Question about Emerson MW8102SS 1100 Watts Microwave Oven
My emerson mw8115ss is working but not heating up how do i change fuse
  • Emerson Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Posted on Feb 22, 2011
3 Suggested Answers
flatech
  • 111 Answers
SOURCE: Have Emerson MW8115SS- When I Open the Door it
May be a bad Door switch that may be arching metal to metal.
Unplug the Microwave and remove the Control panel, then you will have access to the 2-3 door switches, inspect them and make sure they are not melted etc, If you find a bad one then most appliance parts stores can be found in the phone book.
Also make sure the Microwave is on it;s own plug if to many circuits are tied into a GFI then it may be tripping it out.
If you don't have any local appliance parts stores you can get your model number and try one of these sites.
http://www.repairclinic.com/
http://www.partselect.com/
Good Luck!
Posted on Nov 06, 2009
Icebassman 5
  • 57 Answers
SOURCE: My Emerson MW8115SS microwave works but doesn't
Hi there.
Obviously it is "not working"
Could be an internal fuse or the activator is just finished.
Iceman.
Posted on Nov 10, 2009
Emerson Microwave MW8115SS --
I would suggest you check the door switches inside the microwave oven just below the keypad, rectangular in shape. The switches are normally open or closed, set meter to ohms, unhook lead from one side and test with door open and closed. If readings are the same both ways the switch is defective. "check all switches"
Mar 19, 2012 | Emerson Fans Emerson MW8115SS Microwave...
Emerson model mw8115 ss
The problem is caused by one or two bad door switches that will need to be replaced.
Mar 14, 2012 | Emerson Fans Emerson MW8115SS Microwave...
Hi, I have an Oster OMW1199 microwave that will not heat food. The light turns on and the timer works, but no heat.
I bought-the oster microwave and like others it did not last long before it stop heating. I took (careful precaution!!) and (unplugged the the unit!!) to view the fuse which of course is the main problem why this microwave does not heat up. Everything else works well but the heating. But since I changed the fuse to something very close to the same amp of the actual fuse it did work fine next to nothing.
I did not find any problem other than the noheating. This should only be attempted by someone who is in fact has close knowledge of electricity. The process is safe (WITH THE CORRECT PRECAUTION!!).Ever since I replaced the fuse and found out that that was all it needed I have been using it for 8 mths. Note--I did take measures into my own hands which is not recommended by anyone. But it is the old-fashion way...
Aug 28, 2011 | Emerson Fans Emerson MW8115SS Microwave...
Microwave stopped working during heating process....timier works but does not make that microwave sound
Basic Microwave Oven Troubleshooting Tips
heatman101
Dec 28, 2010 | Emerson Fans Emerson MW8115SS Microwave...
My Emerson MW8115SS microwave works but doesn't heat anything up, what could be wrong? And is it a easy fix?
Hi there.
Iceman.
Nov 10, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
MW8115SS worked perfectly and then went dead
Blown fuse , take the outer cover off and change the fuse. Iff you don't have a fuse use a piece of tin foil until you find a replacement fuse.
Hopefully this helps you out.
Aug 18, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Emerson microwave oven model mw8115ss
There is not much you can do about this. There may be a reset button on the control panel, try it. You can try slamming the door a couple of times & looking on the back for any fuses. If this fails, scrap the oven & get a new one, as they are generally not worth repairing.
Jul 02, 2007 | Emerson MW8108P Microwave Oven
Emerson MW8102SS 1100 Watts Microwave Oven Logo
651 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
