Question about Dell Dimension 2400 PC Desktop
My Dell 2400 mtc2 wont conect tu the intornet. im using a cable model.
    Sergeant:
    Champion:
  • 214 Answers
Hello Dear,
Things needs to be checked.
1) the Modem. Open Control Panel > Phone and Modem > Modems (make sure your Modem should be listed here) > If yes then CLick on that and choose "properties" > Click on Diagnostics > Query Modem..
It should return some numbers in the dialog box. If not means your Modem is faulty.
2) If modem is OK then first check that your connections are OK. and also check with your ISP that there should not be any issues (Server Down, Validity expired etc)
Hope it help!
With regards
FIXYA team
Posted on Oct 10, 2010
Is there a "line in" on MTC2?
There is a line in port on the audio of this computer. Turn the system around and look at the rear of the tower or get a flashlight and look at the back. The line in port is the 3.5 mm audio port with a light blue ring around the port. You will have to go into the control panel to use the line in after connecting the device. The default setting is for the microphone jack to be the active audio input. Open the Control Panel. Go to Devices and Hardware (or Hardware and Sound). Look for the Audio section and Manage Audio Devices. Click on the Recording tab. Set the Line In as the default. Note: you may need additional hardware, like a pre-amplifier, to get this to work. I've done it with a cassette player using the headphone jack which didn't need any extra hardware.
MCT2 doesn't specify any Dell desktop model. This term indicates the size of the desktop tower (mid-size tower). That differentiates it from the mini desktops and the full-size towers. You may have a Dell Dimension 2400 or a different model.
Accessing the Control Panel involves clicking the Start button for Windows XP, Vista and 7. For Windows 8, 8.1, and 10, pressing the Windows key + X is a faster route. (There are other options. For Windows 10, right click on the Start button.)
I hope this helps.
Mar 21, 2016 | Dell Computers & Internet
My dell MTC2 does not have sound at all. Are the audio drivers available online at no charge? Also, it does not recognize dvd's when I put them in. It just says to insert dvd.
Yes the drivers are available for dell pcs online. You don't have to pay to download drivers. I can give you the download link provided you give me the correct model no. of this pc. I believe you have given me a serial code? Is this a Dell Dimension 2400 model? As for the dvd problem its a problem with the windows operating system you will have to do a repair installation of windows using the disc.
Hope that helps!
Thank you.
Sep 22, 2011 | Dell Dimension 2400 PC Desktop
I do not have sound at all on my Dell MTC2 Desktop Computer that I bought used. Also The cd/dvd player does not work. It does not recognize discs when I put them in.
The drivers are available for dell pcs online. You don't have to pay to download drivers. I can give you the download link provided you give me the correct model no. of this pc. I believe you have given me a serial code? Is this a Dell Dimension 2400 model? As for the dvd problem its a problem with the windows operating system you will have to do a repair installation of windows using the disc.
Hope that helps!
Thank you.
I have dell desktop PC BMQVSOJ and model MTC2 ,made on ,july29, 2003. i need to buy new motherborad, how?
If you need to buy mother board then go to computer shop nearer to your home or in city and my request to purchase dell's optiplex mother boards.
Mar 19, 2011 | Dell Dimension 2400 PC Desktop
I cant conect to the intornet. im using cable can u help mi.
First thing is check and see if you have a valid IP address (Start, run, CMD enter) type (IPCONFIG /All ) this will give you the IP address information. If result of IP address is 0.0.0.0 or 169.254.x.x then you don't have connectivity with your broadband connection (Bad Cable, Bad NIC, Other communication issue etc)
If no valid IP address, the 1st thing is to power off system, power off any router you may be using and power off the broadband modem. Wait 3 minutes. Power on broadband modem, wait a minute to let it reset, power on Router (If you have one) wait a minute for it to reset, power on system and test your connection. If no change, try a different computer at that connection see if it can access the internet. If another system works, it is likely the Network Interface Card (NIC) which on a Dimension 2400 is part of the motherboard (Buy a PCI NIC for $10)
If you have a valid IP address, boot to the safe mode with networking (F8 at boot) then see if you can connect, if so then your issue is software based (Firewall, security software, possible virus) If it doesn't connect then there could be issue with your TCP/IP protocol settings. If you can't connect in safe mode with net, reboot to normal mode, then right-click your local area network connection and click REPAIR and see if that doesn't resolve. If no change try an anti-malware program like Malwarebytes
Oct 10, 2010 | Dell Dimension 2400 PC Desktop
What kind of power cord do I order for the Dell desktop Model # MTC2? THANK YOU! Liz
Desktop power cables are generic with all desktop computers. All you need to do is visit your local PC store and ask them for a desktop power cable. You don't need your computers model number.
Regards.
Aug 07, 2010 | Dell Dimension 2400 PC Desktop
I need to buy ram
Click Here it will directly take you to a dell website with appropriate part for your computer model. you can purchase from here.
Aug 25, 2009 | Dell Dimension 2400 PC Desktop
What does MTC2 mean
My name is ArmyMason, MTC2 is a model of power supply used for this computer. If this doesnt answer your question might I suggest using our premium service or live chat. Thanks.
Hope this answers your question.
ArmyMason
Feb 24, 2009 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
207 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
