Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
When we press garage door button to open door it only stays on for about 1 second then closes never opening
    President:
  • 3,197 Answers
Check to make sure you do not have a broken door spring and you should also remove the cover from the motor unit and check the drive gear. It may be stripped. It will be obvious if it is.
Posted on Oct 11, 2010
Garage door will close, stays shut for a few seconds and then opens on its own.
The opener is closing too far. On the side of the opener, you should see 2 white knobs, recessed into the side. Using a flat blade screw driver, adjust the close knob (closest to the door side of the opener), anti-clockwise until the door will close gently on the floor.
Aug 24, 2013 | liftmaster Garage Door 1/2 Hp
Tip
2010 BMW 528XI Garage Door Opener Homelink Setup
**** >>> This setup I performed with my new 2010 BMW 528XI Garage Door Homelink and Chamberlain Garage Door Opener <<< ****
Chamberlain:
01. Power off or unplug the garage door opener motor power supply (which is mounted on ceiling of the garage) ;;;
02. keep the garage door opener transmitter in your hand (do not press any button at this time) ;;;
03. In your 2010 BMW 528XI Homelink button (which resides under rear view mirror) press the 1st and 3rd homelink button together for about 30-40 seconds (i.e., until the yellow light blinks fast) and when the yellow light next to the homelink button blinks fast release from pressing the (homelink) buttons ;;;
04. now hold the garage door opener transmitter closer (means within 2-4 inches) to the homelink button (either 1st or 2nd or 3rd) whichever you are planning to program to open the garage door ;;;
05. now press the garage door opener transmitter button and chosen homelink button (either 1st or 2nd or 3rd whatever you need) together ;;;
06. the yellow light (next to homelink button) initially may blink slowly but after few seconds (may be 10-20 seconds) will blink fast; once it started blinking fast release from pressing both garage door opener transmitter and homelink button ;;;
07. Now plug or power on the main garage door opener motor (which is mounted on garage ceiling) ;;;
08. On the main garage door opener motor (which is mounted on garage ceiling) press the "LEARN" button (once you press it may have yellow/orange color light; make sure the light is on) ; then within 30 seconds do the next steps #9, #10, #11 very carefully ;;;
09. go to your car and press the homelink button you programmed and hold it for 4 seconds and then release it --> 1st iteration ;;;
10. again hold the same homelink button you programmed and hold it for 4 seconds and then release it --> 2nd iteration ;;;
11. again hold the same homelink button you programmed and hold it for 4 seconds and then release it --> 3rd iteration ** important note; generally three iterations are not necessary; and steps #9, #10, #11 must be performed within 30 seconds ** ;;;
12. during one of the iteration you will hear "CLICK" sound one-time from Garage door motor (which is mounted on ceiling) and if you have light attached with it; it will blink once (** if you hear the CLICK sound and/or light blinks once**) then the particular homelink button is programmed ;;;
13. now press the programmed homelink button; the garage door will open or close (but always it will take 3 or 4 blinks in yellow light or 2-3 seconds before the garage door opens or closes and which is normal) ;;;
** Thats it, your 2010 BMW 528XI Garage Door Opener Homelink setup is complete ** ;;;
You can program rest of the homelink button the same way but following from the steps between #4 and #13 ;;;
Hope this steps will help you to program chamberlain Garage door opener in 2010 BMW 528XI Homelink. ;;;
** possibly the above same steps may work with other BMW 5-series cars homelink too (but I'm not sure) **
on May 29, 2010 | BMW 528 Cars & Trucks
2012 hyundai tucson setting the garage door opener that is located in rear view mirror
Thanks filter4991;
1. Press and hold button on car's rearview mirror
2. Press and hold button on garage door opener's remote control.
3. Light on Rearview mirror will flash rapidly.
4. Release both buttons.
5. Locate learning button on garage door opener (generally this can be found by tracing the antennae to where it is attached to the unit.)
6. Press and release "Learning button"
7. Press and release rearview mirror button repeatedly until garage door opens/closes but it should work the first or second time.
Worked on Genie Intellicode and Hyundai Tuscon
Sep 20, 2012 | Hyundai Tucson Cars & Trucks
(Chamberlain 1/2 hp Whisper Drive garage door opener) the garage mounted opener will open the door, but none of the remotes now work. batteries have been changed already. Is there a way to reprogram the...
If the wall button will operate the door up but none of the devices do then look at the wall button. Find the lock button and push it for 2 seconds and then try the remotes again. This is your vacation lock. You can get a manual at chamberlain.com. Now if the door does not open or close with the remotes you can reprogram them. Press the colored learn button on the motor head and then press the button on the remote. Repeat for each remote. If they fail to program you will need a new logic board. Thanks BB
Aug 18, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
Keypad on garage door will only close if i punch in my code it won't close by hitting the enter button the temp here is minus 40 does that effect the keypad chamberlain 3/4 belt drive
Try this procedure to reactivate this feature.
Opener can be closed by pressing only the ENTER button if the One Button Close feature has been activated. This feature has been activated at the factory. To activate or deactivate this feature press and hold buttons 1 and 9 for 10 seconds. The keypad will blink twice when the One Button Close is activated. The keypad will blink 4 times when One Button Close is deactivated.
Dec 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster pro 1/2 hp wont shut in one button press
You have a door sensor problem. Either your main light bulb is burned out or you don't have one in your opener. The clicking sound you hear is the relay for the light. Both of the door sensors should have a small light that is lit. Tweak them until they are.
Jun 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Pressing remotes the door won't go u[
It sounds like you have the lock enguaged. When it is flashing it locks out all remote access. Hold the lock button for 3 seconds. The green light should go solid. On the issue of closing, it is most likely a safety eye issue. Hold down the wall button. If it closes it is the safety eyes. Holding the button overrides the safety eyes. Make sure that thelight on both eyes are both lit.
Jan 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remote garage door opener
1-800-355-3515
www.homelink.com
1. Position vehicle within 10 feet of garage door- engine off and battery on.
2. Press/hold 2 outside buttons of Homelink transceiver until red indicator starts flashing rapidly, then release button. This should take about 20 seconds. This erases any previously learned codes.
3. Press/hold remote control and press/hold button of Homelink transceiver simultaneously. Slowly move remote control from 5" away to 1" away from Homelink transceiver. Release both buttons after red indicator starts blinking rapidly. This should take about 5 seconds. I discovered that the Homelink in my TL is a bit faulty because it took much longer to accomplish this than when programming the Homelink in my MDX. My TL's Homelink may "unlearn" it's code in the future and the needed proximity of the TL to the garage door may be much closer than desired until I get the Homelink fixed.
4. Press training button on garage door opener unit until the indicator lights illuminates- this should be immediate.
5. Within 30 seconds press/hold the Homelink button for 2-3 seconds until the red indicator starts flashing rapidly. Repeat a second time. It should now be programmed. Check it by pressing the programmed button on the Homelink receiver.
6. When programming more than 1 garage door opener unit, disconnect power from unit before programming more units. By not doing this the programmed unit could conflict with the unprogrammed units commands.
Problems:
1. The Battery in the garage door remote may be too weak to program Homelink. However, the battery may be strong enough to operate the garage door. One of my remote controls had a weak battery- my system was installed today, fresh out of the box. I had to use the second remote control for the programming of Homelink on my 2 vehicles.
2. Antenna on the garage door opener unit must be hanging down, fully extended.
Oct 11, 2008 | 2003 Acura MDX
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
15 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
