Question about DateXX Office Equipment & Supplies
How do use the datexx ds700 for this problem 5(3x-7)
How do I find the 4th square root of 16 on a datexx ds-700 scientific calculator??
Roots are called as follows:
square root
cube /cubic root
From 4th on, use the ordinal fifth, sixth, ... n-th
To calculate the fourth root you have two possibilities.
  1. Some calculators have the x-root key marked with an x followed by the radical symbol. See the screen capture on how to find your result.
    Usually the x-root is the SHIFTED function of the general power key that is marked ( [^], [X^y], or [Y^x] ). To use it, you inter the index of the root (the ordinal number). then you press the [SHIFT/2nd/ 2nd] [X^y] sequence and the number whose root you are calculating).
  2. Alternatively: Use the equivalence n-th Root (x)=x^(1/n), meaning that to extract the fourth root of 16, you raise 16 to the power of (1/4)
Sep 19, 2014 | DateXX DS-700 - 2 line LCD Display 224...
Why won't my DateXX DS-883 Graphing Calculator work, it has new batteries?
Try a Q-Tip soaked with alcohol and clean the battery terminals. Also, WD-40 works well to. If batteries are left in too long after a total discharge, it can produce acid which will eat away the plating on the terminals. If that's the problem, WD-40 is the best choice to use.
Sep 05, 2014 | DateXX DS-883 Calculator
I have a DATEXX DRC-605 Exactime clock that just changed the date to two days ahead for some reason. How can I change it back to correct date?
Please follow these steps:
* Press and hold MODE button for 3 seconds: the year digit will flash.
* Press UP ( + ) or DOWN ( - ) to change flashing digits.
* After the first value is set, press MODE button again to confirm and move to the next parameter.
* Continue setting month, date, hour, minutes and temperature display format.
* Press MODE button for the last time to return to the time of day with seconds, after the last parameter is set.
I hope I could help.
Thanks.
gylacz
Aug 22, 2011 | DateXX DRC-608 Clock Radio
How do i do log base x problems (other than log base 10) on the datexx ds 883?
Calculate it the same way as on most other calculators, using the relation
log_b(x) = log(x)/log(b) = ln(x)/ln(b)
In words, calculate the log base 10 of x divided by the log base 10 of the base. You can also use the natural log function instead of the common (base 10) log--just be consistent.
Oct 19, 2010 | DateXX DS-883 Calculator
How to use the power sign
The power key is usually marked Y^x or X^y, or just ^
Enter the base (the number to be raised to a power), press the power key followed by the exponent.
Oct 05, 2010 | DateXX DS700C Calculator
Using the percent key...for example finding 25% of 120.
To calculate 25% of 120, press 1 2 0 * 2 5 SHIFT [%]
Sep 09, 2010 | DateXX DS700C Calculator
Top DateXX Office Equipment & Supplies Experts
jasbo
jasbo
Are you a DateXX Office Equipment and Supply Expert? Answer questions, earn points and help others
