Question about Campbell Hausfeld Air Tools & Compressors
Why do I lose pressure while spraying. The air comes and goes. I have to wait for the pressure to build back up to spray again.
  • 4,336 Answers
Well, either a system leak or your compressor does not have the capacity for the air usage of the gun. Spray guns have high air consumption.
Posted on Oct 10, 2010
New pump-pump works fine for 2 seconds--loses pressure--spray goes from 10-12 ft to zero...wait for pressure to build back up and works fine for 2 sec....start over....pump unusable like this
Air leak somewhere between the pump and the spray tip (s).
that will incllude the 25 gallon tank as a possible place to check for leaks!
Apr 15, 2015 | Flojet Pump D2131I5011A
My 55ld520 screen goes black, turn off for short time comes back on but then goes black again.
Start simple by using different cables, whether they be HDMI, VGA or standard COAX cables. They could be losing the connection. Also, it's possible the power supply is wearing out and it gets too hot. You might want to simply try some spray air duster type thing to clear out any dust that can make it hot.
Sep 20, 2014 | LG 55LH40 55 in. LCD HDTV
Starts then dies & won't restart
check fuel pressure, should be 40 psi.
try 2 things
spray starting fluid in air intake to see if it will stay running. It's fue then.
Try turning key to on nd wait 5 seconds for system to build pressure and pump to shut off. Turn key off, wait for relay clcik noise or 10 seconds. then turn key to ON again and wait 5 seconds to build pressure again. Then start engine. If it starts better, you have a bad check valve in the fuel pump or a bad pressure regulator on the fuel rail (unlikely).
report back
Aug 22, 2011 | 2005 Ford Expedition
How to remove the Prime/Spray assembly on the Wagner Paint Crew. The Prime/Spray knob is held on by a retaining clip which I can't figure out how to remove without resorting a hammer and pry bar and risk...
You can unscrew it without removing the plastic part - just use thin vice grips and get a piece of the metal nut, unscrew down (counter clockwise) and it should come off with average pressure. I checked mine, not much to go wrong there, then screwed back in. I have similar problem with pressure, it is likely a worn O ring. Seems to be in the outlet valve as I replaced some of the inlet valve rings and same effect. Research says the outlet valve is the problem if paint comes out of the squeezed nozzel while in Prime mode, which mine does, and is likely not building the pressure as some paint is flowing back through the worn outlet parts.
Aug 06, 2010 | Wagner Power Products 0154842 Medium Spray...
Not enough pressure coming out
Usually this mean's you have lost pressure from one of the three cylinders. When you let off the trigger, the other 1-2 cylinders build pressure, as soon as you begin flow, then you're only running on 1 or 2 cylinders instead of three. This is usually caused by clogged check valves. It can also be caused by a faulty pressure regulator.
Jul 19, 2010 | Campbell Hausfeld 2000 Psi Gas Pressure...
Hansgrohe 06566860 Metro Single Hole Kitchen Faucet periodically makes noise and reverts from needle spray to full spray by itself. Have to press on needle spray indicator on top of sprayhead 4 or 5 times...
make sure the hose under the sink, ( the one that goes to the faucet) has not gotten twisted around anything. sounds like it is losing pressure. it takes steady pressure for the stream to maintain that "needle" spray.
Feb 15, 2010 | Hansgrohe 06649860 Solaris Single Hole...
Air is coming out but no primer
  1. primer viscosity to thick
  2. internal filter clogged
  3. internal passage clogged
  4. gun not adjusted properly
  5. high build primer uses more air pressure
  6. wrong needle and fluid nozzle
  7. gun needs cleaned
Aug 07, 2009 | Vaper 4 Piece Set 3 Gravity Spray Gun +...
Pressure washer has no pressure
Try and back flush the washer..Take spay nozzle off washer and back flush with hose...If any kind of sand or deposits get into the Pump it will hold pressure valve open not letting it build pressure.after back flushing hook back up washer and before you put spar nozzle back on or start washer turn water on and make sure all air is out of washer..hook spray nozzle back up and hold it open with washer still off.when you see that there is no more air coming out of washer start it and you should have pressure.Hope this helps you and have a great day!!
Apr 05, 2009 | Garden
Losing water pressure in pump?
Shellybabe, these GE dishwasher pumps have a habit of sticking when not in use for a while. It sounds like you have been washing but not good. If you remove the toe panel (lower) you will see the pump motor in the center. If the vanes in the back center of the motor turn freely, your pump is not stuck. If they wont turn, put pressure on them until the pump frees up. You also want to make sure that the fill valve is letting in enough water. The water should be just below the heating element after the initial fill. If you are not sure try adding 2 addition quarts of water to the machine after the initial fill and see if the circulation is better. Remember to unplug or kill the power to the dishwasher when checking the motor vanes...Catriver..post back.
Oct 31, 2006 | GE 25 in. GSC3200Z Free-standing...
Air Tools & Compressors Logo
365 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
