Konica 7050 error code f-35
Hi, can someone help me reset this code? A step by step walk through would be great as I don't know anything about fixing it.
Thanks!
F-35 is a fixing unit related problem... resetting wont do you any good if there is a thermistor/heater lamp/thermal fuse related problem. make sure all these are good. otherwise you wont be able to reset that code...
Posted on Jun 02, 2008
Konica minolta 2300w change toner
You will find the step-by-step procedure on the following link, on the page 57 (48)
http://printer.konicaminolta.net/drivers/manuals/2300w/user_es.pdf
If you need anything else, let us know.
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 21, 2014 | Office Equipment & Supplies
F-35-4 this is over problem
Fuser error: lamp, thermistor, fuse problem, etc. Part needs to be replaced and code reset in service mode only. Call a tech
Jun 20, 2009 | Konica Minolta DiALTA Di200 Copier
I have a Konica 7033 copier with error code F-35-2
Access the 25 mode (power the machine ON, while pressing the 2 and 5 keys).
2. Press [1: Software SW].
3. Select software dipswitch 3-1 using the arrow keys.
4. Set the switch to OFF (0).
5. Press [Return] to end the setting.
6. Power the machine OFF/ON to exit the 25 mode.
good luck
May 04, 2009 | Office Equipment & Supplies
KONICA 7020 GIVES ERROR MESSAGE F-35-1O WHAT IS WRONG
hi
error f 35 is fixing error,try to reset on 25 mode
Jan 08, 2009 | Toshiba E-Studio 3511 Color Copier
Error code
Problem: The Digital Panel is Reporting Code 34-1, 34-2, 35-1, 35-2 or 36-2 Cause: The copier is having a problem with the fusing unit.
Solution:
  1. This is occasionally a false alarm. Try turning the copier off for about 10 seconds and turning it back on. If the code doesn’t clear, please call 1-800-877-2679 for service.
Sep 02, 2008 | Office Equipment & Supplies
Error code f35
konica f 35 eror code
Aug 06, 2008 | Office Equipment & Supplies
Konica error code
F-35s are fixing unit problems in alot of Konica's.Need model to know for sure.
Jul 18, 2008 | Office Equipment & Supplies
Error code f-35-8
On most Konica copiers, an F35 error indicates:
1. low temperature of the fuser; and/or
2. open lamp; or
3. open thermo wire fuse; or
4. open thermistor; or
5. or anything heat related at start or warm up.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 19, 2008 | Office Equipment & Supplies
KONICA 7030 F-35-7 CODE
F35-7 is a low temp abnormality in the fixer.
To reset you need to enter the '25' mode and go to dip switch 3 - 1 and reset this to 0.
This should reset the code. ( dip switch 3, 1 to 7 control the high/low temps for the fixing unit i believe they should all be 0)
Hope this helps.
Apr 24, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Error F-35-4
problem konica F-35-4
Oct 15, 2007 | Office Equipment & Supplies
276 people viewed this question
jasbo
jasbo
