Question about Midland LXT300-R 2-Way Radio
Our Exicom 835 am Radio has changed its frequency on tx and rx It shows correct frequency on Display but On frequency counter the frequency is differentso we are facing problem in repair pll or Oscillator kindly help me wasim
Why does my new Honda CB always show RX receiving transmission no matter where squelch is set?
if this is on a Goldwing, it appears that you have a shorted pin int he connector. Disconnect the radio and make sure all of the pins are straight and connecting properly.
Oct 02, 2014 | Radio Communications
No TX/ rx Radio Shack TRC-495
it probably jumped freq. somehow. There is now manual or anything but a picture of this radio and a few tune up rv's but thats it.I have the exact same radio and it works fine If you can put it on an oscilloscope it should tell you right away what the problem is. Then try a frequency counter.
Mar 06, 2014 | Cobra 29 LTD CB Radio
Tx rx
the problem you now have is probably going to cost you more money to fix than the radio is worth. Could be a quick simple fix or you could be at it for hours trying to fix it. you will need a scope, frequency counter,watt meter, modulation meter, signal generator, volt meter,distortion meter,and a service manual from
www.cbtricks.com
Jun 18, 2013 | Galaxy Radios DX-33HML 40-Channels Base CB...
Why wont my scanner model 60 channel pro-2029 scan
Hi Chad,
Do you have any frequencies programmed into your radio scanner?
If not, then that is why you're not receiving anything.
If on the other hand you do have frequencies programmed, are they the correct frequencies for your location?
Are the frequencies the Tx or Rx frequencies that you programmed, The Tx frequencies are the correct frequencies to program, as Rx is the mobile(usually) Tx frequencies, and unless you're within 5 miles of that mobile, you won't hear it, and you certainly won't hear the base transmissions, unless it's a high powered Simplex Frequency.
I hope this has been useful to you.
Cheers,
Peter
Mar 15, 2013 | Radio Communications
My connex cx3300hp wont transmit
You need external watt meter& SWR meter..Change antenna..Is the radio meter keying 3/4 way up to 4 watts?(if not then its not Tx'ng)It could be 10.240 mhz crystal or IF pots(need Frequency counter) Or take it to professional Cb repairmen...
Mar 12, 2013 | Radio Communications
I have an Icom v-8000 radio.The TX is very good with 75 watts out-put. But have nothing in RX.No signal and no audio.
What you have is an amateur band radio, which requires you to be a licensed operator to use it. It is possible that the frequencies have been removed from the eeprom prior to your purchasing same.
You can have Rx only frequencies programmed by an authorised 2-way workshop, but until you become a qualified amateur operator, you will not be able to get Tx frequencies programmed.
For licensing info for Amateur operators visit www.vk6wia.org.
Regards,
Peter
Feb 20, 2013 | Radio Communications
Cobra 25 wx st FC 347 wiring
Just about all fc 347 come with instructions on how to wire it to the radio.
Jun 23, 2012 | Cobra 25 Wx St Sound Tracker Cb Radio W/...
Hi I have a Cobra 75 WX-ST radio. It is currently displaying radio frequencies instead of channels. How do I correct this.
Push and hold the memory key for 3 seconds to change back to displaying channels instead of frequencies. Do it again and it will go back to frequencies on the display.
If you need anymore help, don't hesitate to email me at rollincbmods@yahoo.com
Dean Pitts
Rollin CBs
Mount Vernon, TX
Jan 06, 2011 | Cobra Radio Communications
Magnum 257 6 digit display
To tune frequencies in either 10 kHz or 100 kHz increments,
press the STEP button until the desired digit is
flashing. Rotate the FREQUENCY control in either direction.
The entire frequency range of the Magnum 257
can be stepped through in 10 or 100 kHz increments.
To tune in 1 kHz increments, press the STEP button
until the 1 kHz digit flashes on and off. Rotate the FREQUENCY
control. NOTE: When stepping in 1 kHz increments,
you are limited to tuning within a 10 kHz
frequency range.
Dec 22, 2008 | Magnum 257 CB Radio
Radio Communications Logo
Top Midland Radio Communications Experts
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
