Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
At first a loud noise, and then no picture - Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
    Problem Solver:
  • 5 Answers
Try checking the on/off button or standby button. Does it flash multiple times? Does it show any other words besides on/off? The trouble code is usually identified by the number of times the on/off or standby button flashes. These codes can be found at Samsung's trouble shooting website.
Posted on Oct 18, 2010
My phillips is making a loud buzzing noise, no picture, then it shuts off
presuming it has one two choices: contact Philips (good luck there) or Google the model number with "color wheel"
Oct 31, 2012 | Philips 50PL9126D/37B 50" DLP TV
Loud noise now tv wont turn on
More than not if it is a loud noise shortly after you turn the set on, the color wheel is bad. The color wheel is not available by itself and requires the complete light engine to be replaced. The part number for the light engine is 75002250. I would suggest having a technician replace this for you if this is the case. Please take a moment to rate my answer. Thanks...
Nov 25, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
Makes loud vibrating noise when turning off and on
the high voltage transformer is going more than likely.
the picture is affected because the flyback transformer drives the horizontal deflection circuit as well
May 27, 2009 | Televison & Video
Loud popping on jvc av56wp74
if the noise is from inside the tv in the back,the high voltage transformer that feeds the anode for the rgb tubes,28000volts probably is arcing.
May 23, 2009 | JVC AV-56WP74 56" Rear Projection...
Poor picture quality and loud buzzing noise
Sounds like your color wheel is failing they make a loud sqeauling noise when they begin to fail.Run you somewhere around $300-400 to have a tech repair it.
http://the-tv-dude.blogspot.com
May 03, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Replaced bulb and now no picture and a loud humming sound
replaced the light engine. yhis set is probably not cost affective to fix.
Apr 03, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Samsung DLP TV (720p) Gray picture, loud spinning noise
It sounds like you have a defective COLOR WHEEL, common problem with DLP's. You need to contact a service comp. for replacement and availability.
Feb 13, 2009 | Samsung Televison & Video
Sounds like a jet taking off
the horizontal output transistor is busted or a protect diode,check the plyback maybe it has a leak
Oct 15, 2008 | Samsung HL-P6163W 61" TV
Loud cracking noise sounds like fireworks and wont get a picture
It seems you have loose or cold solder joint connection problem,causing a cracking sound.The solution is to reworks or resolder the solder joint connection in power supply section, audio section and inverter section...
Hope this may help you;
Regards,
VOTIT
Sep 25, 2008 | LG RZ-37LZ30 37 in. LCD Television
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
