Question about Philips SA1100 MP3 Player
Seperate Playlists Is there anyway to make seperate playlists with this mp3 player?
  • 8,596 Answers
Use Windows Media Player to create the playlist, and then transfer them to the player by dragging the entire folder to the sync window, instead of dragging all of the files within the playlist to the window.
Posted on May 31, 2008
I cannot seem to arrange my music into playlists. All songs play, but not in any playlists. How can I divide my songs into playlists
To create a playlist - In your media player highlight the song * right click mouse* choose playlist and name song
Apr 06, 2011 | SanDisk Sansa E280 MP3 Player
How to seperate music files. I would like to add individaul playlists. Instead of all songs grouped together and you have to shift through all songs to get to the one you want.
Hi shannitar,
You can try placing the music files in different folders. If your mp3 player supports playlists (which it should), then go to the folder where your music files are kept, use ctrl+ click to select those you want to add to the playlist IN THE DESIRED ORDER, then right click and choose "creat playlist". A .pla file (or any other extension) will be created, which you can now play on your mp3 player.
Oct 17, 2009 | GPX Audio Players & Recorders
Music from burnt cds...won't go to assigned folder
thats the way the software works. I'd suggest using an option like within winamp - where it looks for media tags and fills in all the appropriate information as to artist and genre for you. Winamp will do this with songs that have absolutely no information in them whatsoever (like burns) but it cant with homemade files like your buddy's garage band. The only way to seperate it besides folders is within playlists.
Jan 02, 2009 | SanDisk Sansa e250 MP3 Player
Making playlists
yes you can create playlist using WMP11...
To create playlist using WMP
  1. 1. Click the Library tab. If you need to clear the List pane before beginning to create your playlist, click the Clear List pane button playing_i_clearlistpanebtn.gif.
  2. Drag items from the Details pane to the List pane to add them to the new playlist.
    To select multiple adjacent items, press and hold the SHIFT key while selecting. To select nonadjacent items, press and hold the CTRL key while selecting.
  3. To rearrange items, drag them up or down in the List pane.
  4. To save the list, click Save Playlist at the bottom of the List pane, and then type a name for the playlist.
    By default, playlists are saved with a .wpl extension in the Playlists folder, which is usually located in the Music folder. You can also save playlists with the .m3u or .asx extension. To do so, click the List button at the top of the List pane, click Save Playlist As, and then change the extension in the Save As dialog box. Once you save the playlist, it's added to the Playlists category in the library.
    To play the playlist in the List pane, click the Play button playing_i_playbtn.gif.
  5. To access the playlist in the future, click the Playlists view in the Navigation pane.
I hope that helps
Please rate accordingly
Thank you
Computerrep
Jul 19, 2008 | SanDisk Sansa Connect MP3 Player
Probelm with playlists
The Vista compatible software may work different, but I have mine set to Repeat OFF, and I have no problem with playlist play. Is it possible that the songs that you put on your playlist are in the wrong format? If they were streaming files, or DRM-encrypted WMA's, there may be issues with playback. Convert the songs in your playlists to mp3 format ON THE COMPUTER, and then delete the playlists that are not working OFF YOUR SANSA. And then re-add the playlists to your Sansa.
-Tha Mp3 Doctor
Jun 03, 2008 | SanDisk Sansa Clip MP3 Player
Custom playlists
3346 automatically changes the playlist to alphabetical format - sorry
Mar 04, 2008 | Philips GOGEAR SA6045 MP3 Player
"Playlist On The Go" on a Philips 4 GB SA6045 mp3 player.
I just figured out how you clear the songs from the "playlist to go". go to playlist to go, then when it shows the songs you have added press the up button and you will see the words "clear playlist to go", press the forward button and it will ask you to clear it or cancel, select clear and it will tell you it's cleared.
Dec 15, 2007 | Philips GOGEAR SA6045 MP3 Player
Two ipod products on one pc
Hello there! There are a few different ways you might solve this problem. The easiest thing to do would be for you and your husband to each create your own playlists. Consider putting your initials in front of the name of each of your playlists, and your husbands initials in front of his, so that in an alphabetical list, you wind up with all of yours grouped together, and he has all of his grouped together. Now it's time to connect each iPod in turn. When you connect yours, click the iPod icon in the left hand column (the 'sources' column), and click through the tabs to the right until you get to the screen where you can choose to sync 'all playlists' or 'selected playlists'. Click on 'selected playlists' and then check off all of yours (or whichever you'd like at the time, if you have more music than will fit), none of his. When your iPod is done loading up that music, go ahead & disconnect it. Now repeat the process for your husband's iPod, selecting his playlists but not yours. From that point forward, when you plug in each iPod to sync with your library of music, it will remember which playlists it is supposed to sync with, and which it should ignore. Just remember that if & when you create brand new playlists in the future, you'll need to go back into the iPod settings to tell iTunes to sync that new playlist with your iPod (this can be done only while your iPod is connected). Hope this gets you where you were looking to go... best of luck!
Sep 28, 2007 | Apple iPod shuffle Second Gen. Silver (1...
Playlists
I found a little problem with this too. So I created a folder to put on my storage card. Name it whatever you want. Now take these steps to get to it to play all the songs in the folder: When you are in Windows media player, click menu, open file, storage card, The name of your folder. You should be setup to play all those songs as a playlist now. Hope this helps, I haven't messed with it anymore so I've stuck to it doing this. Good luck.
Jul 22, 2007 | Samsung Blackjack SGH-I607 Smartphone
Philips SA1100 MP3 Player Logo
97 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
