Question about Gestetner Copier
Will copiers misfeed when toner is low and would you get a joo1 code
  • 29 Answers
I don't know about the j001 code but generally the reason a copier will misfeed is the pick up rollers being worn. There can be a number of other reasons besides this but this is the most likely.
Posted on Oct 10, 2010
FAINT COPIES RICOH AFICIO 2035E I have been experiencing the following problem for a while but it clear if I perform the following solutions. When I ADD TONER MANUALLY add toner in the developing un
YOU CAN TRY THIS.
AFTER YOU DO MEMORY CLEAR THEN YOU HAVE TO FIRST DO FORCE TONER SUPPLY UNTIL THE IMAGE IS GOOD ENOUGH AFTER THAT RUN THE ID SENSOR INITIALIZE. I HAVE AN EXPERIANCE A FEW YEARS AGO AND I DID THIS WAY AND ITS OK. ( MUST CLEANS THE ID SENSOR BEFORE DO INITIALIZE)
Nov 28, 2014 | Ricoh Aficio 2035E Digital Copier. 35cpm...
Tip
How to retrived your machine from misfeed or stacking up in fuser unit
first introduction misfeed have alot of places in machin copiers actually some times trays is not convenient with criterion on machine that mean yo have tray a4 horizontal if yo made a3 it's make misfeed and fuser unit make misfeedes in fingers may broken and may cooler roller accumulate on it masses of burned toner make heavy load on fuser unit mechanism
on Apr 22, 2011 | Office Equipment & Supplies
Xerox WorkCentre 7120 error code
Chain Description 001 Cover and Door Interlocks 002 Touch Screen / Control Panel 003, 041, 045, 123 Machine Communications 004 Drives 005 Duplex Automatic Document Feeder (DADF) 061, 062 Scanner, DADF and ROS 007 Paper Supply 008 Paper Feed 009, 089 Xerographics 010, 011 Fuser, Copy Exit 012, 013, 047, 112 Finisher 016, 124, 127 Configuration, Software, Memory, Hard Drives, Color Server, DFE 018 Network Communications 020 Fax, Software 021, 121 Foreign Interface 022 Job Timers 024, 026, 027, 033 Job Parameters 034, 035, 036, 133, 134 Fax Communication 042 Motor, Fan, Sensor 071 Tray 1 Misfeed 072 Tray 2 Misfeed 073 Tray 3 Misfeed 074 Tray 4 Misfeed 075 Tray 5 Misfeed (Bypass Tray) 077 Paper Path Jam 078 High Capacity Feeder 083, 084 Fax Jobs 091 Drum Cartridge 092, 093 ATC, ADC, Toner 094 IBT, BTR 102 Job Queue 103, 116 Software
Aug 23, 2014 | Xerox Office Equipment & Supplies
Ricoh Aficio CL3500N printer phantom misfeed
It seems that the sensor is having dust or toner settled upon it. Kindly remove the toner and clean the residual toner. Take a hard stock paper and give one copy command and push it while it tries to pull the paper. Paper misfeed is not the same as paper jam. Paper misfeed refers to the blank paper tray and paper jam refers to paper which has been taken from the tray and now inside the unit.
May 19, 2010 | Ricoh Aficio CL3500N Laser Printer
Misfeed detected but no paper jam
Di 251 is legacy Minolta machine, Minolta is now Konica Minolta
for the image unit try this site
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
as for the adf replace!!! the rollers all three try the same site above
Nov 03, 2009 | Minolta Di251 All-In-One Printer
Ricoh Aficio 250, clear misfeeds at w and finisher
Clean the sensors in this parts and try reset the SC codes:Enter in the SP mode press 5-810 (SC code reset)select 1.Then hold down the Photo mode key and the +key at the same time for at least 4 sec.
Sep 23, 2009 | Ricoh Aficio 250 Copier
We have a Sharp 1641CS copier will not feed or copy
Well one reason the Cartirdge is spilling is due to the cartridge backing up with toner everytime it tries to print, it misfeeds cause the paper feed tires need to be replaced,
May 29, 2009 | Sharp AL-1641CS Copier
FLASHING EXCLAMATION POINT
Link to the manual: http://h10032.www1.hp.com/ctg/Manual/bpd09762.pdf
Basically it only means that the printer needs attention.
I would check for a paper jam or misfeed, out of paper, low or empty toner.
Dec 12, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Toner replacement
When this happens it is usually because the paper has misfeed remove paper from cassette tray replace it then reseat toner.
Jan 03, 2008 | Canon imageCLASS® MF4150 All-In-One Laser...
269 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
