My SX 316-S Pioneer Receiver was professionally installed. I don't seem to have the owners manual. How do I get the remote control XXD3108 to work properly? I don't hear any sound difference from Sports, Adv. Surr., or Sports setting. Also, the small speakers on the stands have extremely low volume output.
    President:
  • 2,777 Answers
How long ago was it set up? I would have them come back out and set it up again for you, and show you how to switch modes and the like. I have put the manual on my personal webserver for you here... it's quite difficult to find. You need to switch mode on the remote to have it do true surround sound and force pro-logic when it is not in true surround sound, things like that.
Also you can go into the setup of the receiver and go into each speaker output and increase the dB of each channel independently.
Although, if it was installed recently I would call them back up and have them come out and adjust things for you, and give you a quick run down of how it works. But this manual will be essential to have as well, here it is for you:
http://micromatikal.dlinkddns.com:8000/cust/dhuggs04.pdf
Thanks!
Tim
Posted on Oct 10, 2010
OVERLOAD issue
check the attached service manual.
H appears normal and L appears to be defect.
also see page 88 to troubleshoot further Pioneer SX 316 Service Manual
Apr 05, 2016 | Pioneer Sx-316 Audio Multi-channel...
How do I hook up a powered subwoofer to a pioneer sx-316?
Many subwoofers accept both line level (RCA jacks) and amplified inputs (+ and - speaker terminals). The Pioneer SX-316 does not offer line level output, only amplified outputs via the PURPLE + and - speaker terminals. This means that in order to use any subwoofer with an SX-316, the sub woofer will need to accept a + and - speaker wire connections for input Your manual speaker connections are on page 11 of the manual which can be found here: http://www.manualslib.com/manual/260358/Pioneer-Sx-316-S.html#manual
Starting at the rear of the SX-316; run a speaker wire from the PURPLE + and - terminal (SUBWOOFER) to the + and - speaker input terminals on the subwoofer. See your subwoofer manual or experiment (at your own risk) with connecting the speaker wire from the SX-316 to the subwoofer's + and - LEFT only, RIGHT only or BOTH left and right speaker inputs. Do not connect wires from the SX-316 to the speaker OUTPUT terminals of your subwoofer.
Finally, adjust any variable low pass filter knob or setting on the subwoofer to the lowest frequency that your main speakers are capable of producing. If you're not sure what that value is, try setting the subwoofer to 100Hz and judge how it blends with the main speakers. If it seems a little too bass heavy and thick then reduce the setting to 80Hz. On the other hand, if the sound seems to be slightly thin and lacking weight, try increasing the setting to 120Hz. By careful listening and a bit of patience you will be able to get the sound to seem balanced and well blended.
Apr 06, 2014 | Audio Players & Recorders
Pioneer receiver sx 316 shuts off after a few moments of being turned on
Mine is having this problem now.
Tried re-inserting the speaker wires.
Tried resetting before it shuts off.
Tried disassembling but solder joins are still nice.
It still shuts off soon after power up. Time to spend money? :(
Sep 08, 2012 | Pioneer Sx-316 Audio Multi-channel...
I need to know if the "pioneer audio multi-channel receiver SX-316" has a remote control.i just got it wondered if its possible to get a remote control for it.
Of course it does. No complex modern A/V electronics exists without a remote. They save money on front-panel indicators and controls my requiring a TV and a GUI to operate, too.
http://remotes.com/remotes/servlet/rs?a=gmi&uuid=A13102125354151&smodel=SX316&brand_pn=PIONEER_SX316
There's one on eBay, too.
http://cgi.ebay.com/PIONEER-XXD3108-AV-RECEIVER-REMOTE-CONTROL-/360376667427?pt=LH_DefaultDomain_0&hash=item53e81f8d23
Since you asked the question that means you don't have the manual either. You WILL need it.
You may have to register for free but it is here...
http://audio.manualsonline.com/manuals/mfg/pioneer/sx316s.html
http://dl.owneriq.net/e/e385684d-89d1-4c1d-bafc-0829f1879e06.pdf
Jul 09, 2011 | Audio Players & Recorders
I need to program my pionner sx-315 reciever in my directv remote control
I can help you with your Pioneer Receiver & DirecTV remote control.
This is a list of all the Pioneer Receiver control codes for DIrecTV remote controls:
31023, 30150, 30244, 30289,
30531, 30630, 30801, 31123,
31343, 31384, & 31935.
There are so many codes to try for Pioneer Receiver and DirecTV, you might want to go ahead and do a DirecTV Remote Control Code Search.
I hope that helps.
_________________________________________
DirecTV Remote Control Code List Download
DirecTV Remote Control Manual Download
DirecTV Remote Control Code Entry
DirecTV Remote Control Onscreen Setup
May 25, 2010 | Pioneer SX-315
I have a Pioneer Audio Multi Channel Receiver model SX-316-S and I can't seem to figure out how to hook up my TV and DVD to the receiver so that all sound comes through the receiver
DVD audio straight in from its highest quality audio output. Use the stereo audio output to run straight to the TV for casual watching through TV speakers without the Pioneer involved.
A TV is just a glorified night-light, not a sound source - get its related audio from the Cable Box, ditto the highest quality
Mar 04, 2010 | Pioneer SX-315
103 people viewed this question
 Grubhead
Grubhead
