Question about Hoover Nextra HNT 2135 Top Load Washer
Hoover 500m spin cycle
After spinning clothes still a little wet, put on spin cycle again and then the machine pumps out a fair amount of water then spins OK.
What is the reason for this
  • 38 Answers
That sounds like a broken motor couplin, slack drive belt, or worn bearings.
A repair person can determine which is it. I cant tell from here. However,
If you do this test you can eliminate one of the above. Lift the lid of the washer, hold the rim of the inner-tub and spin it clockwise and then anti-clockwise. If it spins both ways, you have a bad bearing which needs replacing.
Posted on Jun 01, 2008
Hi, My Hoover 600MB top loading washing machine is approx 8 years old. Recently it has occassionally not fully spun out - clothes still wet at end of cycle. Now it also often doesn't agitate - just...
Have a look for coins etc stuck in the drain pump or the tub outlet hoses especially where they fit onto the tub. If a coin or other foreign material blocks the water flow when draining , these machines wont spin properly.
Jul 26, 2011 | Hoover Washing Machines
My Hoover 500M top loader is very noisy on the spin cycle intermittanly. It sounds like a faulty or dry bearing, maybe when the water pump is emptying the bowl. The noise stops as soon as the spin cycle...
First I would bench check the water pump and see if it is operational or not. If it is then I would check the transmission. When it is in the spin cycle it switches to the high speed, so if you hear the grinding only in the spin cycle it could be the high speed gear.
Do you have any indication of a transmission leak? Fluid on the floor or on the transmission?
Jun 22, 2011 | Hoover Washing Machines
Hi I have a Hoover HNF7167. Machine was on a normal wash. When the cycle was finished the clothes were extremely wet. Put on a spin, still very wet, tried the drain cycle but this didn't work. I took...
Same problem here except the filter was clean. Got a new washing machine coming tomorrow. Looks like it could be the pump BUT after reading various web sites and auction sites it looks like it may also be the circuit board.
Jan 05, 2011 | Hoover Washing Machines
My wash machine wash the clothes but not doing the final spin, all the clothes all soak and wet
Handyman here -
Its possible that the door is not locking properly. If the door doesn't lock the machine will wash, but not spin the clothes dry. If you wait 15mins or so after machine is done, then set cycle to spin, it will pump any water that has dripped off your clothes out, but again it will not spin. Helps a little.
Good Luck!
Apr 03, 2010 | Frigidaire ATF6000ES Front Load Washer
Clothes are to wet after spin cycle
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler Spin cycle Siphoning Water-inlet valve Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely. Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Jan 24, 2010 | Kenmore Washing Machines
After the final spin cycle, my clothes are still wet.
Check these out:
  • If your washer spins but does not pump the water out, the drain line is probably clogged. In many washers a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that is attached to the pump or even into the pump itself. It it's in the pump, you need to remove the hoses from the pump and pull the item out.
  • To remove the item from the outer tub port, open the washer's main access panel and remove the large diameter rubber hose that connects the pump to the bottom of the outer tub. Using a needle-nose pliers, try to grab and remove the stuck item through the port.
  • Check your washer for a frozen pulley. Remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely, it's frozen, replace it.
  • If the water that pumps out of the machine goes back after the spin cycle, your washer is siphoning the water from a laundry tub that has a slow drain back into the washer. The usual remedy for this is to improve the draining of the laundry tub.
  • Also check for these problems:
  1. If the drain hose reaches more than 4 inches into the laundry tub, cut the excess.
  2. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Aug 21, 2009 | Hoover HTC243 Top Load Washer
Blocked filters/dodgy pump?
The problem you are having could simply be the inlet valve.
The inlet hose is attached to the inlet valve on the machine. Where it screws on that is.
You can get a valve from an appliance parts shop and they are inexpensive.
Jun 18, 2009 | Hoover HTC243 Top Load Washer
Clothes wet at program finish
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Apr 01, 2009 | Bosch Washing Machines
Hoover Saver 1300 Washer Dryer - drum not emptying fully
There is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles.
It is possible that this pump isn't working properly. I think if it weren't working at all, you wouldn't be able to get beyond the wash cycle.
It has been my experience that small articles of clothing may get washed or spun out of the inner tub and into the area around the pump pick up, thus partially blocking the flow to the pump.
It's also possible that the drain hose from the pump to the drain may be partially clogged.
It is also possible that the pump doesn't run sufficiently long to get all of the water out because its' motor gets hot and shuts down or because of a problem in the control mechanism which manages the the starting and run time of the pump.
First, I would unplug the washer from the wall outlet and probe under the inner tub, or possibly remove the tub to see that there is no blockage from clothing.
It's also possible that things left in clothing pockets like paper clips, small plastic items, etc. can get into the pump and lock up the impeller.
If you're sure it isn't blocked you can then run a "short cycle", no load and water only, and watch to see how much water comes out of the discharge hose where it's hung on the drain pipe.
It should gush out, and tub should be free of standing water prior to the start of the first rinse cycle.
If it does not, then you'll have to access the pump and clear it of obstructions or replace it, if defective.
As it drains, it should start spinning slowly, then speed up as it drains; the final portion of the spin cycle is very fast.
Essentially, the spinning tub wrings out the clothes using centrifugal force.
With the water remaining in the bottom of the tub, it would appear that it is:
a) not spinning long enough, or
b) there is something preventing all the water from getting out in the time allotted by the timer to perform this task.
A fair handy man can get to pump either from the rear of the machine with back plate off, or by removing the cabinet cover from the frame, depending on the model of the the machine.
As always - before attempting any repair, UNPLUG THE UNIT!
When clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 18, 2009 | Washing Machines
Clothes too wet
Watch the washing machine go through its complete spin cycle.(It could have a filter in the pump,check for water flow coming out of the drain. Make sure the washing machine is fully leveled with a square. make sure you put fairly big loads to keep it balanced. If the washing comes out wet on the final spin ,add some more garments and then put it on spin again as the w/m might be going out of balance. Under the work bench on top some times there is a spring to adjust the tension. about every five or six years the motor brushes need changing.
Jan 04, 2007 | Bosch WFL 2463 Front Load Washer
Hoover Nextra HNT 2135 Top Load Washer Logo
622 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
