent or bad or not seating correctly in you're new board.
Posted on May 31, 2008
Currently I have a problem with the motherboard PC CHIPS M848A MODEL, because the sound drivers are not configured correctly.
I uninstall the following contradores Audio C-Media AC97 audio device, and again I get the same error, that are not installed, use the Installation CD that brings the motherboard.
LES would appreciate a quick solution.
My email is WDLR2004@YAHOO.ES
See you soon.
Posted on Feb 01, 2009
Installed new power supply but no power still (dead). Noticed the old power supply had a two wire connection to the motherboard (U8668-D)which new ps didnt have. book for old PS states this connection was...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to fail to detect a hard drive continue on a cycle or to shutdown
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 11, 2010 | Biostar U8668 Motherboard
Computer shutdown
make sure this hard drive is getting power
Test or replace your PSU power supply unit
one bad/faulty lead can cause a computer with lots of problems continually rebooting or failing to detect your drive
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
hope this helps?
Nov 24, 2010 | PC Chips P25G Motherboard
I have a gateway 831gm. it has an Intel (Augsburg) 915G Motherboard and a Pentium 4 630 cpu 800MHz fsb & 2MB L2 cache. i've been looking for a cpu upgrade and saw that the Pentium E5200 Dual Core has...
If both motherboards are LGA775 socket, then the next concern is whether or not the case is capable of having the new motherboard installed into it. Disconnect all power cables to all dv drives or cd drives and hard drives. Disconnect all ribbons from drives to the mother board. If you can get to all of the screws that hold the motherboard into the case, you get away without removing drives. Once you've got the motherboard then you can disconnect the power cable from the motherboard. Remove the memory chips, disconnect the sound cable from the old motherboard. install the memory chips onto the new mobo, Connect the power cable to the new mobo, then install the new mobo into the case. Replace the ribbons from the drives to the mobo, replace the power cables to the drives and reinstall the sound cable to the cd or dv drive. You should be done now.
Dec 13, 2009 | Gateway 831GM PC Desktop
Emachine D2880 no power clarification
your getting power to your PSU, via the green light on your mobo.
verify the PSU has a green light(most emachines do)
it sort of sounds stupid but, check the connection of the cable coming from the front of the case(the wires that connect to the mobo to the power button on the outside of the case.
if all else fails, take the pc out of the case.. put all components on a static free bag and start to rebuild your PC(without a case)
...this will rule out a short on the PC case, and faulty wiring from the case...
pretty much sounds like you've been through almost every step except replacing the PSU(you just said you tested/but your getting power to the PSU)
hope some of this helped
Sep 04, 2009 | E-Machines eMachines Desktop PC
Just installed new CPU on M848A v2.1 and pc will not POST
becose the processor not support that.replace it by a suitable one.
Jan 16, 2009 | PC Chips M848ALU Motherboard
Pc chips a33g no boot windows
If you have a SATA hard drive your windows disk needs SATA drivers on it.
Download Driverspack from this site
Mass storage one
then copy windows CD to hard drive and use "Nlite" to install driverpack into it then burn windows to new CD and try again.
This should solve your problem
Dec 27, 2008 | PC Chips A33G (V1.0) Motherboard
PC Chips M848A dead, no screen output or blips
I had the same problem. I bought the M848A from Newegg in an attempt to save my trusty Athlon 2600+ CPU and a fancy Raedon 512mb AGP card which I salvaged out of my old broken down system. I thought it would be a good time to update the RAM so I bought 2 gigs of OCZ 3200 DDR400 to go with.
(1) First the damn thing wouldn't boot past the post screen. It would simply cycle thru post over and over. Fixed: The microsoft XPpro operating system was corrupt. The new board hated the old configs from the previous system. After trying (and failing) a os repair, I ended up simply doing a clean intall with great results. Board was stable worked great for a week. Only had one glitch...
(2) The board would only recognize and post ONE of the 2 gigs of ram I bought. I raided all the CMOS settings, and downloaded all the user manuals I could get a hold of and found no answers to this curious problem. On a whim, I opened the case and switched their locations back and forth which led me to...
(3) Lights on, no one home. All the lights came on... power, HDD, cd drives... all the fans worked: case, CPU, graphics card... but the screen would remain blank/unpowered and no post menu would come up. Seemed like it wanted to work, but simply stopped short of booting up. THIS WAS YOUR PROBLEM?!?? On a hunch, (more an angry impulse) I reached over and popped an old Mushkin Technologies (PC 3200 400DDR) 512mb out of my old dead mobo and slammed it solo in the primary memory slot. Bingo. Fired right up.
The board appears to be testy with its RAM... If it fails its initial memory test, it will not post. The screen will not come on. I'm not 100% certain this is the final solution to the problem... I'm still playing with it. My questions now are.... do I have dead RAM? Chip compatibility issues? Perhaps the PC Chips support techs on their website have some practical advice on this issue. I'll keep you posted if you like.
Dec 26, 2008 | PC Chips M848ALU Motherboard
Cannot get motherboard to boot from hard drive
Have you checked the Bios to see if its actually recognising the hard drive?
Turn on the computer and I think on your bios it should be the f2 key to get into the bios, if its not detecting the hard drive you may just have a jumper on the drive set wrong
Let me know if I can be of further assistance
Aug 22, 2008 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
Motherboard will not boot from Hard Drive
Go into your BIOS with the appropriate key (printed on the screen when you first turn the PC on).
Look around the various menus for a "boot order" or something to that effect.
I'd usually set it for CDROM then HDD... but as long as the hard disk is actually in the list before anything else with a bootable disc in it, you should be fine!
I replaced mother board now I can't access files on old HD
Try going into the BIOS settings and setting the slave drive as the 1st boot drive.
May 04, 2008 | Intel Motherboard
Computers & Internet Logo
1,045 people viewed this question
Top PC Chips Computers & Internet Experts
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
