Question about Delta 10"Hybrid Tablesaw with 30"Unifence
I have a delta 36-600 table saw that the clutch or drive has quit working . the motor was rebuilt about a year ago now the drive slips is there a simple or easy fix or adjustment to the clutch for this problem .the saw has been overloaded several times creatiing the failure. thanks for any help you can offer. Gerry
In my Delta table saw the motor and blade turns but it can't cut even MDF, the blade stops as motor runs super strong. It seems to be a clutch problem but I am not sure other parts such as belt, gears or ... involved. I appreciate any help.
Posted on Aug 21, 2011
  • mort131 Aug 21, 2011
    Indeed the problem was the belt. Now I need to order that from Delta. Does anyone knows the part number since I don't have the manual for it.
If you have a motor with the no.1313314 and the motor runs ,but the blade spindel does not turn try removing the backcover plate . With this removed you might find that the toothed gear belt has broken. If this ,in fact, is the problem the belt is a Bando syncro,link 100xl.
Hope this rectifies your problem as I am waiting for a new belt myself.
E
Posted on Jul 21, 2011
I own a Delta Shopsmart table saw model TS220LS and I have not used it for years and it still work but I don't know how to get the saw to rise above the table level. thanks.
On pos 75 page A turn the depth adjustment clockwise otherwise if its blocked by wood or other trash control the mechanic and clean it dry .
  • Delta TS220LS TYPE 1 Bench Table Saw Parts
Sep 17, 2016 | Delta Saws
Good morning guys.i have an old trojan radial arm saw that needs it vee belts renewing. do you have a exploded view of this area of the saw.estimate saw is 40 years old. still does the job.years ago i
Hi , I have one of the same , a Trojan Radial Arm saw made in Lower Hutt , NZ. I bought it from a joiner whom purchased it new. I have the original manual with vbelt replacement instructions if this is usefull? Nygenz@hotmail.com
UPDATE: currently June 2016 and I am getting someone requesting this manual every 3months or so. Testement to how well these saws were built as they're all 40 + years old now/
Jan 21, 2013 | Delta Saws
I have a 10" Delta Table saw Model 34-670. I was
Check nameplate on motor for amp draw, and then check that against your breaker and wire size.
http://waterheatertimer.org/Color-codewire2.html
If table saw worked on the breakers before and suddenly stopped working, then see if you can lubricate motor bearings >> look for oil cap on each end of motor and use 3-in-1 oil.
Clean the saw and make sure there's nothing rubbing against drive belt and that saw blade rolls easily when saw is turned off.
Mar 02, 2011 | Delta Saws
I have a delta contractors table saw that wont start. It has a Marathon Electric Motor 62-044 that hangs off the back. It has capacitors rather than brushes. When you turn on the swithch it does nothing. I...
Most likely to quit suddenly is the switch.
My table saw switch broke recently, and at first I thought it was the motor.
Over the years I remember seeing table saws fitted with a handy box and ordinary light switch to replace the table saw switch.
Check for power at motor: Sometimes the wire connection from switch has access box on the motor where you can get in and check for power.
Feb 01, 2011 | Delta 36-979 10" Left-Tilt Contractor's...
My delta 36-650 table saw 1.5hp motor dims lights
If you didnt replace your switch ... do so now. If you did replace the switch, check your work
Oct 25, 2009 | Saws
Delta Table Saw stopped running
I have a table saw that the cord from the motor plugs into the the back of the on/off switch. I yours is configured like that, unplug the motor cord from the back of the switch and plug it in to the wall and see if the motor will run. If so replace the switch.
Jun 21, 2009 | Delta 10"Hybrid Tablesaw with 30"Unifence
Motor not working on Delta table saw: I just got a used Delta table saw for free, the previous owner said the motor wasn't working. I wonder if it could just be a switch... how could I check that? I also...
Ok, the motor turns, but throws sparks on the brushes. This is normal to an extent for universal motors used on that type of equipment.
Try reassembling the saw, and put a blade on it, then try it. If it runs, try cutting a piece of scrap 1x, both crosscut & rip. If the motor can't hold the load, you may still have to replace it.
Apr 16, 2009 | Delta 10"Hybrid Tablesaw with 30"Unifence
Changing voltage on motor...
pull up the i.s. wiring code from that time
i.s. international standards.
the code change a few years ago
Apr 09, 2009 | Delta Radial Arm Saw
I was using my Delta TS220LS table saw and it stopped running.
Confirm there is power to the plug that you are using to power the saw.
Reply back your finding and I can help you further.
Jan 07, 2009 | Saws
Delta 10"Hybrid Tablesaw with 30"Unifence Logo
689 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
Craig Butler
Craig Butler
Are you a Delta Saw Expert? Answer questions, earn points and help others
