Question about Kirby Generation 3 Bagged Upright Vacuum
Kirby G3 made loud noise when running. Sprayed silicon in fan thinking it might be a bearing. Found a coin and nail in fan and removed. Tha vacuum would not turn on. Replaced switch and brushes. Still nothing. Did the silicon spray do something?
  • rclester Oct 13, 2010
    found broke wire on stator of motor
  • 11,800 Answers
No - the silicon is an insulating material and would have no effect on the electrics of the vacuum. Most likely you have a bad connection - dismantle the vacuum again and check the wiring and the motor with an ohmmeter. Be very attentive with the brushes, if they don't sit perfectly on the collector the motor will not run.
Posted on Oct 10, 2010
How to remove a Kirby Heritage II Armature
The armature that holds the fan on is reverse threaded. It turns to the right to remove it. You can put a nail or nail punch in the hole on the armature and tap it gently to the right. this should loosen it enough to unscrew. There's a washer, then the fan, and a spacer that fit over the shaft.
Sep 02, 2012 | Kirby Heritage II Vacuum
My Kirby g3 is making a loud noise and the Fan is stoping to fast
POSSIBLE CAUSES: 1) Sometimes there is a piece of debris in the fan case. (Not likely, but possible) Take the power head, handle and cloth bag off of the Kirby, pick it up and turn it with the fan toward the floor and shake it to see if something falls out.
If there's nothing in there and it still makes the noise, you most likely need to replace the fan/impeller as it is probably cracked or broken. You can sometimes see fan damage by removing the power head, looking into the hole in the front of the Kirby and slowly rotating the fan by using the shaft in front. The damage can't always be seen that way, but if you can't see it, you'll need to take the fan case off so that the whole fan is visible to make sure. I have written complete instructions that should lead you through the whole repair.If neither of these things are found to be the case, check the carbon brushes. I don't have a guide written for this yet, but my switch repair guide (link below) will help you break down the Kirby to get to them. Unscrew both brushes, take them out and look at them. The remaining length of brush will pop out of the holder and if they are shorter than 1/2 inch long, I recommend replacement. (they are not expensive)
Jan 15, 2011 | Kirby Ultimate G Bagged Upright Vacuum
Our Gen3 Kirby still works but is extremely loud not - I am currently only using with the wood floor attachment (no brush) - thoughts?
this could be the impeller fan next to the motor shaft under your attachment hose connection.
to determine this, remove the hose from the unit, and turn the fan shaft with your hand looking down inside the unit. You should see blades on the impeller fan, and they should all look squared off and curved. If any of them are broken or worn, it will make the unit louder than normal.
Also, the hose attchment has an increased noise more than using the brush attchment anyway because it increases the suction for the hose more than on the carpet. IE the motor runs faster giving you more suction.
An Impeller fan for the G3 Kirby will run about 18-39$ for the fan. More for labour.
Good luck,
Mark
Nov 07, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Kirby G4 motor is very loud. It has suction but seams to be a lot louder than when we bought it in 1996.
Hi There,
Most likely it's just the fan that is making the noise rather then the motor. The way the Kirby vacuums are designed, anything hard that's vacuumed up such a coin, or other hard things can break the fan.
In order to check and see if it's your fan, remove the front part of the vacuum that contains the roller brush and belt. If you're not sure how to do this, here's a video that shows you how to change the belt, but will also explain how to get the front bell shaped housing off:
Once you have the front cover off, look inside the vacuum directly behind the motor shaft. You will be able to inspect the fan here. Turn the motor shaft which also turns the fan, and see if there's any cracks, or if the fan blade is broken. I think most likely you'll see the fan damaged somehow.
Here's a video repair that we've put together that explains step by step on how to replace the suction fan on your Kirby:
Part 2:
Hopefully this helped you fix your Kirby. Please be so kind and rate the repair, or leave feedback if this was helpful to you. Thanks so much,
Chris Jones
GoVacuum.com
May 02, 2010 | Kirby G4 Bagged Upright Vacuum
G5 Kirby Vacuum...makes a loud noise on initial startup and then runs smoothly...it does this for both the attachment and powerbase...I cleaned out the passageways...Im thinking its the belt but if thats...
check your fan for stress cracks around the center, rotate while off for resistance or any noise. these frequently crack and rub against the inside of the housing. also listen and feel for bad bearings
Dec 29, 2009 | Kirby G5 Bagged Upright Vacuum
My Kirby G3 makes a loud, high pitch whistle with the hose
I would say you either have something stuck on the impeller or there is a piece of paper or something stuck inside the hose. its not clogging the hose but when the air passes by it. It is making that noise. If you find nothing you may need a repair. May have a bad bearing in the motor. Actually you can also try inspecting the brush on the head. It removes easily from vacuum and should spin freely and quietly.
May 04, 2009 | Kirby G5 Bagged Upright Vacuum
Kirby genernation 3 maintenance
HI
There is no oil needed on this model.
Chances are the fan is either cracked, chipped or broken and needs to be replaced
All the best
Rob
Feb 10, 2009 | Kirby G4 Bagged Upright Vacuum
Kirby making clicking noise
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=667246
Generic problem for all Vacuums
Posted by jenad on Jun 12, 2008
In the middle of vacuuming my car out, my Kirby Sentria began making a loud clicking noise, sounds like it's coming from the motor. It's never done this before. I checked for debris in the fan and removed the bag and checked there too. The vacuum still works, just not sure if I should continue to use it.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The clicking noise sound s to me that it is coming from the motor like you said and I am not sure how new the Kirby vacuum is, but if it is still under a factory warranty it is a good idea to have Kirby take a look @ the vacuum because it could be the fan, carbon brushes or something could be hitting the armature making a clicking sound and if it is the armature then I would get it check ASAP. Feel free to contact your local factory authorized Kirby dealer in your area and also I will give you the website and the customer service phone # to Kirby for further assistance. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/ Customer Service – United States & Canada 1-800-494-8586
Hours 8:00 am to 5:00 pm (EST) U.S. & Canada Fax # 1 (216) 529-6146
Mail To:
Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 12, 2008 | Vacuums
Kirby Generation 3 Bagged Upright Vacuum Logo
340 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
