Question about Cuisinart DGB-600 Coffee Maker
We recently purchased a refurbished Cuisinart DGB-600 Coffee Maker at a yard sale. So far, we've had three batches of horrible coffee that tastes more like water with coffee flavoring. The first two batches were done using the built in grinder and the third with preground coffee. I've cleaned the removable parts, rinsed out the reservoir and am now running through a vinegar and water mixture to hopefully remove calcium deposits. Any tips?
  • 3 Answers
It sounds like the water isn't flowing through the coffee grounds correctly. Perhaps you don't have the right kind of filter installed (either the right-sized paper filter, or the "gold" filter that comes with the machine) ... or, if uising pre-ground coffee, and if the coffee is all in a pile in the middle of the basket... the water will follow the path of least resistance, so much of it may run "downhill" and around the coffee, through the filter and into the carafe, without passing through the coffee. (That would be more likely if you're brewing only a few cups rather than a full pot.) Or, you might not be using enough coffee; I would use about 7-8 tablespoons of ground coffee for 10 cups of water. I'd recommend getting it working properly with pre-ground coffee before trying the grinder. It's also important that the lid of the carafe is in place while brewing, and that the carafe is fully seated in its chamber; the bump on top of the carafe's lid triggers a spring-loaded mechansim on the bottom of the basket, which regulates the flow of water into the carafe... so if any parts of this system aren't lined-up right, you may get unexpected results (including, in some cases, water all over the countertop).
I also recall, once upon a time, using one of those pre-packaged "packets" of coffee... sort-of like a large tea bag full of coffee grounds... and getting unsatisfactory results; again, the water found it easier to run over/around the coffee packet, rather than through it.
Posted on Oct 14, 2010
I have a cuisinart grind & brew coffee pot that leaks when I put water in it. How can I open it to see where the water is coming from?
The Manual for your coffee maker can be found here:
http://www.cuisinart.ca/pdf/ibs/en/DGB-600BCC_en.pdf
'Leaks' are usually caused by overfilling either the water reservoir or the coffee basket or by coffee grounds interfering with a seal.
Make sure you perform a complete cleaning on your coffee maker making sure any contact points which need to seal are free of coffee grounds.
Instructions for removing the grinder and filter baskets are contained within your manual.
Feb 06, 2011 | Cuisinart DGB-600 Coffee Maker
Need instructions to operate DGB-600BC
Thanks for the reply. Got rid of the coffee maker. Its a dud. No more information required.
Jun 18, 2009 | Cuisinart Thermal DGB-600 Grinder
Wattage of a Cuininart DGB-600
The consensus seems to be that it is 1025 Watts, although I have a hard time believing it - not even a stand mixer is 1025 watts.
Apr 01, 2009 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Cuisinart dgb-600 brew pause feature doesn't work
Replace the filter basket - they can be had for around $6.00 plus shipping - you can even get them directly from Cuisinart.
Jan 23, 2009 | Cuisinart DGB-600 Coffee Maker
Need schematic to reassemble...
The filter basket is orderable from Cuisinart and costs somewhere in the neighborhood of $5 to $6 - there is no service manual for that particular part of the coffee maker.
-Tha Mp3 Doctor
Dec 05, 2008 | Cuisinart Thermal DGB-600 Grinder
Coffee maker turns off
Turn on the Auto-Off feature - it should display "2:00" - press the hour button twice and change it to "4:00" - it will now go off after every 4 hours - that is the maximum time period allowed by the coffee maker.
-Tha Mp3 Doctor
Nov 22, 2008 | Cuisinart DGB-600 Coffee Maker
Where do I purchase replacement charcoal water filters for my coffee maker?
Cuisinart DGB-600 replacement charcoal water filters is Cuisinart DCC-RWF 6 pack charcoal water filters, 12 filters.
Oct 17, 2008 | Cuisinart DGB-600 Coffee Maker
Cuisinart DGB coffee maker
there is two little plastic pieces sticking out of the bean holder and on the coffee maker where the bean holder goes there is 2 holes, take the bean holder and put one piece of plastic in the coffee maker holes at a time and it should fit just fine...
Sep 13, 2008 | Cuisinart DGB-600 Coffee Maker
Suddenly coffee tastes TERRIBLE!!!
First try putting a cycle through with no coffee - see if you have any more luck identifying the taste. If you haven't descaled recently, that could be the cause - scale can hold other materials which can be tasted - run a cycle with 50% white vinegar, then rinse through a couple of times and see what you get - if you need to get rid of any vinegar taste, just run a cycle with a couple of teaspoons of bicarbonate of soda through. The water could still be to blame - even purified, there are certain things that can change that most purifying methods will not remove, such as higher salt levels during summer months etc. Make a cup of coffee without the machine at all, and see if you get the same aftertaste. The machine may not be to blame. Hope this helps, please ask again if you need more info :)
Sep 09, 2007 | Cuisinart DGB-600 Coffee Maker
Cuisinart DGB-600 Coffee Maker Logo
155 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
