Question about Fuji DocuPrint C1110B Laser Printer
My Xerox phaser 6125 shows me a message Error 062-370. What can I do?
My Xerox Phaser 6125 smears black (!) toner, extra obvious and totalley unacceptable on double sided printed sheets. Different types of paper all show the same problem.
This would normally be the cleaning unit to blame. If in doubt go,to the Xerox.com website and investigate further.
Good luck.
Sep 24, 2013 | Xerox Phaser 6125 Laser Printer
Xerox Phaser 6125 prints pink
you cal also try to clean the laserwindow of the Magenta imaging unit
Nov 08, 2012 | Xerox Phaser 6125 Laser Printer
Our phaser 6125 is making a lot of noises when it is printing. Any suggestions?
Open the front tray of the printer and check if something is broken. If there is, ask yourself if you can fix it, if not, send it to Xerox support.
Phaser 6125 does a lot of noise in all the prints. Are you sure its not the normal noise?
Aug 17, 2011 | Xerox Phaser 6125 Laser Printer
I have a problem with the fusor xerox phaser 6125, the display say error 010-397 please help me
That is in fact a problem with the printers fuser, which melts the toner to the paper. You should replace the fuser (part# 675K65654). To replace it open the front door, and at the top right you should see a gray clip you push down and then slide the fuser out starting with the right. When installing the new fuser slide the left side in first and then the right. Iteminc.com has this part in stock and ships same day. Hope this helps, good luck. Thanks for using FixYa!
Aug 08, 2011 | Laser Phaser 6125 Colour XEROX Phaser...
Today when I wanted to print something the following problem appeared on my Phaser 6125: Error 061-370 My printer is rather new and has about 2000 copies done. I've turned the printer off, waited a...
An internal error has occurred. Turn the printer off and on. If the problem is still there the laser needs to be replaced. If the machine is less than a year old then the machine will be fixed under warranty.
Mar 04, 2011 | Xerox Phaser 6125 Laser Printer
How to fix invalid black message after replacing a toner
how to fix invalid black message after replacing a toner And I have the same problem. I buy 4 new toners and for each one i get notice from xerox 6125 invalid black, or invalid yellow. What do I need work?
Feb 26, 2011 | Xerox Phaser 6125 Laser Printer
How to refill xerox phaser 6125?
Just found a supplier for toner and reset chips for my new 6125. Don't know where you're based but in the UK you can use the following link:-
http://www.zinetic.co.uk/Xerox_Phaser_6125_Toner_Refill_Rainbow_Pack-details.aspx
In the US, a possible source from EBAY is:-
http://cgi.ebay.co.uk/4-Xerox-Phaser-6125-6125N-6130-6130N-Toner-Refill-HY_W0QQitemZ380126889100QQcmdZViewItemQQptZBI_Toner?hash=item588154048c&_trksid=p3286.c0.m14&_trkparms=72:1683|66:2|65:12|39:1|240:1318|301:1|293:1|294:50
Good luck.
MJN
Apr 07, 2009 | Xerox Phaser 6125 Laser Printer
I need an Apple Mac driver for the Xerox Phaser 6125 printer
Hi there, I found a driver that will work for this printer. I currently have the Xerox Phaser 6125 as well. Its called the FujiXerox Fuji DocuPrint C525 Driver and can be found here:
http://www.fujixeroxprinters.com.au//en/support/Downloads.aspx?product=5452&category=5726&os=124&dl=108
The original thread that helped me is here: http://www.openprinting.org/show_printer.cgi?recnum=Xerox-Phaser_6125
Hope this helps, DreamGirlB
Mar 21, 2009 | Xerox Phaser 6125 Laser Printer
Laser Error Error message 061-370 for Xerox Phaser 6125
From the service manual:
Troubleshooting Procedure Table
Step Actions and Questions Yes No
1 Check the Laser Unit for correct
installation.
Is the Laser Unit correctly installed?
Go to step 3. Reinstall the
Laser Unit. Go
to step 2.
2 Cycle the power.
Does the error still occur?
Go to step 3. Complete.
3 Check the wiring harness connectors
P/J40, P/J41, P/J411, and P/J412
between the MCU Board and the Laser
Unit.
Are the connectors securely
connected?
Go to step 5 Reconnect the
connectors. Go
to step 4.
4 Cycle the power.
Go to step 5. Complete.
5 Replace the Laser Unit (page 8-31).
Replace the
MCU Board
(page 8-59).
Complete.
Jan 31, 2009 | Xerox Phaser 6125 Laser Printer
Fuji DocuPrint C1110B Laser Printer Logo
70 people viewed this question
Top Fuji Office Equipment & Supplies Experts
billconfused
mukhtar21 shaikh
mukhtar21 shaikh
Dave Busselle
Level 1 Expert
Are you a Fuji Office Equipment and Supply Expert? Answer questions, earn points and help others
