Question about Hamilton Beach (24459) 4-Slice Toaster
Hamilton Beach model 24459 4 slice toaster, one side just stopped working, holding down the lever will not even start the heating element.
5 Suggested Answers
Falling Down
  • 67 Answers
SOURCE: Hamilton Beach 22505 toaster info
Usually, four screws under the bottom remove the top but the toast loader lever knob is usually press fitted on. Some units have bent tabs to hold them together if screws are not used. To remove the knob, freeze the unit (to shrink the knob/lever) then place a flat piece of wood like a ruler wrapped in cloth on the housing behind the knob and use a large bladed screwdriver to try to work the knob off. If you break it superglue and epoxy, and drawer knobs not plastic or wood might work as a replacement.
Posted on Nov 30, 2007
SOURCE: Digital Display no longer showing, lever won't stay down
YOU HAVE A DEFECTIVE DIODE THAT LITES THE LCD. A .99 CENT PART. SELLER SHOULD REPLACE THE TOASTER WITH OUT QUESTION.
Posted on Sep 30, 2008
espressonist
  • 1711 Answers
SOURCE: I have a 4 slice
The toast carriage is held down by an electro-magnet, not by any type of physical clasp or hook.
So the most frequent problem with elector-magnet is due to the heat some wire or springs become loose so the electro-magnet is not working properly so it does not stay down.
Another reason that electro-magnet not work properly is due to bread remaining does not leave the lector-magnet contacts to contact. You should clean between where the metal of the Electrical contact meet each other.
Posted on Sep 15, 2010
mc1bean
  • 3053 Answers
SOURCE: need instruction manual for hamilton beach 2-slice
Hello, az
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about toasters andpossibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/how-to-repair-small-appliances1.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
Will not heat up.
The heating element may have failed.
Feb 03, 2016 | Hamilton Beach Easy Reach 4-Slice Toaster...
The bread only toasts on one side (each piece)
I take it it that the outside is being toasted and not the part between the slices? That would mean that the element that is shared by the two slices has burnt out. Check with a dealer for a replacement.
Jan 20, 2011 | Hamilton Beach Eclectrics 22111 / 22112 /...
Toaster will only toast on one side
Is there a cancel button for this? It might be stuck. Check this and let me know
Feb 07, 2009 | Hamilton Beach 22502 Digital 2-Slice...
Only toasts one side of toast
The cancel button is stuck in the in position
Jan 13, 2009 | Hamilton Beach 22502 Digital 2-Slice...
jsullivan22 is right about the diode. I have this problem with my 24502, which is a dual version of this. There are 2 circuit boards in your unit one with the LED display on it and another one. The diode needing replacing is on the other board. it is in the center of the board, right next to a large (1/2W or 1W) 2K ohm resistor. The diode is probably part number 3ez24d5. Test it with the diode test on your DMM, if it is bad you will get 0V both directions (I think). Also if you measure it with the Ohm function it will probably measure less than an Ohm (check the zero on your DMM as many are not accurate down this low) You can probably replace it with a <a id="ctl00_ContentMain_CartGrid_grid_ctl02_ctl00_lnkManufacturerPartNumber" href="http://mouser.com/Search/ProductDetail.aspx?R=1N5934BGvirtualkey58410000virtualkey863-1N5934BG" style="font-weight: bold;">1N5934BG</a> or a <a id="ctl00_ContentMain_CartGrid_grid_ctl03_ctl00_lnkManufacturerPartNumber" href="http://mouser.com/Search/ProductDetail.aspx?R=1N5359BGvirtualkey58410000virtualkey863-1N5359BG" style="font-weight: bold;">1N5359BG</a> Mouser stocks both of these&nbsp; (currently). I haven\'t gotten my parts so I can\'t guarantee these will work, but I\'m pretty sure. I will try the latter first as I\'m hoping it\'s higher power rating will keep it from burning out again, although I will be buying several spares. <br><br>This is clearly a design issue with these toasters and one that could be easily corrected. Both circuit boards in my toaster are very toasty in the area of these diodes, although I\'m sure the fact that these boards are mounted very close to the heating elements doesn\'t help their longevity.<br><br>Hope this helps everyone.
Sep 27, 2008 | Hamilton Beach 22502 Digital 2-Slice...
T-Fal Avante Bagel Tpaster - 4 slice
Energized coil (Magnet) which holds down lever mechanism may be coated and in need of scraping for it to make full contact
May 01, 2008 | Tefal Avante Deluxe 4 Slice Toaster
Nov 05, 2007 | Hamilton Beach 22505 IntelliToast 2-Slice...
Duraband 4 slice toaster manual model # TS-5221
if u need a manual for a toaster, then u r really in trouble...espcially for the amt of money u paid for it.
ok...
if u need instructions on how to use a toaster...here goes:
When:
A toaster is used to heat slices of bread, bagels, waffles, etc. to a hot, crispy consistency. Most toasters allow the user to set the toasting length to ensure the toasted bread comes out to temperature and crispiness to the user’s likes.
Where:
Toasters should be used on a flat, uncluttered surface near an electrical outlet but far from sinks, or running/standing water.
How:
To toast bread in a toaster, follow these instructions:
1. Place slices of toast, one each, in the slots on the top of the toaster.
2. Find the toast setting (a knob or lever) and adjust to the desired wellness of the toast. (Generally, there is a scale printed near the knob or lever ranging from light to dark toast).
3. Push down the toasting lever (moving the slices of bread down into the toaster between the heating elements.
4. When the toast is finished, the slices will “pop” up automatically.
5. Remove the toast from the toaster.
WARNING:
If the bread should get stuck inside the toaster, DO NOT PUT ANYTHING INSIDE THE TOASTER in attempt to dig it out. UNPLUG the toaster, turn it upside down and shake. If the toast does not fall out, use a plastic fork or knife to gently remove it from the toaster. Using metal utensils could damage the heating elements. NEVER stick anything in the toaster while it is plugged in.
*For further safety, it is recommended that the toaster be unplugged after each use.
I wish u luck and happy toasting.
Oct 14, 2007 | Kitchen Appliances - Others
Hamilton Beach (24459) 4-Slice Toaster Logo
59 people viewed this question
Top Hamilton Beach Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
deton8 von Splosion
Are you a Hamilton Beach Kitchen Appliances - Other Expert? Answer questions, earn points and help others
