Question about Maytag Bravos MTW6600T Top Load Washer
I have a Maytag Bravos washer model number MTW6700TQ. It is leaking water out of the back/bottom of the washer. Is this the pump going bad. Doesn't look like any hoses are unhooked.
jtate9
  • 68 Answers
SOURCE: Maytag MAV2755AWW Washing Machine is leaking water
It sounds like you have a leaking pump. The pump is easy to replace:
#1 Use a shop vac and pull all the water out of the drain line. This will keep you from having to clean up about 1 gallon of water off of the floor.
#2 Lift the front of the machine enough for you to get under and see.the pump just inside the front of the washer.
#3 Lift the 2 retaining clips off of the pump. This will allow you to pull the pump off of the motor.
#4 Remove the 2 clamps off of the hoses.
#5 Install the new pump into the hoses, and reinstall the clamps.
#6 With the retaining clips installed into the motor housing, install the pump.
#7 Attach the retaining clips, and set the washer back on the ground.
You have now replaced the washer pump.
If you have any questions, let me know
Please rate this solution
Posted on Jul 29, 2008
SOURCE: I need an extention hose
Home Depot sells it. With a rubber end that slips over the end of the discharge hose that comes with the washer.
Posted on Sep 07, 2008
MNfisherman
  • 11896 Answers
SOURCE: Maytag Bravos washer leaks.
Either the valves are leaking themselves or tub is leaking. Most likely the water valves.
Posted on Oct 24, 2009
hattonhall
  • 349 Answers
SOURCE: My Maytag Bravos washer is
Water shroud punctured. Do not use machine.
Highvoltage+Water risks electrocution.
Posted on Oct 25, 2009
  • 45 Answers
SOURCE: Maytag Model...SAV205DAWW leaking water at bottom
there could be 2 things that i know of
first one is that someone bended the door to much and the joint's are eather lose or out of place
the second thing is that the door sealing rubber is out of place, you need to putt it back to place
Posted on Dec 27, 2009
Maytag Bravos XL HE Leaks Adjacent to Bleach Dispenser, how do I fix this?
Fill it with water by hand and see what happens. Tape paper towels in the suspected area. Makes it easier to see. Part 2 ans: so the water is over powering the drain...that sucks. You are right, the valve is probably letting too much water out. I don't know if it is adjustable but I do know it'll probably cost a lot for an itty-bitty brass valve. If money is not a problem replace the valve. If you are a DIY'er, I'd try to use some sort of clamp on the hose leading into the dispenser and close it just enough to slow the flow down. Another idea is to open the drain up by cutting away some of the screen if it has one. A better source than me is to go to repairclinic.com and email them. They have a lot more experience than me. I did appliance repair as a side to handyman for 20 years & fixed just about everything for 50. I never had any formal training.
Jun 19, 2015 | Maytag Washing Machines
Water leaking from the bottom of my maytag bravos washer
Depending upon the age of your washer, the pump may have begun leaking
Apr 21, 2013 | Maytag Bravos MTW6600T Top Load Washer
Water pump maytag
what is your model number is then we can get started then okay
Nov 04, 2012 | Maytag Bravos MTW6600T Top Load Washer
Noisy spinning and water leak
The noisy spinning on this model washer is usually the drain pump bearing going bad which could also be a possible cause of the leak. Unplug the washer, Tilt your washer back and rest it against the wall. Remove the belt and manually turn the drain pump pulley, if it is hard to turn either way or is grinding or noisy it will need to be replaced. The leak is a little harder to find. Remove the front bottom and top panels, run the washer, stay back with a flashlight and look where the leak is. If the drain pump is bad it is likely leaking. Next check the center, bottom of the tub for leaks, if the leak is her it is likely the cause of both problems. The tub seal is leaking and has ruined the tub bearing. The tub seals and bearing would need to be replaced. Very involved job, and I would suggest you call a servicer with the expensive tools and knowledge to do the job. There is also a bearing on the bottom of the transmission which could be noisy but would not cause a leak. Hope it is only your drain pump.
Please rate this post. Thank You
Jan 22, 2010 | Maytag SAV571EEWW Washer
Maytag Bravos MTW6600T Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
