Question about Dell Dimension 2400 PC Desktop
I cant conect to the intornet. im using cable can u help mi.
  • joecoolvette
    joecoolvette Oct 10, 2010
    How do you have it hooked up? Cable company cable to modem. Ethernet cable from modem to computer. Cable tech has to set your computer up by going to their website, (And coming to your home), or you have been given a CD disk, and/or instructions
  • 3,940 Answers
First thing is check and see if you have a valid IP address (Start, run, CMD enter) type (IPCONFIG /All ) this will give you the IP address information. If result of IP address is 0.0.0.0 or 169.254.x.x then you don't have connectivity with your broadband connection (Bad Cable, Bad NIC, Other communication issue etc)
If no valid IP address, the 1st thing is to power off system, power off any router you may be using and power off the broadband modem. Wait 3 minutes. Power on broadband modem, wait a minute to let it reset, power on Router (If you have one) wait a minute for it to reset, power on system and test your connection. If no change, try a different computer at that connection see if it can access the internet. If another system works, it is likely the Network Interface Card (NIC) which on a Dimension 2400 is part of the motherboard (Buy a PCI NIC for $10)
If you have a valid IP address, boot to the safe mode with networking (F8 at boot) then see if you can connect, if so then your issue is software based (Firewall, security software, possible virus) If it doesn't connect then there could be issue with your TCP/IP protocol settings. If you can't connect in safe mode with net, reboot to normal mode, then right-click your local area network connection and click REPAIR and see if that doesn't resolve. If no change try an anti-malware program like Malwarebytes
Posted on Oct 10, 2010
I cant conect mi huawei p8 on kenwood kca bt200 i forgot pairing code ...help me please help help help
Delete the registration and then check out pages 12 and 13 of the user manual, below.
http://kasc4.s8.novenaweb.info/files/prod/1028/5/KCA-BT200(EN).pdf
Sep 05, 2016 | Kenwood Radio Communications
Necesito bajar mis fotos de mi camara m340 a mi pc
Usted deber?a haber tenido el software incluido con la c?mara cuando lo compr?. Encienda la c?mara. Conecte el cable USB (modelo U-8) de la c?mara a la PC.Use el programa Easyshare para localizar sus archivos de im?genes y subirlas a su PC. Si esto es lo que no funciona, tambi?n puede utilizar un lector de tarjetas. Si uno no se construye en su PC, usted puede comprar uno bastante econ?micamente. Inserte la tarjeta en el lector de tarjetas y se mostrar? como una unidad extra?ble en "Mi PC". Crear una carpeta en su PC, ?bralo y seleccione los archivos de la tarjeta (unidad extra?ble) y copiarlos. Pegarlos en la nueva carpeta. Estoy usando un traductor en l?nea para esta respuesta, as? que espero que pueda entender lo que escrib?.
Dec 28, 2014 | Kodak EASYSHARE M340 Digital Camera
I los mi cod to get mi wireless conection
Plug into the router directly using a cable between your computer and the router. Then you can go into the router settings and set a new wireless key. If you need help accessing the router settings read your manual. If you've lost it you can download one from Netgear's site. Use a cable to access the router and turn off the wireless on your computer.
Mar 13, 2011 | NetGear WNR2000 Wireless Router
My Dell 2400 mtc2 wont conect tu the intornet. im using a cable model.
Hello Dear,
Things needs to be checked.
1) the Modem. Open Control Panel > Phone and Modem > Modems (make sure your Modem should be listed here) > If yes then CLick on that and choose "properties" > Click on Diagnostics > Query Modem..
It should return some numbers in the dialog box. If not means your Modem is faulty.
2) If modem is OK then first check that your connections are OK. and also check with your ISP that there should not be any issues (Server Down, Validity expired etc)
Hope it help!
With regards
FIXYA team
Oct 10, 2010 | Dell Dimension 2400 PC Desktop
Bad connection to ps3
once you have the mobile conection pluged into your ps3 try scanning 4 networks if it finds ur network click onto it and type in the WPA key that came wit your mobile conection
PLZ RATE THIS IF YOU FIND IT HELPED SOLVE YOUR CONECTION TANKS.
Jul 18, 2009 | Sony Playstation 3 (PS3) Console
I dont know how to install my D-link 524 router.i need wireless
http://www.it.hiof.no/datakom/lab/di514_QIG_103.pdf
go for this web site you go the your anwers
May 23, 2009 | D-Link DI 514 Wireless Router (DI-514)
Home cinema system whafardale to my matsui lcd tv
You need an audio cable as well. It is stupid i went into currys and they said for your home cinema system to work you need a HDMI cable and a audio cable its stupid that they don't come with the system really.
Nov 09, 2008 | Wharfedale DVD-M3 DVD Player
Dns error
sorry mi amor pero no te puedo ayudar a mi me pasa lo mismo aveces...ya tu sabes quien es jazmin12291
Aug 25, 2008 | Sony Playstation 3 (PS3) Console
Unable to access most functions....
Hi !! If you dont plug park brake and light switch, some options will be blank. Turn off power supply conect those plugs (im advice you to do not conect speed cable). Turn on them reset the unit.
P.S. The park brake cable can be conected with tre ground. This way you can watch dvd with the car in moviment...
Go to the panasonic web and download the last update for your unit !! http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/Mobile-Navigation/model.CN-NVD905U
I hope it helps yous... sorry my english....
Nov 21, 2007 | Panasonic Strada CN-NVD905U GPS Receiver
Dell Dimension 2400 PC Desktop Logo
88 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
