Question about GE DWSR483EBWW Electric Dryer
The dryer will not stay on when i switch to on position
  • mustang88 Oct 10, 2010
    the dryer will stay on as long as I hold the start switch to the on position but as soon as I let it go it will stop running
  • GE Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Oct 17, 2010
Maytag Performa PYE/G2300 Dryer: The switch runs through the cycles but nothing changes. All cycles stay the same - hot! Help, please? Thank you!
You mean it stay only "Hot" only on any position?
-If so then the switch is defect (Burn or melt inside)
It might need new switch.
Good luck
Mai
Feb 07, 2017 | Maytag Dryers
Kenmore dryer model 110.74994300 push start does not stay on
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
Kenmore Whirlpool Dryer Won Start Easy Fix
Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Jul 01, 2014 | Kenmore 62602 Electric Dryer
When you push the start button, the dryer turns on, but shuts off when you let go of the button. Dryer does not stay on, When you continuously hold the button in the "on " position, the dryer operates...
There is a switch on the motor that is active when the motor gets to speed. Either the switch is bad or the motor is not getting up to proper speed.
Eric
Aug 21, 2010 | Kenmore 74602 Gas Dryer
On/off switch stops working
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 22, 2010 | Frigidaire Electric Dryer
Dryer won't stay on
replace switch
Oct 10, 2009 | Dryers
Frigidaire dryer feq221cas2 the startswitch will not stay on
The switch is bad and need to be replaced. Holding the switch in the on position may cause it to burn, thus causing a fire so please do not hold it in manually.
Jul 22, 2009 | Dryers
Door switch tab is broken so dryer does not stay in the on position whirlpool gold ultimate care II the tab switch that lets the dryer know it is on is broken, I have to tape it down but it only stays...
will need to replace actuator. door swich can be accessed through the top. Unplug first, pull screws under lint filter door and pull top toward you. top should release and flip back
Jul 17, 2009 | Dryers
Kenmore dryer 68972890 won't stay running
it sounds like a weak motor.you can also check the start switch if you have a meter,remove both wires and check it on ohms in the off an on position-mike
Mar 11, 2009 | Kenmore 63942 Dryer
Ge dryer wont stay running
start switch is bad,it is stuck inside,get the model number inside dryer door or on top panel,call local appliance parts store to get new part,only a few bucs,replace and you should be allright,let me know-mike
Jun 15, 2008 | GE DBSR453EBWW Electric Dryer
GE DWSR483EBWW Electric Dryer Logo
147 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
