Question about KitchenAid KDRP407HSS Dual Fuel (Electric and Gas) Kitchen Range
Kitchenaid KDRP 407 oven does not work and reads F02. Cannot be reset except by turing off breaker. After turning off breaker, it appears to work but eventually again yields F02.
3 Suggested Answers
  • 31 Answers
SOURCE: Kitchenaid Oven works great but won't turn off
Replace the touch pad.
Wigo.
Posted on Mar 04, 2010
  • 1891 Answers
SOURCE: we lost power in our
there is no reset but do ck the house fuses . even if they look ok turn them off aand back on . then sk the range for power . if the clock runs the oven you may have a clock failure . also ck the power cord behind make sure is pluged in .. hope this helps mm feed back pls ..
Posted on Nov 16, 2010
Gas kitchenaid gas stove code F02. Turned off breaker seemed to cool down at first now getting warmer. Can't open oven door, like it is cleaning. What do Ido now?
Shut off the breakers and GAS make sure the oven has completely cooled... This may take a significant time
without the aid of the cooling fans...
While you are waiting the requisite HOURS....
Look up your model number on reputable parts sites..
I will list below.
The most likely failure point is a simple heat sensor... (thermal switch" which SHOULD HAVE released your door IF INDEED it
was cool enough (this is VERY critical).
My KGRS807SSS00 Model Overview from PartSelect com
http://www.appliancepartspros.com/
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Don't hesitate to call KITCHAID themselves...
They ARE SUPPOSED to be GOOD....
I DISAGREE... but that just my opinion... as a
disappointed OWNER of their "STUFF"
ServiceBench
Dec 26, 2016 | KitchenAid Kitchen Ranges
My kitchenaid kgrs505xss oven says feature not available
I had this problem. Turned off the circuit breaker about 5 minutes. When breaker turned back on, was able to reset
Apr 15, 2012 | KitchenAid KGRT607HBS Gas Kitchen Range
I ran the upper oven cleaning cycle and now it doesn't heat or broil. I have tried the reset of turing onff the breaker for 30 minutes and that did not work.
CHECK THAT YOU HAVE 220 AT THE PLUG OR POWER CONNECTIONS. TURN OFF POWER AND CHECK THE CONNECTIONS TO THE ELEMENTS MAY HAVE BURNED . IF OK AND NO VOLTAGE THEN CONTROLS.
Mar 11, 2010 | Dacor ECD230 Epicure Electric Double Oven
I was cooking in my Kitchenaid oven and the door locked. It will not unlock
We had the same thing happen
Turn the oven breaker off, then let the oven cool completely. Turn breaker on, there will be an error code appear, push and hold the "bake" button for at least one minute until an error message appears, then press the off button.
This reset the latch on our oven
Nov 02, 2009 | KitchenAid Ovens
F6E0
Last night I saw the lights in the house flicker momentarily... This morning, I turned the oven on, set it to Bake and within a few seconds, the control panel reported error code “F6 E0” then shut the oven off. The control panel also reported "Lost communication...". I read on another site that this code may require replacing the control panel itself. Apparently, the momentary power fluctuation wasn't large enough to damage the electronics (since the control panel still works), but was significant enough to confuse the electronics controlling the oven. To fix the oven, I simply turned the 30 AMP breaker for the oven off for about 5 minutes. When I turned it back on, the oven worked just fine. Solution #1 recommends taking off the control panel, which voids the warranty. It's more likely that it was fixed just by cycling power to the oven via the breaker.
Oct 27, 2008 | KitchenAid Architect Series KEBC107KSS...
KitchenAid KERA807PSS01 oven won't shut off until breaker thrown
assuming its a stainless stell oven? if so heres the par tyou need its a membrane switch( your cancel button ceased to operate corrrect???not a bad part to install you need to remove a few screws from under control panel itself( perhaps a few on the sides, the front control will lift off and this part is installed from behind the control panel (SHUT THE BREAKER(S))
part number 9756595ES
in the mean time instead of shuttin off the breaker toreset you can simply( requires reading manual ) set your oven to time bake. it will shut off automatically after predetermined time has been obtained.
Apr 27, 2008 | Ovens
Kitchenaid Oven KERA807PSS01
perhaps you would like to visit this site and read what others have to say about it.
It's not pretty.
Apr 06, 2008 | Ovens
Kitchen Aid ovens - error codes
The F-3 error code typically means you have sensor problem. The sensor is usually mounted in the oven space up near the top of the unit. The first thing to do is turn off the circuit breaker to the oven. Do you have an ohm meter? I suggest if you don't to purchase one. They are relatively inexpensive. Maybe you can borrow one from a friend. Disconnect the sensor from the electronic control and measure the resistance. There should be a wiring diagram in the top of the unit that will help you to locate the sensor wires. Most sensors should read around 1100 ohms at room temperature. If sensor reads as an open circuit or has a very high resistance, it must be replaced. If instead it reads very low, then there is a short in the wiring. Some units have a fuse in series with the sensor. Check to see that the fuse has not blown.
May 02, 2007 | KitchenAid KEMC378 Electric Double Oven
KitchenAid KDRP407HSS Dual Fuel (Electric and Gas) Kitchen Range Logo
344 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
