Question about Frigidaire Ovens
We have frididaire gas range model # PLGF389CCB---serial #--VF31226190 last nite, while cooking, extreme heat melted the plastic control cover. Now the gas oven won't turn on and we are receiving a message of "F 1" with a continuous beeping noise.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error code F1 indicates Electronic Oven Control (EOC) failure and to resolve this issue you'll have to replace the Electronic Oven control (EOC). Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks Rylee
Posted on Oct 10, 2010
Melted plastic on heating coil
you can not remove the plastic safely please replace the heating element
Sep 30, 2013 | Frigidaire (FEB30S7D) Oven
We bought a house with an old wood combustion oven everhot deluxe 204. Unfortunately all the controls details have been erased with time. So we do not know where the highs and lows stands for the knobs. We...
Hi Jacqui and Sven,
Check these guys out...you'll have to call or write, but they should be able to answer any (and all) questions about the Everhot Deluxe 204. They even carry spare parts! Hope this helped.
http://www.woodstoves.com.au/html/everhot_parts.html#Everhot
May 06, 2011 | Ovens
Kenmore Elite Gas range, model # 790.79363401 The range works but the oven does not seem to heat up. It appears to ignite, just not get hot.
the problem should be from the heating element of your Kenmore Elite Gas range. The heating element is either defective or may have loosed contact as a result of heat coming out of the Oven. The heat coming from the oven may have melted the wire connected to the heating element which might not make it heat up.
Disassemble the oven and check if its actually the wire connected to heating element that got melted, or its time to replace the heating element.
Good luck.
Dec 15, 2010 | Kenmore Ovens
Pleace HELP!!! How do I set the clock on my Russell Hobbs RHM1712 microwave?
You can set the timer on a range slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking. The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day.
Set the timer on a range slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
Fill the insert of the range slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours.
The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat.
A small indicator light will come on below the word to tell you the cooking temperature.
thank and thanks for using fixya.
Aug 20, 2010 | Ovens
Error F5E1 after self cleaning
Hi There
I have read the codes you are looking for,so I'm sending them to you and i hope this will help.
F5 E1 16 Door latch not operating Check that door switch is completely closed. Check latch, solenoid, and actuation switch for electrical or mechanical malfunction.Thank you for writing to fix ya.
Best regards Richard
Dec 11, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Older gas range not heating up enough
Pull the knob off of the oven control and see if their is an ajustment. If the ajustment doesn't work then change the thermostat bulb. It goes for the oven to the back of the oven control know
Dec 21, 2008 | Ovens
Frigidaire during cleaning F1 error,
F1 means its your electronic control and it will probably cost you the same amount to get this problem fixed again. The part is usually $350 plus.
Nov 24, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frididaire gas oven won't light
Does the cooktop burners work? if they do then the problem is either the safety valve or the glow plug (even though it glows). Try tapping the safety valve. If the oven lights up change the glow plug.Otherwise change the safety valve
Regards
Nov 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Gas oven temp problem
HI thanks for your question. there is a oven sensor , located in the oven, top left corner. replace this part. thanks the appliance doc. please rate my answer. thanks
Oct 11, 2008 | Frigidaire Ovens
How to remove the control panel on Whirlpool double oven Model RBD305PDS14
Remove the doors by turning toward you a little toggle apparatus located on each hinge. Locate a small screw on the lower inside edge of the left and right hand trim and then slide off the trim. Remove the lower trim then raise the upper trip and put the left end of the panel inside the top opening. This allows you access to the control panel. Test both the keypad part #8300440 and the control panel part #830219 to see which one needs to be replaced. Order the replacement part, plug it in, reverse the precess above and it should work like new..
Oct 02, 2008 | Whirlpool RBD305PDS Electric Double Oven
Ovens Logo
60 people viewed this question
Top Frigidaire Ovens Experts
Oloyede Monsuru
ashburton
Starnley Johnwells
Starnley Johnwells
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
