Question about John Deere 4020 Gas & Diesel Tractor Radiator
My 2305 John Deere won't start. The battery is good, but it won't turn over---just clicks. Charger didn't help. Checked the fuses--any ideas?
5 Suggested Answers
  • 73 Answers
SOURCE: My John Deere 325 won't won't start. Replaced the
I know this is going to be hard to believe but you have either dirty / loose or coroded cabels if you jump it from the car and it strarts then the only thing you are doing is appling power to the outside of the battery connection the inside is not making contact with the battery post clean with a wire brush do both poles apply a no corode paste tighten bolts snug they're made of lead and bend easily so don't over do it Good Luck Bruce depending on where you live you may want to greese up the snowblower too :-)
Posted on Oct 12, 2009
Testimonial: "That was it! I cleaned up the neg cable. Put it back on; it started right up. I do use it for snow removal (NH) and that is coming soon. Thanks!"
wireguy212
  • 1627 Answers
SOURCE: 2305 john deere, idle runs slow in full idle.
Look at the fuel filter bowl on the rear of the engine right hand side to see if you can see a red ring raised up slightly from the bottom of the bowl.If you can see the ring then there is water in the fuel[or ice by now]You will need to take of the filter and get the water out of the filter bowl by taking it indoors to thaw.Before removing the filter bowl,turn off the fuel,petcock is just above and to the rear of the filter.Once the water is out you then need to clean the bowl out and re-install with a new filter.Pick up a product called "diesel melt" at the dealership and add it to your fuel for the rest of the cold season{follow the instruction on the bottle}.If this is not the case then the linkage on the injection pump may need to be adjusted to get the rpm up to no more than 2450 rpm..
Posted on Jan 11, 2010
  • 13 Answers
SOURCE: john deere lane rider la135 wont start.
You don't mention if they are on and are bright or are week. Do they dim when trying to cranks the motor? I would start with checking the ground wire at the battery and where it connects to the frame. Make sure both are clean. From there, have the battery tested and then the starter.
Posted on Jun 10, 2010
  • 6468 Answers
SOURCE: my john deere 2305 was running fine. I went back and started it and it just clicked. I checked all the positioning and it was fine. I installed a new battery and still nothing. I talked to a John
check the safety switches make sure you didn't leave the blades on
Posted on May 19, 2012
Solenoid 2305 john deere
When bolting it on, be sure good and clean. Its your ground for solenoid.
Jul 26, 2014 | John Deere Garden
John deere d110 clicks but won't start
Starter solenoid. 10 bucks. just fixed mine, exact same problem.
Nov 09, 2013 | John Deere D110 19.5HP Single Cylinder...
I have the John Deere Turf Tractor and it will not do anything. I have checked all the connections and had the battery and charger checked. All these things are fine. What else could be the problem?
What is meant by anything? No crank, no start, no go??? If battery has charge and nothing is happening, check fuse then go on to switches. A multi-meter and/or a test light should send you to the right area pretty quickly.
Sep 24, 2013 | John Deere 420,1020,2010,2020,2510,2520...
Have john deere gator cx it won't start, I have
My older cx won't even turn over.. Totally dead..
lights work so ignition system ok..
battery is new and hot..
fuses all ok..
Stated and ran fine through two pastures.. Turned off to fix fence..
now not a peep..
Aug 18, 2013 | John Deere 420,1020,2010,2020,2510,2520...
I have a john deere LT 150 that will not start. When you turn the key nothing happens. I've checked the seat switch , the mower engage switch and a new brake/clutch switch. Battery is good. You ca
you have a safty switch problem you have 4 to 6 switchs the easest way to test them ,startin with the seat get a ohms metter they are open or noramly closed
Oct 23, 2012 | John Deere Garden
John Deere 4020 Gas & Diesel Tractor Radiator Logo
990 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
