Question about GPX MW3337G
Changing from mtp format to usb
When I plug in the usb cable it still shows up as mtp. How do i get it back to usb?
  • 1 more comment
  • timmyderselt Jul 08, 2008
    yea i have the same proplem some times my computer reads it as mtp and other times as a usb divice
  • roxiebaby Jul 24, 2008
    i have the same problem but i pushed to button it did not work
  • Anonymous Aug 31, 2008
    i have a Bush mp3 player, and for soem reason its switched itself to MTP. Its never done that before, how do i get it back?
    Problem Solver:
  • 8 Answers
My model is the mw3337 and I press on the blue button, the one that you press to select whether your songs play randomly, repeat 1 or repeat all, that switches from mtp or usb.
Posted on Jul 10, 2008
Sansa e250 MP3 Player: won't play any music or change to any other format...
Hope this helps. See the section about the hot fix first----- If you are using Windows XP: you need the following. Windows XP SP2 or higher Windows Media Player 10 or higher Download and install the latest Windows Media Player if it's not installed. If you are using Windows Vista: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. Download the hotfix from-->>> Run the hotfix. Refresh the players driver Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Check under Device Manager 1. Right-click My Computer, and select Manage. 2. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are Sansa Connect and Sansa Express which only use MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Instructions to connect in Forced MSC mode are listed here: Instructions to switch player to MSC mode are listed here: If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the Sansa firmware NOTE: Sansa Express and Sansa Connect do not have MSC mode. For Sansa Connect you can try reinstalling the firmware using the Connect Recovery Mode. Additional troubleshooting notes: If you have replaced the Sansa Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting. - Try connecting on another computer. - Try using a different USB cable - Try connecting to the back USB ports which may supply better power. - If only MTP mode is not working, try reinstalling Windows Media Player For Windows XP try also download and install the MTP Porting Kit ........
May 16, 2010 | SanDisk Sansa e250 MP3 Player
Mp3 player malfunction
1. Try updating the drivers-
- Right click "My Computer", choose properties
- Click the hardware tab and choose Device Manager
- See if you find the name of the device there - if yes, Right click on it and choose "Update Driver"
2. Try changing the mode to MTP
3. If nothing works, unplug the USB cable, Lock the device, Push the round button in the middile of the Sansa player, continue holding it and plug in the USB cable.
4. One more option you could try -
  • turn off your mp3
  • press the hold(lock)button down to activate it.
  • press the center button and keep it pressed ..
  • connect the USB cable supplied with the device always pressing the center button,
  • connect the other end of the cable to a USB jack on your PC.
  • From there it should work properly.
Dec 14, 2009 | SanDisk Sansa Clip MP3 Player
Sansa view is no longer recognized when plugged into USB port
Solutions are in order of increasing probability of data loss AND device recovery.
Screen messages are loose approximations
A Soft Reset
1. Hold Power switch up for 5 seconds.
2. Screen displays "Goodbye".
3. Restart
B. Hard Reset
1. Hold Power Switch for 30 seconds
2. Restart
C. Recovery Mode
1. Hold Power Switch for 5 seconds to switch device Off
2. Move switch to Hold
3. Press and hold Home button
4. Connect USB cable to device
5. Screen displays "USB" in small type and "16 MB Format" shows up in My Computer
6. Copy firmware files to "16 MB Format" drive letter
7. Disconnect USB cable
8. Screen displays "Firmware update"
9. Restart device
C. Force Format (This one wipes the data partition. Make sure all needed music/pictures/video exist elsewhere)
3. Press and hold top/North/up of Scroll Wheel
5. Screen displays "Format and lose data"
6. Press right/East on Scroll Wheel to confirm
7. Screen displays "Formatting"
8. Restart device
D. Manufacturing Mode (included for completeness only)
3. Press and hold centre of Scroll Wheel button
5. Windows detects a new hardware device
6. ???
7. ???
8. ???
Sep 07, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
XP not able to download songs onto MP3
When using XP and media player 10, your mp3 player has to be in MTP mode to transfer music, you can't do it in USB mode. If you have already tried in USB mode you'll be beter off clearing the memory and starting over (you'll have to reload your music after you are done).
  1. Plug the player up to the computer using the USB cable.
  2. Close out any pop ups that open. If they won't close ignore them until you are finished.
  3. Double click the My Computer icon on your desktop.
  4. When that opens find your player under Removable Devices or Audio Devices. Some computers will show your player twice but will have the SD MMC card showing behind the player name. That is only for formatting the SD card.
  5. Right click once on the player to open the Options menu and then click on Format
  6. Click OK to any warnings that come up. There may be one or two depending on your operating system.
  7. Any memory will now be erased from your player and you can disconnect from the computer.
  8. Reboot your computer and plug your player back in.
  9. When you see USB appear on your players screen, press and hold the M button until MTP appears on your screen.
  10. Reload your music
Sep 05, 2009 | GPX MW3836 MP3 Player
How do i free 8mb in Sandisk Sansa M250 i formated but the same result happens plz help me!!!!
SanDisk tech support recommends formatting the m200 series in both MSC and MTP modes to completely clear out all work areas,"fragments" and residual data. The m200 has a very basic Operating System that doesn't have a defrag option. According to tech support, the m200 needs formmating occasionally to keep it working smoothly. I learned that formatting will also clear up intermittent hang-ups. I format mine each time I reload it.
Format in MSC Mode
With the m200 not connected to the PC, power it on, press the menu key. Select "Settings", then USB, then MSC.
Connect the m200 to the PC via the USB cable
Right click on the "Start" button.
Left click on "Explore"
Find the m200. It will show as a hard drive, for example: "SANSA M250"
Right click on the m200 device and select "Format"
After formatting is complete, click on the "Safely Remove Hardware" icon on the System Tray and stop the device
Disconnect the m200 from the PC.
Format in MTP Mode
With the m200 not connected to the PC, power it on, press the menu key. Select "Settings", then USB, then Auto Detect.
Connect the m200 to the PC via the USB cable.
Find the m200. This time it will not show as a hard drive but as a music device, for example: "SanDisk Sansa m250"Note there is no drive letter in MTP mode.
After formatting is complete, disconnect the m200 from the PC. There is no icon to stop the device.
Your m200 device is now formatted and ready to reload.
By the way, MSC mode is mostly for use with other than Windows XP computers. If you are using WinXP and Windows Media Player 10, you might consider using MTP mode and WMP to manage the m200's.
If i was helpful, kindly do Rate!
Jul 28, 2009 | SanDisk Sansa m240 MP3 Player
Samsung YP-U3 not recognised. This device cannot start. (Code 10)
  1. Connect the USB cable to your computer.
  2. Press and hold the menu[0].jpg button while plugging the other end of the USB cable into the YP-Z5.
  3. When the display shows USB Connected, release the menu[0].jpg button.
  4. The device is now in USB mode.
  5. When through, you must safely remove the USB device. Note: To safely remove the USB device, right click the USB icon ( usb_icon.jpg ) in the bottom right of your screen, and then click Safely Remove Hardware.
  1. Upon disconnecting the device, it will return to MTP Mode.
Dec 12, 2008 | Samsung YP-U3 MP3 Player
Hung in a transfer loop after being removed from PC
When I (USB) plug in my RCA Opal M4002A mp3 player into my "Office PC" it works fine, but when I plug it into my "Studio PC" the "Opal" screen shows "USB connected" and so does the "PC" with the "Device Connected Sound" but then the "Mouse Pointer" changes to the "Hour Glass" you hear the "System Notification Sound" then the "Mouse Pointer" changes back to the default "Arrow Pointer" and this back and forth action loops endlessly until I unplug it. I've tried everything. Any ideas would be greatly appreciated. Thank You, Quaal
ALSO I HAVE THE "RCA Opal M4002A" (2GB) mp3 player.
*** After much trial and error this FIXED my problem. ***
1 - First right mouse click on "My Computer".
2 - Left click on "Properties"- Left click on "Hardware"- Left click on "Device Manager".
3 - Now with one end of the USB cable plugged into your mp3 player, plug the other into your USB port. (Now when I did this a new "Portable Device" icon with an "MTP" Driver (sub icon) showed up in the "Devices List". (The "MTP" icon had an "!" on it, telling my it wasn't working properly. I then did this.
4 - Right click on "MTP" driver icon, then ...
5 - Left click on "Update Driver". (I was then given two choices. The top one was the faulty "Portable Device" driver which I had done everything I could to fix, but nothing worked. So I then did this ...
6 - Left click on the "Mass Storage" Driver (the second choice below it in the list), I then clicked "OK". The "Updating Driver" screen showed for a moment. The "Portable Device / MTP Driver(!)" icon vanished from the "Device Manager" devices list, But the looping STOPPED!!! My Opal was working beautifully and showing in my "Root Directory" as Drive j: and in "Device Manager" under "Disk Drives" as "Thomson Opal USB Device".
P.S. For some reason the file transfers are noticeably faster now. Good Luck, Quaal
May 21, 2008 | RCA OPAL M4001 MP3 Player
Blocked Iriver X20
Yes, try running a format from your computer to the IRiver with it plugged into the USB port. I have done this with several friends MP3 players and it works great. In other words plug your MP3 player into your computer as you usually do and from windows or dos in your accessories run a regular format of the MTP portable device or whichever drive dos says it is. Then presto you can again load music or whatever your MP3 player take into it again.
Jan 14, 2008 | iRiver X20 MP3 Player
My understanding, as a new user, is that IRiver plus 3 only communicates with the player via UMS mode, which is not the default. Windows Explorer and Windows Media Player only communicate through MTP mode. If you change from MTP (the default) to UMS, it will reformat the player and delete all your files.
In other words, do not use iriver plus 3 unless that is the only software that you want to use. Boing back to MTP mode after a sync or download will then delete all THOSE files you just downloaded.
I just say NO to Plus 3.
Good luck.
Dec 30, 2007 | iRiver Clix Digital Media Player
Sandisk Sansa View 8GB = would not connect
I jsut purchased an 8GB sansa view mp3 and I downloaded it like I was suppose to and it does not work in Rhapsody at all, also in the windows media player it shows that the device was installed correctly but it still doesn't work and I still can't sync my songs to it. The sansa icon won't even show up
Dec 26, 2007 | SanDisk Sansa View 8GB MP3 Player - Black
GPX MW3337G Logo
605 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
