Question about Rheem RTG-53PVN Indoor Natural Gas Tankless Water Heater for 1-2 Bathroom H
My Rheem tankless water heater model RTG-95DV will not ignite, my remote gives a error code 11. I checked the gas valve it is opened all the way, I can also hear the igniter clicking. Looking at the circuit board there is a LED light it will start flashing when I try to start the heater it continues to flash after the heater is shut down, what is this light for?
  • 244 Answers
SOURCE: Rheem Tankless wh model rtg-74pvn shuts off error code c4 76
Contact Rheem; the Burner control unit has lost comm with the remote...the part is warranteed for up to five years.
Posted on Nov 01, 2009
  • 244 Answers
SOURCE: Rheem water heater turns off by its self
Flashing code 76 is lost communication between the remote and the burner control assembly CCA (circuit card assembly). The CCA is still under warranty if purchased within the last 3 yrs. Contact Rheem customer service and have your Mod. and S/N available....explain to the agent you are recieving - flashing code 76...they'll walk you through the process.
  • 244 Answers
SOURCE: How do I delete the stored error codes on my Rheem
Some error codes cannot be reset...Example would be P/S failure on the PCB. Any other error, if you remove power for approx. 2 min - error should clear. - if not you need to contact Paloma/Rheem customer (800-432-8373) support
Posted on Nov 24, 2009
  • 244 Answers
SOURCE: I have a 1L error code. Can you help?
Hi stevenandarl,
Contact Paloma/Rheem customer (800-432-8373) support; tell them the code you are displaying. Rheem will send you instructions via email if you feel you can perform this operation yourself. Or they will recommend a professional in your area to help you.
Mike...
Posted on Nov 26, 2009
  • 68 Answers
SOURCE: Can't find manual & have a C7 error code.
need to contact rheem what you can do until then is remove the control wire it will run until parts ship out
Posted on Jul 31, 2010
Rheem Integrity 20 not always lighting. Showing code C2 11
Before calling service technician, open following links for Rheem/Paloma troubleshoot resources including error codes:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/pdf/No-Error-Code.pdf
C2 11 is no ignition.
Clean combustion parts yearly as recommended in manual is first step.
Other causes can be loose wiring, bas gas valve, dirty air intake, bad venting, bad sensors etc.
Test these parts using service manual. Call Rheem since Rheem does not post service manuals.
Oct 06, 2011 | Rheem Tankless Hot Water Heater...
I am getting a C2 11 code on my eco sense tankless water heater. There is also a flashing 24, any ideas? Thanks
Multiple error codes can mean PC board failure.
Error 24 is malfunction of operational switch: "press max or mim button on PC board, or replace PC board." On some models, max and mim button can be located just above dip switches, and rotates with screwdriver. See diagram in manual.
Before calling service technician, open following links for troubleshoot resources including error codes, Rheem chat, and possible manual.
http://waterheatertimer.org/pdf/ErrorcodeTroubleshooting.pdf
Aug 10, 2011 | Rheem EcoSense by 7.4 GPM Tankless Water...
Code 11
Before calling service technician, open following links for Rheem troubleshooting resources including error codes.
Error codes are considered start-point for troubleshooting.
Error 11 is no ignition.
This problem can probably be solved by routine yearly maintenance shown in instruction manual which recommends: Yearly cleaning, adjustment and inspection of burner and combustion parts.
The yearly maintenance would check incoming gas supply, venting, wiring and grounding, and burner and ignition parts.
All gas water heaters today require same maintenance: tankless require yearly, and tank-type require periodic (1-3 years)
Jul 03, 2011 | Rheem Tankless Hot Water Heater...
No hot water. Constant beeping at the tank. Tempature gauge flashing 11.
Before calling service technician, open following links for Rheem troubleshoot resources including Rheem chat and typical service manual and typical product manual.
Error codes are start place for troubleshooting:
Error 11 is 'gas is inadequate' or 'ignition failure'
Open gas valve so handle is parallel with gas line.
Bleed air from gas lines.
Check that appliance is grounded.
Check igniter wires and harness for damage.
Check that vertical vent length does not exceed limit.
Other causes: Gas inlet solenoid valve, bad igniter, solenoid valve, flame rod.
Jun 14, 2011 | Rheem Tankless Hot Water Heater...
Remote flashing Code 11
Before calling service technician, open following link for Rheem troubleshooting resources:
C2 11 is: "inadequate gas.
Open the gas shutoff valve all the way"
Another source for error 11 shows: "no ignition"
"Ensure you have gas to the appliance.
Ensure gas type and pressure are correct.
Bleed all air from gas lines.
Ensure gas line, meter, and regulator are sized properly.
Ensure appliance is properly grounded.
Check gas solenoid valves for open or short circuits.
Ensure igniter is operational.
Check igniter wiring harness for damage."
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 02, 2011 | Rheem Tankless Water Heater Main Remote...
C2 11 code
Before calling service technician, open following link for Rheem error codes and troubleshooting resources:
Error code C2 11 is 'no ignition'
There is no service bulletin covering how to perform these actions.
Rheem will ask that you call qualified service technician, who can give you tips and tricks for keeping the unit working, including opportunity for yearly service that will eliminate the expected $1-8 monthly savings from owning tankless.
Read manual for yearly maintenance needed to keep unit working at prime efficiency.
Apr 18, 2011 | Rheem Tankless Hot Water Heater...
Replaced mother board due to error code c2 11 as per rheem tech department. now code 11 flashes after 3 to 4 minutes of use and unit shuts off. WHAT NOW????
Rheem, Richmond, Ruud, and Paloma are all the same manufacturer. After about 9 months, my tankless RTG-74PVN started giving me error code 11 and cold water!. I fixed it by cleaning the burner, as shown in this video:
www.howtolou.com/clean-a-burner
Dec 29, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I have an error code of c2 11 on rheem model number ptg-74pvn-2 I will get warm water for about 5 seconds and then it goes cold
www.howtolou.com/clean-a-burner -Lou
Dec 10, 2010 | Rheem Tankless Hot Water Heater...
My new tankless WH stopped working. It gives hot water for about 15 sec, then starts flashing C7 12 or C2 11. How can I fix this, We had it for a month now & it worked before.
11 The Gas Shutoff Valve is not opened
completely.
12 Gas Service has been interrupted.
LP Gas is running low. (LP models only)
I think C7 is where the startup sequence ended...and then you get the error code
If less than a month old...contact your customer support
Nov 01, 2009 | Rheem EcoSense by 7.4 GPM Outdoor...
Rheem RTG-53PVN Indoor Natural Gas Tankless Water Heater for 1-2 Bathroom H Logo
158 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
