Question about Sony Cyber-shot DSC-T300 Digital Camera
The camera vibrates when powered what is the cause
  • 87 Answers
On Sony T100 and similar,
its the vibration canceling unit, i had the same problem.
if you have good hads you can fix it.( on your oun risk)
1) disasamble the camera, you will see black plastic box inside, this is he lens unit.
2) on the botom you see 2 scrwes, they are holding the CCD remove them and the ccd unit will come from the lens assembly
3) the next is the stabilizer unit it is the problematic one. it is located on the left side of the lens asebly and is held by 2 screws.
you can test it by puling out the cable connected to it (the conector is just under the lens) and verifign that the problem is solved. ( you can leave it this way it will shoot fine just without the anti shake)
4) to fix it take it out ,remove the plastic cover, you see the lens on a plastic mount it should be glued to the magnet under it. the problem is that the glue fals apart.
remove one of the pins on wich it slides, and take the lens and the magnet out.
5) reglue the magnet and reasemble the camera.
6) power up and test, for me that solved the problem
if you need more help you can mail me at adisarit(et)yahoo(dot)com
this is spam mail so be prepared to wait a few days for reply.
i have a document with pictures explaining the process
Posted on Dec 20, 2010
I have Sony T-200 for more than 2yrs. It has been working alright. Now when it is switched on it vibrates and the picture you get is out of focus?There is no vibration when viewing pictures.
hi, your camera has IS unit get defective cause vibrate noise. and out of focus. It will require realignment or lens unit assemble or replacement of the lens unit. your local repair shop would charge around $65 to 135 depend on what they really want to charge. Good luck with you and best regard!
May 22, 2011 | Sony Cybershot DSC-T200 Digital Camera
Canon ixus 65 - when taking a shot without the flash on, a red camera icon appears on screen and the shot is usually blurry. Why?
When hand-held shooting, shaking will cause blurry. So when the shutter speed below 1 / 60 second the vibration warning will appear, open the flash, up shutter speeds, vibration warning disappeared.
Jan 08, 2011 | Canon PowerShot SD630 Digital ELPH / IXUS...
How to disable the vibrate function in my sony cyber shot DSC-T70 and where i can find it
There is no option in the DSC-T70 Camera to enable or disable the vibrate option. The vibration in the Camera is a malfunction. The Camera may experience an issue where an abnormal internal vibration and an inability to properly focus and take pictures. Try the following troubleshooting steps and check if the issue can be resolved.
Follow the steps below to perform a manual power reset.
Turn off the Camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the Camera to remain without power for 60 seconds.
Re-insert the battery pack.
Turn on the Camera.
If the issue persists after the power reset, then reset the Camera back to factory default.
To reset the Camera back to factory default, select the INITIALIZE option under Main Settings 1 Menu of the Camera to OK. (HOME-->SETTINGS-->MAIN SETTINGS-->MAIN SETTINGS 1-->INITIALIZE-->OK).
If the issue occurs again, then service may be required.
Thanks for contacting FixYa.
We wish you a Happy Holiday Season.
Dec 18, 2010 | Sony Cyber-shot DSC-T70 Digital Camera
Vibrating and shaking
the sstepper motor of the focus assembly has slipped out of its track. that motor is a very powerful one which can cause the vibration.  once u change the mode to take the picture the motor should run in both direction to make some calibration. you cannot disable it. in the preview mode the optical assembly returns to it closed position and then the motor is switched off.
since it is a cybershot you need to be very careful in handling the camera if you have any plan to open it. it is recommended to be taken to the nearest service centre. any way the wheels might need replacement
Jul 04, 2009 | Sony Cyber-shot DSC-T300 Digital Camera
Vibrations
this is the normal problem and no need to worry. It is the camera mirror returning to its normal position when the camera is powered off....
thank u
rate me!!!
May 24, 2009 | Sony Cyber-shot DSC-T300 Digital Camera
Sony Alpha A100 shakes when I turn it on
It's actually, believe it or not, an anti-dust mechanism. All Sony Alpha A100's (mine included) do a little shake/vibration to help keep the dust off. It's nothing to worry about unless it lasts for more than a second.
May 14, 2009 | Sony Alpha DSLR-A100 Digital Camera
Screen vibrates intermittantly. Also buzzing noise.
This is a problem with the lens gyro we can keep it from shaking it requires the camera to be taken apart and amodification done to the lens repair cost 65.00 in most cases.
May 14, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
Vibration of camera
Vibration problem
Sony has recently discovered that with certain units of its "Cyber-shot" DSC-T20 digital still camera, a symptom may arise in which the camera body may vibrate when it is powered on, due to a mechanical failure affecting the lens, and it prevents the camera user from being able to shoot.
To ensure customer satisfaction, Sony will provide a free repair service when this symptom occurs within certain units covered by the serial numbers indicated in the serial number validation box below.
We apologise for any inconvenience this may cause. Your understanding and cooperation would be much appreciated.
Symptom and cause
The camera body may vibrate when powered on, due to a mechanical failure affecting the lens. This prevents the camera user from being able to shoot.
Applicable model
Digital Still Camera "Cyber-shot" DSC-T20.
How to check the model name and serial number
The model name and serial number are indicated on a sticker located at the bottom of the camera.
Applicable serial number
To determine whether your DSC-T20 camera purchased in Asia Pacific region may be affected, click here to validate the serial number.
Model Name Area Serial No. Range Unit DSC-T20/B AU2 2257001 - 2501900 5,050 DSC-T20/P AU2 2258851 - 2485700 4,700 DSC-T20/S AU2 2261851 - 2501500 7,650 DSC-T20/W AU2 2265751 - 2502100 7,650Period of free repair service
From 17th July 2008 to 16th July 2011.
PLEASE NOTE these serial numbers are applicable to ASIA / PACIFIC check your own country sony website if your serial number is applicable as different regions will have different serial number for the DTS -T20, hope this helps
Dec 24, 2007 | Sony Cyber-shot DSC-T20 Digital Camera
Sony Cyber-shot DSC-T300 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
