Question about Singer 6510 Sewing Machine
How do I replace the spool pin on my Singer 6510 Scholastic? Do I need to take the machine apart?
  • 3 more comments
  • sps200 Oct 10, 2010
    this is a horizontal spool pin that is connected to the inside of the machine. My machine does not have a "top lid" . It has a front portion and a back portion. It looks like I can take the back portion off, and the spool pin is attached under that.
    This is a horizontal spool pin that is connected to the inside of the machine at the top of the back portion,, behind the carry handle. my machine does not have a top lid. it has a back and front. it looks like I can take off the bottom and the back and maybe get to the pin from there, but I don't want to ruin my machine.
    my sewing machine does not have a top lid. it has a back and a front, and the spool pin is attached to the back part of the machine on the inside I think i will have to take the machineapart to replace the spool. Once I get the machine apart, how do I remove the broken spool and reolace it with the new one?
    my sewing machine does not have a top lid. It is put together with a front and back, The spool pin is attached to the inside of the back portion, next to the carry handle. I think I have to take the machine apart. How do I remove the broken piece and replaceit with the new spool?
    my sewing machine is a 6510 scholastic model. It does not have a top lid, it has a front panel and a back panel. The spindle is horizontal The spindle assembly is inside of the back panel, next to the carry handle. The assembly is one-piece molded plastic with a square at one end that has a small hole in it. The square part should go inside the back portion of the sewing machine. Your directions don't seem to match my machine.
  • 4,737 Answers
Please try this (click here). Honestly I don't have much idea, but I am only posting this link if it might of some help to you.
Good luck.
Thanks for using FixYa.
Posted on Oct 11, 2010
  • 2,272 Answers
The spool pins are the ones on the top lid.
Those are plastic, and you can:
1 Remove the top lid, and flip up lid. Then carefully remove the little clips that hold the pattern panel in place. Push the spool pins out from the bottom
2 Use a small drill bit, drill through the center, and dig them out. If drilling, only go about 1/8 inch or less, so you do not drill through the pattern panel inside the top lid
3 Try punching them out from the top into the top lid area
usually use a Moto Tool, or Dremel, very fine dental type bit, and drill through the center of them. Then you can work them out with a small tension screwdriver.
But perhaps the best is to remove the inner pattern panel and push them out the top from the bottom side.
I do suggest removing the top lid, and then undo the two springs that hold the flip up lid in place. Work on it with the flip up lid removed. Makes it easier to fiddle with.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Oct 10, 2010
    President:
  • 1,216 Answers
It's a bit difficult for a layman , and you need not to take it apart if you have mechanical aptitude.
There are a couple ways of removing the old spool pins.
These are the ones on the top lid?
3 Try punching them out from the top into the top lid area (not my suggested way, but sometimes works)
I usually use a Moto Tool, or Dremel, very fine dental type bit, and drill through the center of them. Then you can work them out with a small tension screwdriver.
No matter which approach you take, I do suggest removing the top lid, and then undo the two springs that hold the flip up lid in place. Work on it with the flip up lid removed. Makes it easier to fiddle with.
Hope this helps
How to remove broken horizontal spool pin of Singer Sewing machine model 6550 and replace with new spool pin?
It appears to be just "hooked" on according to the photo, and you can get the replacement part for $4.00 using this link: http://www.sewingpartsonline.com/spool-pin-singer-3709-sewing-machine.aspx.
However, before you go to all that trouble, you can also just use the auxiliary spool pin used for twin needle sewing which came with your machine but can be purchased from the same site for about the same price.
I don't use either -- I just put the spool in a cup behind the machine and thread from there. See? One way or another, you're back in business!
Jul 06, 2017 | Singer Sewing Machines
Where can I find a service manual for a 6510 scholastic singer sewing machine?
Service manuals are very difficult to find as manufacturers really don't want users to be have that information. However, if you search the internet, you may find some service manuals that are available from service repairmen or a parts diagram may also be helpful.
Jan 26, 2016 | Singer Sewing Machines
Scholastic 6510. Where do I oil it?
Is there a maintenance section in the manual that instructs how and what to clean? If so, does it mention anything about oil? If not, then it is likely yours is a computerized machine and may not require oiling.
Aug 15, 2015 | Singer Sewing Machines
Singer sewing machine
I'm not sure what you're asking. If you're asking how you can replace the spool pin that is on the machine, you don't need to. Just put your spool in the back of the machine, away from the sewing area on the right, and put it in a coffee cup or Mason jar, and feed the thread from there. Many owners of embroidery machines--which are just sewing machines with an embroidery unit attached--routinely do that--it tends to feed more evenly that way.
Aug 07, 2014 | Singer 6510 Sewing Machine
I have a Singer Scholastic 6510 and when the needle is going down the thread is not catching.
Remove the bobbin. Thread your top thread just as normal. Now turn the wheel toward you and watch the area where the bobbin normally be. You should notice a sharp object (hook) pick up that thread just as you continue to turn the wheel. If it doesn't pick it up then the needle and hook aren't meeting at just the right time. This will mean that your machine needs to be timed.
Aug 29, 2011 | Singer Sewing Machines
I have a singer machine. Have not used it yet. Got it out of the box by the handle and it looks like the horizonal spool pin broke off. Is this replaceable? Or is this spool pin removable If so how do...
Do you have the manual with it, refer to this to find out if the spool is removable.
if you don't have one, then go to http://www.singerco.com/accessories/manuals.html, type in your model number and click "search" to find it.
Some machines will have two spool holders so you can twin sew but as long as you have one left the machine is useable.
May 23, 2011 | Singer 6510 Sewing Machine
Singer 6510 Sewing Machine Logo
244 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
