Question about Sony Dvcam DSR-PD170 DV Digital Camcorder
I have a PD170 camera. Whenever I turn the camera on the record function, a yellow tape-with-slash icon appears to the left of a yellow eject icon. It refuses to record. However, when switching to the Play function, it plays back the tape just fine. It just has this problem on the Record function. Prior to this problem, it had been doing something strange with resetting itself every time the battery was charged and had been placed back into the camera.
  • 3,083 Answers
The most likely thing I would suspect, is that possibly the cmos type battery inside the camera on the circuit board died- it's the small battery on the circuit board for the firmware that holds the time and settings when the camera's main batteries are not inserted. That's what I suspect with the resetting problem.
I think you have a different problem going on with the tape. The icon is indicating that the camera isn't detecting the tape correctly, and that's usually caused by a sensor or switch, that gets activated when the tape loads around the head. Chances are the tape deck needs cleaning, and that might solve the problem. I don't recommend people servicing these, since they're hard to clean and regrease correctly without taking them partially apart.
You're going to, however, have to take it apart to chance the cmos/firmware battery, so you might be able to access the tape mech. If you google "cleaning tape decks on camcorders" you will some sites that explain how. Although each tape deck might have some physical differences, they're like cars, and the main components are similar in structure and fuction.
If you elect to have it repair, Panasonic will repair it, or you can try a local camera shop. Get an estimate first, just to keep them honest (and you forwarned about the cost).
Good luck, and hope this helps.
Posted on Oct 10, 2010
I turn the camera to record and it blinks an icon which resembles ejeciting the tape. It is a triangle over a line. It also blinks "C:31:23" It will not allow me to record. What is it?
You need to try to eject the tape and put it back in the camera. That error means that something has happened with the tape transport and the camera could need a cleaning tape but not necessarily. Try re-inserting the tape. If the error appears again, try a different tape. If the error still appears, run a cleaning tape in the camera on playback for 8-14 seconds (no longer!). Then put a regular tape back in. If you still see the error, there is probably a mechanical problem in the tape transport and the camera will need to be repaired. It's possible it could just need a clean and lube on the mechanical parts, but in any case you will need to take it to a camera shop for an estimate.
Nov 30, 2010 | Sony Handycam DCR-TRV330 Digital Camcorder
When i put a tape in it ejects it..then a tape with a slash appears on the screen
you are prohibited from recording on thips tape. This is because the red tab on the side of the tape that faces you when you are inserting the tape inside the camera has been put in 'SAVE' position . to be able to record o the tape you need to use your fingernail to slide the red tab to the 'REC' position.
Ive extracted the following article for you from wilkepedia to help you understand this issue:
Tape and recording protection
250px-8mm_cassette_erase_tab.jpg magnify-clip.pngThe write-protect switch (right) prevents accidental erasure. .
To prevent the recording on the tape from being erased, there is a small write-protect tab that can be moved to one of two positions, labeled "REC" and "SAVE". Comparing the sliding tab to a door, the tape is in the "REC" position is when the "door" is open and the "SAVE" position when it is closed. (Not all tape cases have markings for this information!) The tape can only be recorded on (or recorded over) when this tab is in the "REC" position. This is an improved version of the VHS write-protect tab, which prevents erasure after it has been (permanently) broken off.
Dec 02, 2009 | Sony Handycam CCD-TRV318 Camcorder
Sony Camcorder DCR-TVR140 NTSC does not recognize tape in camera
daer
this error C:31:23 is related to the s reel and this occurs only when the tension of the tape is more,
solution:
1 st try to change the tape
if the problem persists then u need to take it to the service center as the tape path of the mechanical section is to be adjusted
as you are telling that your camcorder is not showing remaining time (time code ) then head assy. also need to be cleaned ..try to use cleaning tape for 10 sec. not more then that .
Jun 24, 2009 | Sony Handycam DCR-TRV140 Digital Camcorder
PD170 Record Button Won't Work
any one of the record button will be struck or short...
Jul 08, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
"DV IF" Flashing
To get rid of the DV IF flashing go to >menu>systems>DV control ...OFF. (page 63 in the instruction manual)
Mar 06, 2008 | Canon XL1S Mini DV Digital Camcorder
Time code breaks
have the PD170 professionally cleaned; a worn pinch roller causes time code inaccuracies like the ones you are describing.
Nov 12, 2007 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Sony Dvcam DSR-PD170 DV Digital Camcorder Logo
83 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
