Question about OKI B4600n Printer
Error message 173,what shoud be the problem please
Shows an error 173
Error 173 is an upper heater temperature. It usually points to the fuser unit
Power the printer off, make sure the printer is plugged directly into the wall outlet not a surge protector also remove the fuser unit and reseat. If the error 173 message continues, the fuser unit will need to be replaced.
Apr 12, 2016 | OKI B4600 Printer
What is error 173
173: Error
177: Error
Thermistor indicates
Low Temperature
(COLD) Error.
Turn ON power again.
Leave in that state for 30
minutes then turn ON power
again.
Jun 11, 2014 | OKI B4600n Printer
Code 173 for oki c5500
Service call 172:Error & 173:Error
Both errors mean -
Abnormal temperature detected by fuser thermistor (high-temp or low temp.)
Does error reoccur?
YES -
Turn power ON again. Replace fuser unit.
Jan 19, 2011 | OKI C5500n Printer
OKI B4350 error 173
That is a temperature error with the fuser, most likely the thermistor. Really the fuser needs to be replaced. Hope this helps.
Feb 22, 2010 | OKI B4350 Laser Printer
Error 163 173 ibm 600e laptop when turned on these errors occur
this error is the battery by the sound of things, you need to replace the cmos battery , then enter the configuation utlity and set date and time, hope this helps
Nov 29, 2009 | IBM ThinkPad 600E 2645 Notebook
Hi I have a Oki c6100dn Printer with fatal error message 173, How can I fix that
unfortunately, a 173 error is a fatal error which requires service, or technical skill on your part. It usually involves replacing the power supply board and fan.
Jan 27, 2009 | OKI C5100n Laser Printer
Fatal Error Code 173 - OKI 5100 copier
173 is a fuser upper roller low heat error.
Nov 19, 2008 | Office Equipment & Supplies
Error Code 173, 192, 163
That error means low temperature on the heat roller. The thermistor (something like an electric thermostat) measures the amount of heat needed to work. Error 173 refers a lower temperature than required, while error 172 refers overheat. The complete error list will be of no use to you, since most errors will refer you to an authorized service center
May 22, 2008 | IBM ThinkPad 600X Notebook
Service Call: 173: Fatal Error
That is a fuser erron code. Abnormal temperature. You will need to replace the fuser. Sometimes I have sen a buildup of toner on the thermistor. If you can get to it. You can try to clean the toner off. Be careful. Very hot.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 10, 2007 | OKI C5150n Led Printer
Printer Fixing Error- Replace Fixing Unit
You need to replace the fixing unit. It costs $120 and replacing it is not a trivial job. You may be better off buying a new all-in-one (not necessarily an HP). I've had good luck (so far) with Brother.
Nov 09, 2006 | HP LaserJet 3150 All-In-One Printer
OKI B4600n Printer Logo
54 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
