Question about Orion Atlas 8 EQ-G Telescope
Electronics - Atas EQ-G - connection is lost when guiding program begins calibration. Tracking and mount control lock up requiring restart of mount. Thanks
  • 3,186 Answers
Have you upgraded the motor control firmware and the hand controller firmware to the latest version? If not see this web site which contains instructions for updating the firmware.
http://www.telescope.com/control/accessories/mounts-and-tripods/orion-atlas-eq-g-computerized-goto-telescope-mount
This could also be caused by a USB-Serial adapter cable. Try another brand. The one sold by www.scopestuff.com works --- along with a Keyspan brand Serial-USB adapter.
Posted on Oct 13, 2010
2005 Chevy Malibu Lt v6 3.5, has anti theftwont go off, after ignition cylinder change
Did you change key also ? does it have transponder chip in the head of the key ? Needs to be programmed . You change what ? Ignition lock cylinder an key ?
Important: When replacing either the vehicle keys, PCM, or TDM and the 10-Minute Relearn Procedure is used, ensure that the appropriate calibration is selected for the replacement component on the calibration selection screen of the service programming system. The appropriate calibrations for specific vehicle theft deterrent (VTD) system components are described below.
• When preparing a TDM for replacement, the Prepare Module For TDM Setup Procedure calibration is required. This allows the retrieval of required information from the TDM prior to its replacement.
• When learning vehicle keys and the 10-Minute Relearn Procedure is used, the Vehicle Theft Deterrent Learn For Learning Replacement Keys calibration is required. This clears all previously learned keys from the TDM and enables the TDM to learn new vehicle keys. For learning additional vehicle keys, refer to Adding Keys .
• When replacing a TDM or ECM and the 10-Minute Relearn Procedure is used, the VTD Learn for Powertrain calibration is required. This clears the previously learned fuel continue password in the ECM and enables the ECM to learn the fuel continue password of the new TDM.
Important: When replacing a TDM with a GM SPO Replacement Part, insure the Setup a New TDM procedure is performed prior to the 10-Minute Relearn Procedure.
Connect a scan tool to the vehicle.
Turn ON the ignition, with the engine OFF.
Ensure that all power consuming devices are turned OFF on the vehicle.
With a scan tool, select Request Info. under Service Programming System and follow the scan tool on-screen instructions.
Disconnect the scan tool from the vehicle and connect the scan tool to a Techline Terminal with the current Service Programming System (SPS) software.
On the Techline Terminal, select Service Programming System and follow the Techline Terminal on-screen instructions. Ensure the correct programming procedure is selected based on the component being replaced or programmed. See Important above.
Disconnect the scan tool from the Techline Terminal and re-connect the scan tool to the vehicle.
With a master vehicle key, turn ON the ignition, with the engine OFF.
With a scan tool, select Program ECU under Service Programming System.
At this point the scan tool must remain connected for the duration of the 10-Minute Relearn Procedure.
Jun 13, 2017 | Cars & Trucks
Try to program and it comes error L5
PAGE 63-64 in link Describe "LS" error.
7
Belts stop turning and "err
LS" or "err OS" is displayed
Calibration
Re-calibrate machine. (See Calibration Procedures, Pg 26)
SPEED
SENSOR
1. Cycle power off and on
2. Put the machine in calibration mode (see Calibration
procedures, Pg 26) but do not start the calibration routine.
3. Remove right rear base plastic cover to allow access to
LED board. Caution: Machine is on. Current is active!!
4. Locate LED D on the motor controller board. LED may
be lit or unlit.
5. Manually advance the treadle with your foot, and check
if LED D is blinking.
6. If LED D is not blinking, then the speed sensor is not sup
plying a signal. Check that the speed sensor is connected
securely to P1 on the motor controller. If sensor is con
nected and LED D still does not flash replace sensor.
I/O cables
If LED D is flashing when the belts are turning but err LS
or OS persists, check for signs of visible damage to any of
the three I/O calbes and connections. If no visible damage
check continuity using a multi-meter. If a multi-meter is
not available replace all three cables.
Electronics
If all I/O cables are functioning properly, LED D indicates
speed sensor is functioning, and err LS or OS persists
problem is in either the upper electronics board or the
motor controller board. With machine on check LED A
on the controller board. If it is dimly lit replace upper
electronics (000-4430). If it is not lit at all replace motor
controller.
http://download.nautilus.com/supportdocs/AM_OM/Bowflex/BFX_TC5300_6000_OM_AM_RevA_web.pdf
Jun 04, 2014 | Bowflex Treadclimber TC5300
Lifebook tablet stylus doesnt work
Hello, Lori -
If you received a user's guide for your laptop when you purchased it, check the manual, starting on page 30 for instructions on using the stylus (called a pen) in the guide.
If you do not have a user's guide for your laptop, you can find and download one here (free):
http://solutions.us.fujitsu.com/www/content/pdf/SupportGuides/T4220_UG_B5FJ-4091-01EN-00.pdf
You will need Adobe Reader software (free) loaded on your laptop. After you download the guide, save it with a file name you can find easily - something like: Fujitsu Lifebook T4220 Manual. If your laptop is connected to a printer, you can print the guide for easy reference.
The information on using the stylus / pen begins on image 40 (page 30) of the PDF document.
Information from page 31 (image 41 in the PDF document) regarding the pen:
CALIBRATING THE PEN
In order to ensure accurate tracking between the pen
and cursor, you must run the Touch Screen Calibration
Utility before you use the active digitizer for the first
time, or after you change the display resolution.
To run the calibration utility:
1. Go to Start -> Control Panel and double-click on
the Tablet and Pen Settings icon.
2. Click Calibrate.
3. Adjust the display of your Tablet PC to a comfort-
able angle.
4. Using the pen, firmly touch the screen directly on
the (+) symbol; the (+) symbol will move to the
next location.
5. Repeat step 4 in the four corners, then click OK.
Best wishes.
Feb 09, 2018 | Fujitsu Computers & Internet
Thinking of buying this, but wondering if it can connect to computers and cameras
This is fine for planetary and lunar views with a camera. The mount is manual drive so not suitable for deep sky objects with a camera (except perhaps M42)
Orion and Celestron make inexpensive, lightweight usb cameras for telescopes. Suggest you use the scope with your eyes until you get used to finding and tracking objects.
Serious astro photographers use much bigger scopes with motorized GEM (German Equatorial Mount). Takes lots of practice and $$$
Oct 22, 2012 | Celestron PowerSeeker 114 EQ Telescope
How to adjust horizontal start position of label
is it possible to track the label stock with some guides?? before the printhead sometimes zebras use guides. some zebras also allow you to set a margin in the software or control panel itself.
Jul 11, 2017 | Zebra GX420d Thermal Label Printer
Problem with the HP LaserJet 4730mfp All-In-One Printer Unable to use ADF. Red light under start button.
Do the calibration for the scanner.
1. Place letter- or A4-size paper in tray 1, and adjust the side guides.
2. On the control-panel Home screen, scroll to and touch Administration.
3. Touch Troubleshooting.
4. Touch Calibrate Scanner.
5. Touch Calibrate to print the first pass of the calibration target(Print out).
6. Place the first pass of the calibration target face-down in tray 1 so that the arrows are facing into the MFP.
7. Touch Start to print the second pass.
8. Place the calibration target face-up into the ADF, and adjust the side guides.
9. After the calibration target has passed through the ADF once, reposition it face down in the ADF and touch Start.
10. Place the calibration target face-down on the scanner glass, touch Start, and scan the page.
After this pass, the calibration is complete.
Calibration will fails if print quality is not good...ensure that print quality must be in order..
Once calibration successfully done, restart printer several times & verify start button light, if its green every time 'u' re success. if not cleaning required for CCD which is major work & not suggestable..
Aug 30, 2011 | HP LaserJet 4730mfp All-In-One Printer
At a startup performing calibration initialization long HP Color Laserjet 4600dn
Calibration bypass
During certain diagnostic procedures, you will need to bypass the automatic calibration that is
performed whenever the printer is turned on.
To bypass calibration
1 Turn the printer on and watch the control panel display.
2 When the display begins showing the memory count, press and hold until all three lights on
the control panel are lit.
3 Press .
4 Press PAUSE/RESUME. The display should show SKIP DISK LOAD.
5 Press until SKIP CALIBRATION is highlighted.
6 Press . The printer will skip calibration and then continue its power-on sequence.
Please refer here for further details if required
Let me know if any further clarification is required. Hope this helps!
CreativeTECH
Nov 26, 2010 | HP LaserJet 4600dn Color Printer
Channels locked
Please follow this guide to unlock your tv :
www.ehow.com/how_4488981_unlock-tv.html
Regards,
Feb 05, 2010 | iLO 3200 32 in. LCD Television
Setting the star coordinates on a celestron Astromaster EQ mount
You need to put more information into your question. There are several different Celestron EQ mounts with different hand controllers.
Go to www.cloudynights.com and post your question with the exact model information in the member forums.
Nov 06, 2009 | Celestron Optics
I need to find out the weiring diagrame to install it
Equalizers Like a crossover, the equalizer gets installed between your receiver and your amplifier. The outputs will be preamp connections to your amplifier. You'll find EQs that are designed to be installed in the dash, above or below your receiver. Others are designed to be mounted in a remote location, like the trunk. Either way, the wiring connections required will be the same. To install:
1. Mounting the equalizer:
A remote-mount EQ can be securely mounted with just a few screws. Anywhere between the receiver and the amp is fine. Most people mount the EQ in the trunk near their amp, especially if you have more than one amp. This also makes it easier to add additional amps later. You should mount it where it will be easy to get to so that you can make adjustments without too much trouble. Don't mount your EQ directly on steel — you will invite noise problems. Instead, install it on a non-conductive board and attach the board to the car body (or use rubber grommets under the screws to isolate the crossover).
An in-dash EQ can be mounted above or below your in-dash receiver, assuming that you have space available in the dash. This will require custom installation work. Another option is installation below your dash, in a universal under-dash mounting kit. To install the under-dash mounting kit, attach it to the mounting surface using the supplied self-tapping screws. In most cases, the use of an under-dash kit will require modifications to the kit or to the mounting surface.
3a-xover.jpg Locate the remote turn-on lead behind your radio (usually a blue wire). 3b-xover.jpg Connect the turn-on lead from your amplifier wiring kit to the blue wire. You can wrap the bare wire ends together and cover with electrical tape, or use solder. 2. Making the power connections:Your EQ will require 12-volt power, ground, and turn-on signal connections.
  • To obtain 12-volt power: Cut a length of small-gauge cable (16 gauge is typically sufficient) long enough to reach from the EQ location to your vehicle's fuse panel. Strip one end of the wire, and attach it to the EQ's power input. This may require a crimp-on connector, or bare wire might be sufficient, depending on the equipment you're installing. Route the wire from the EQ location to your car's fuse panel. Using a fuse tap, connect the wire to a source of switched 12V power.
  • To ground the EQ: Remove a bolt near the EQ mounting location. Crimp a ring terminal to one end of a length of small-gauge wire, and then bolt the terminal tightly to the vehicle's metal chassis. Scrape away any paint and clean the bolt location thoroughly. If you can't find a convenient ground screw or bolt, drill a hole for one — be careful not to drill into the gas tank or a gas or brake line.
  • Making the turn-on connection: In most cases, you can tap into your in-dash receiver's amp turn-on lead to get a turn-on signal for your EQ. Remove the receiver from the dash to access the turn-on wire (usually a blue wire). For step-by-step instructions on removing your vehicle's radio, see your vehicle-specific Crutchfield MasterSheet™, or read our In-Dash Receiver Installation Guide. Strip the insulation off a small section of this wire coming from the radio. Strip the insulation off another small-gauge cable that's long enough to reach from the in-dash receiver to the EQ, then connect the two with crimp caps or solder. Wrap the solder or crimp connection with electrical tape to guard against a short. Using wire ties to secure the wire, route the turn-on lead behind your dash all the way to the EQ mounting location.
3. Making the signal connections:
In most cases, you'll be routing RCA cables from your in-dash receiver's preamp outputs to the inputs of your EQ. While your receiver is out of the dash to access the turn on lead, connect a set of RCA patch cables (long enough to reach your crossover in its mounting location) to these outputs, taping them together so they won't come apart. Route the patch cables (again using wire ties) behind the dash, and to the crossover mounting location.
May 14, 2009 | Alpine Car Audio & Video
Orion Atlas  8 EQ-G Telescope Logo
122 people viewed this question
Top Orion Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
deton8 von Splosion
Tony Parsons
Tony Parsons
Are you an Orion Optic Expert? Answer questions, earn points and help others
