Question about Polar RS400 Heart Rate Running Computer Wrist Watch
Error 169 shows on watch. cannot clear, appears to be frozen.
My casio pro trek 2894 is frozen it shows op en ontop and when i press the setting button it resets time to 12h00
Hi
Have you checked that all buttons when pressed come in and out easily?
Sometimes the little spindles that press the contacts inside the watch do not come out completely and remain "pressed" even if the button appears to be "out"
Clean the watch, with particular attention to the buttons area so they can move easily in and out. If this does not do the trick, open the watch with great care not to damage the threads on the plastic case and visiually inspect if the buttons travel easily in and out and that all springs if fitted are sound. Remove and replace the batteries with new ones (DO NOT use bargain batteries from that "auction site")
and reset the watch.Try again, if ok carefully clean the back seal apply a little vaseline to the top of the seal and close the case. DO NOT over tighten the screws as this will damage the plastic thread and the watch will not seal properly and will be likely to flood with moisture. Good luck
Jan 25, 2017 | Casio Watches
Casio PRO TREK error 'OP EN' Display frozen with the above msg. None of the buttons - except the light - works. Whats wrong .. battery charge shows FULL
The problems is very simple: On the back cover (inside) is a little Cu metal Part. This part is glued to back cover using a poor glue (rubbered glue) and, in time, is moving from original position. You must put back this parts to original positin ( a little hole inside of back cover) and glue using a good glue. When the back cover is mounted , this part must have a ferm contact with two springs from mechanism (sensor for back cover open). If beatwin this springs isn't a electric short (using Cu metal parts) the internal mechanism of watch "see" the back cover is open and show "OPEN" on screen!
Mar 22, 2010 | Casio Watches
I am very confused with my guess 41005M. Do not know how to set the date and day directly.I only can pull the crown once. Do really need help :(
Unfortunately their site does not seem to refer to watches by numbers, so I could not identify your watch.
If you go to their web site you can get instructions.
Go to "guesswatches.com", click on "watch care" and a page showing all the variations of watches will appear.
Click on the one that looks like yours and operating instruction appear.
I hope that this clears up your problem.
Jan 26, 2010 | Guess Watches
During a workout my watch stopped working it appears to be frozen and will not do anything
NO, don't open the back cover you will break the water seal.
Reset the wrist unit. Resetting clears the date and time settings.
Press all buttons except the Light button at the same time until the display is filled with digits. Press OK.
If this does not work, have the batteries checked.
Oct 19, 2009 | Polar F6 Wrist Watch
Seiko M705 - 5A10 series divers watch. Time is Frozen
Have the batteries checked and an "AC" done to it. These watches generally have several batteries and the die off can be slow and only fail partially. The "AC" or all clear function will reset the circuit board and bring all your functions back.
As with any dive watch, be sure that you take it to a watch maker/technician that can reseal and pressure test the watch to insure it is safe for diving.
Sep 18, 2009 | Watches
How to turn off hourly alarm on Gap Sport watch?
Click reset button (lower right) - this shows you the alarm time as indicated by a large letter 'A' that appears in the display.
Keep holding the reset button and simultaneously press the mode (lower left) button.
This toggles the days of the week at the top of the display.
All days shaded in black means the hourly alarm is on.
All days clear means the hourly alarms is off.
Now, if I could just figure out how to choose the exact days the alarm can be set to ring ... it seems like it is possible.
Aug 16, 2009 | Watches
Can't figure out how to deactivate the alarm on Umbro U564B watch
Start with watch in normal clock mode. press and hold bottom right "lap reset" - alarm time appears. Keeping "lap reset" held, I can then toggle the alarm on and off using top right "start/stop".
Qiu: Circle segment lights up (only a black point in the middle, NO ALARM)
Circle segment with a black section on the above middle point, ALARM ON.
Mar 03, 2009 | Bulova Watch
Hour and second hands on my Casio Wave Ceptor watch appear to have frozen
They ususally say leave it alone for about 3-4 minutes and it goes back to time keeping mode. Or - you have "turned it off" a feature to conserve the battery while it sits in you drawer.
Manuals can be downloaded from Casio at
http://world.casio.com/wat/download/en/manual/
Dec 29, 2007 | Watches
Frozen Display
The reset will always solve the issue. It may have been due to Electromagnetic Interference or Static Electricity.
You can press and hold ALL buttons at the same time for 10-15 seconds. After that, simply reset the time/date. All saved information will be stored.
If you are still having a problem feel free to contact Polar Customer Support @ www.polarusa.com.
Hope this helps.
Chris @ Polar USA
Nov 08, 2007 | Polar F6 Wrist Watch
AXN 300 Watch
Here is the link to the user manual for your watch; http://www.polarusa.com/manuals/AXN300.pdf Check page 9 - you have to re-enter these basic settings after removing the battery, this may clear the error message although i was unable to confirm this from the manual. contact polar on; http://www.polarusa.com/default.asp and you can find a service centre who can check your watch, all the necessary link software downloads etc. Hope this helps :)
Oct 03, 2006 | Polar AXN 300 Watch
Polar RS400 Heart Rate Running Computer Wrist Watch Logo
172 people viewed this question
Top Polar Watches Experts
NOEL
NOEL
David Payne
David Payne
Are you a Polar Watch Expert? Answer questions, earn points and help others
