Question about Toys
I have a maxi cosi easy fix base and i'm not sure if the leg is fitted properly. I'm using it with the iso fix which i have got in with no problems. In the instructions it says the leg on the front will lock in the down position which it doesn't. I have checked underneath and it doesn't appear to even have a locking mechanism at the hinge. I have extended the leg so it is firm against the floor and the indicator on the foot is green but it is not locked at the hinge and therefore will moved is sufficient pressure is applied. Could you give me some advice on what is the correct way for the leg to be when the using the base with iso fix?
Babycare_nl
  • 21 Answers
SOURCE: Have purchased Maxi Cosi baby restraint with Easy Base - Iso fix,
The Maxi Cosi CabrioFix and EasyFix can only be used with IsoFix or the seat belt on (preferrably) the back seat. Please don't alter the mounting system of the seat as it will give unpredicable results!
The Commodore name has been around since 1978 so it is possible when you own an older Commodore you won't have any means to fix the Maxi Cosi seat.
If you do have IsoFix and/or seat belts in the back seat then please elaborate on the exact nature of the problem.
With kind regards,
Babycare.nl
Erwin de Raad
Posted on Jun 23, 2009
SOURCE: Maxi Cosi Tobi straps locked
hi i had the same problem so i took it back to toys r us where i got it from, they rang manufacture and were advised that they r going to recall them as it is a fault. hope this helps
Posted on Sep 19, 2009
  • 419 Answers
SOURCE: maxi cosi cabrio fix fitting to renault laguna
I would suggest that you have this fitted by a trained car seat specialist, but you can check the compatibilty on the Fit Finder on this link.
http://www.maxi-cosi.com/maxicosi/carselector.aspx?language=gb-en
I hope this helps;
Posted on Oct 12, 2009
SOURCE: Is Maxi-Cosi Mico Base compatible with CabrioFix?
No, they are not interchangeable.
Posted on Jan 05, 2010
SOURCE: hi i bought a maxi cosi cabrio fix car seat and it
hi
NO THIS IS A CABRIO CARSEAT NOT A CABRIOFIX SEAT SO IT WONT FIRT ON THE BASE ONLY FIT THE CAR WITH A SEAT BELT
Posted on Jan 24, 2010
We have just had our 2nd Child and strated using our current Maxi Cosi Cabrio Fix Seat with Iso Fix base. However, it has stopped clicking into the base! We know it previously worked, but the small
Hi
The Maxi Cosi CabrioFix carseat can be used with the EasyFix or the FamilyFix base (both fitted with IsoFix)
In the event that the seat will not click into position on the base it will need inspection / repair work.
If you're in the UK and the product is under 2 years old, please contact your retailer with your proof of purchase and they can arrange for it to be sent to our engineers for inspection / repair work required under warranty.
If you're in the UK and the product is over 2 years old or you no longer have proof of purchase please contact the customer care team on 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays) to discuss booking it in for chargeable inspection / repair work required.
If you're outside the UK please visit www.maxi-cosi.com and select the country you're in, then use the "Contact Us" tab on the right side for your enquiry to be sent through to the customer care team in your country.
Jan 01, 2013 | Maxi-Cosi Cabrio Red Flame Reflection...
Does maxi cosi cabriofix easy base require anything to be removed from it before fixing it? we cant find where the button is that fixes it to the seat
Hi
Can you clarify - what button are you looking for?
The EasyFix base is fitted into the vehicle using the IsoFix points OR the 3 point seabelt. (Never both) The carseat then clicks onto the base and the metal rods on the underside of the CabrioFix carseat are grabbed by clamps on the base.
May 26, 2012 | Maxi-Cosi Maxi Cosi Mura 3 with Free...
I cannot get the support leg for my maxi cosi base detached. Any ideas
The support leg on the base cannot be detatched. It is part of the safety feature on the base and should not be removed.
Nov 07, 2010 | Maxi-Cosi CabrioFix (Black Reflection)...
I have a maxi cosi cabriofix and need a base to go with it. Which base fits this model? What is the difference between the easy base and easy fix? My car does not have the iso fix adaptors so that will...
The Maxi Cosi CabrioFix can be fitted using the EasyFix base (IsoFix or seatbelt fitted) the EasyBase and EasyBase 2 (fitted with seatbelt only) or the FamilyFix base (IsoFix only). If you do not have IsoFix points you need either an EasyBase or EasyBase 2 to be fitted with seatbelt.
Sep 25, 2010 | Maxi-Cosi CabrioFix (Black Reflection)...
Maxi cosi cabrio fix fitting to renault laguna
I hope this helps;
Oct 07, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
What's the difference between Easybase (non isofix) and Easyfix base (isofix)? can I use the second one for both maxi cosi cabriofix and car seat up to 3.5 year?
The Easy Fix Base is used for cars which have isofix points in their car. The Easy Base fits into your car using the seatbelt.
Both of these bases can be used ONLY for the CabrioFix Carseat and cannot be used for the next stage seat (Group 1).
I hope this helps.
Sep 25, 2009 | Maxi-Cosi Baby Gear
With kind regards,
Babycare.nl
Erwin de Raad
Jun 17, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
Which car seat fits the Quinny zapp
Hi, all the maxicosi carseats will fit onto the zapp using the adaptors that come with the zapp pushchair (but not the newly rebranded bebe loola).
The difference between the maxi cosi cabriofix and the ordinary cabrio or citi is that the cabriofix can be attached to the maxicosi in-car seat base (easybase or easyfix), whereas the cabrio and citi can only be fitted in the car using the cars seatbelts, they wont attach to the incar base. Hope I have helped a bit x
Aug 31, 2008 | Quinny ZAPP Stroller
Toys Logo
37 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
