Question about Woods Kubota Bx 24 Bx 23 Bt610 Bh75 And Backhoe Thumb
Does kubota have a problem with the bh75 backhoe the rear cylinder bent once and snapped the second time
Dipstick or sight gauge location on Kubota Tractor/Backhoe TL421 needed. Changing fluids and cannot locate the level gauge.
motor oil stick is if sitting in seat facing forward , its on right side , just by your right ankle , in a little offset in the block ( loop handle sticks out by right ankle) hydraulic oil level is a sight gauge (glass) they do get covered up with grime over time and need to be wiped off to see them !!! me I look down fill tube with light and measure three inches off tank top (heat expansion room)
Oct 12, 2016 | Kubota Garden
We changed water pump in Kubota l3010 tractor. It won't crank and water is coming out of exhaust pipe. Any suggestions?
Jonsas, right. Don't try to crank with water on pistons. If it crank, it would bent the rods. Pull spark plugs or injector precups first.
Mar 30, 2015 | Kubota Garden
I've been hacked of 999999999999999999999999999999 wooz and 999999999999999999999 beex on woozworld.com
You didn't have that much but, I can still give you something to get free wooz and/or beex! http://ch3at.com/woozcheat/
and I think you only have to put your username and how many beex and wooz you want!! :D You're welcome! I play woozworld and my username is stella987yti! Please add me! Thanks :3
Aug 17, 2013 | Woods Kubota Bx 24 Bx 23 Bt610 Bh75 And...
I have a kubota bx25 that won't start. it has power to the starter on battery side
you need to have power to the small wire on the starter for it to crank over
Sep 03, 2012 | Woods Kubota Bx 24 Bx 23 Bt610 Bh75 And...
Manual kubota B7000 DT
I need manual Kubota tractor B7000, do you know where I can buy it?
regards, Milan
Feb 09, 2012 | Woods Kubota Bx 24 Bx 23 Bt610 Bh75 And...
I have a B1200 kubota tractor and want to get a manual on it
Call (803)-536-9411 or 800-849-9412 ask for Justin. Tell him Brad sent you
Pioneer Farm Equipment.
Brad.H
Nov 30, 2010 | Woods Kubota Bx 24 Bx 23 Bt610 Bh75 And...
I have a small kubota tractor -L1800DT -deisel motor. It starts but stops a rter a fer seconds running, . When it does go, it slowly fades in power and stops. I have replaced the fuel filter which was...
Andy, a couple of ideas for you: first, check to see if there are two fuel filters. Some Kubotas have one filter in the engine compartment, but another one under the chassis. If you only changed one, you could have another one still plugged up. The other problem that would cause the engine to lose power shortly after starting would be a dirty air filter, so check that too. Good luck! Please rate my solution if helpful, thanks.
Aug 09, 2010 | Woods Kubota Bx 24 Bx 23 Bt610 Bh75 And...
My BX23 rear yellow lights flash all the time...even when tractor is turned off. I have disconnected the battery cable to stop the immediate problem but need to see the wiring diagram to figure out why...
The hazard lights are wired so they will flash when the hazard switch is on, regardless of whether the tractor is running. Assuming you have tried flicking the hazard light switch on and off, and the lights flash no matter what position it's in, then I think the hazard light switch is shorted. Pull one of the wires off the back of that switch to stop the flashing, then order a replacement switch - it's not an expensive part. Good luck!
Jul 07, 2010 | Woods Kubota Bx 24 Bx 23 Bt610 Bh75 And...
I own a kubota RW-25 4 wheel drive loader and backhoe. whilst starting the other day everything was normal, when the machine didnt start stright away i returned the key to ignition off, then to igniition,...
have you check the fuss and the relays. if i rember there are three not sure been a long time I had one in my shop. check the ground wires to. the only other thange i can come up with at this time is your inginshion swicth
Sep 18, 2009 | Garden
Woods Kubota Bx 24 Bx 23 Bt610 Bh75 And Backhoe Thumb Logo
287 people viewed this question
Top Woods Garden Experts
D. E. Hev
Dennis Key
Dennis Key
Are you a Woods Garden Expert? Answer questions, earn points and help others
