Question about Whirlpool ED5FTGX Side by Side Refrigerator
Freezer and refrigerator both quit cooling
We first noticed that the ice was melting and then that no cooling was occurring at all. It sounds as if the compressor is trying to run but isn't doing so properly or consistently. Lights inside both sides are working.
  • MarkaKinzie May 31, 2008
    Is that something I should look for externally, or do I need a repair-person?
  • 2,322 Answers
Before you decide to call a repair person, you can read the info from this website.
Check the info from this website to know what is involve in checking the compressor.
Posted on May 31, 2008
    Brigadier General:
  • 3,614 Answers
Theres a possibilty that it was a loose compression on your ref
  • micromaster
    micromaster May 31, 2008
    if you have an idea on how to do the job, it is possible you can work on the unit.. the compressor unit must be check on this kind of fault.. checking also the electrical system on the unit that can be also the cause of the loose compression..
    if you have no background to repair and service the unit, it is better to call someone in your area who has the expertise to troubleshoot & repair which part is defective..
    thank you
GE Refrigerator, ice melts in ice bin, Excessive heat on refrigerator side
Do you see any ice buildup on the back wall of the freezer or behind it?
Dec 09, 2012 | GE Refrigerators
Freezer stays cool but bottom stays warm.
I agree with your analysis, and recommend that you replace that fan between the two sections.
May 20, 2008 | Kenmore Refrigerators
Suddenly, the temerature of the refrigerator and freezer went up to the point that the ice cubes and ice cream melted. Sounds like the compressor is working. I may have left a door ajar for quite a few...
try unplugging it for a day a so to let the evaporator coil defrost. When left open for long periods the evaporator coil will build too much ice blocking air flow. You might have apuddle of water under the fridge after the melt. -->
c_getProfessional_AskGet_refreshPicture(); if (!window.unique_ord) { unique_ord=Math.random()*10000000000000000;}document.write(''); 817-grey.gif
May 22, 2011 | Kenmore Side by Side Refrigerator
My Kenmore Elite refrigerator doesn't cool enough, but the freezer feels ok. Here is the story: A couple of years ago I noticed that ice was accumulating at the bottom of the freezer, in a small bay...
There are two things that could be happening...
The hole is plugging up and the wtarer is not running away when it defrosts...
or the defrost control is not working correctly all of the time...
These tips cna help you to figure out the exact problem...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 07, 2010 | Refrigerators
On June 5 had ice and frost buildup in the back of the freezer - that caused the refrigerator not to cool the food. Shut off and melted all the ice. Turned back on and has worked. Now just noticed ice...
Have you cleaned to condensor coil on the back of the box at the bottom where the compressor is at take a vacuum cleaner and clean the coils see if this helps sounds like you have an airflow problem.
Jun 29, 2010 | Maytag 22 cu. ft. Bottom Freezer...
Area around freezer door is very hot to the touch. ice maker works, but after awhile the ice will melt. freezer is freezing.
HI, That area being hot is a sign the refigerator is not cooling properly. We need to pin point the cooling problem.
First, are you noticing any frost build up inside the rear freezer panel?
Are the fans and the compressor running?
Please let me know so I can assist you through this.
Vic
May 27, 2009 | Refrigerators
Freezer quit then noticed fridge side not cooling
the relay on your compressor is bad go behind you refrigerator and take off the the bottom panel the relay is on the left side of your compressor usually
Dec 29, 2008 | Whirlpool GD5SHAX Side by Side...
Fridge & Freezer not cooling
i think you have a bad compressor pull it out and take off the back panel and feel the compressor if it is hot and making a bad sound it might be an over load relay
Dec 11, 2008 | Frigidaire PHS67EHS Side by Side...
Error Message ER FF
The refrigerator has noticed the freezer fan is not responding. Need to replace the fan motor. Also called evaporator fan motor.
Oct 09, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Whirlpool ED5FTGX Side by Side Refrigerator Logo
90 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
