Question about Brother LS-2125 Mechanical Sewing Machine
The bobbin mechanism wont spin - Brother LS-2125 Mechanical Sewing Machine
    Genius:
  • 1,788 Answers
Do you mean that the thread is not pulling up? I don't understand, if you have it threaded right and the thread can be pulled when it is in the casing how can it not move? Or are you trying to wind a bobbin? Please restate your question, no one can help unless you are clear.
Posted on Oct 10, 2010
  • Maggie Coyle Jun 26, 2013
    the shuttle that the bobbin and bobbin case sit in will not spin
    the hook and base housing where the bobbin and bobbin case sits into wont spin
My bobbin winder wont spin''? Kenmore model 1931
Here's a quick fix until you can get to a mechanic. Alternatively use the bobbin winder on another machine if you have one.
https://youtu.be/CtsQyGJkRQ4
Oct 02, 2017 | Sewing Machines
5050c bobbin wont wind
The pickup wheel under the bobbin stem may be worn and needing to be replaced (assuming it has not been knocked and bent off line) .
Try using a pen to push the bobbin stem further over when you are trying to wind it. If it starts to spin, then this is probably the answer.
Jul 13, 2016 | Singer 5050 Mechanical Sewing Machine
After replacing the bobbin the sewing hook/bobbin doesnt turn anymore. It will spin if you turn the wheel backwards but it wont do anything when turned forward.
Did the machine get jammed? Maybe the timing belt clutch came disconnected. Look on the bottom of the machine while turning the hand wheel and see if the lower horizontal shaft is turning at the left end. If not, you have to regage the clutch. Let me know if this the case.
Apr 25, 2011 | Consew 255RB-3 Mechanical Sewing Machine
The needle will move but bobbon wont spin
If the mechanism that the bobbin case it attached to doesn't move at all, you have a problem in the drive system of the machine. Either a screw has loosened in one of the gears or in the linkage to the bobbin area from the top of the machine. Unfortunately a trip to your service tech will be needed.
Oct 07, 2009 | Brother LS-2125 Mechanical Sewing Machine
Bobbin spindle won't spin
Check the bobbin winder rubber, it may be worn or broken and insufficient friction against handwheel to turn.........or a thread jam around spindle is stopping the spin. In this case, carefully unwind, DO NOT cut thread.
Sep 01, 2009 | Necchi 3537 Mechanical Sewing Machine
Bobbin pole for putting more thread on wont spin fast tried to reload bobbin but machine wont spin bobbin fast enough to put thread on it
most likely you do not have the correct bobbin that fits on the bobbin pole.
on the bottom of the pole there may be a small knub in which the small hole on the bobbin should slip onto this holds the bobbin in palce, (if the wrong bobbin is used and if could be just a slight difference in the boobin ) the pole will not spin correctly and not fill the bobbins,
I have seen different bobbins with the same machine with such a slight difference that the owner did not realize it.
Aug 29, 2009 | Kenmore Sewing Machines
When winding the bobbin the bobin wont spin ,the motor runs but wont engage the winding mechanism
Make sure you either tighten the knob or push in the wheel on the right end of the machine, at the hand feed wheel.
Aug 13, 2009 | Brother Sewing Machines
Bobbin filling
Does the winder spin freely by hand? If so then it needs to be adjusted, maybe a new bobbin tire also. If not then try oiling it and freeing it up by hand.
Hope this helps.
Jan 30, 2009 | Singer 7442 Mechanical Sewing Machine
Cant get machine out of neutral after threading the bobbin
there should be a way to disengage the bobbin winder. I had a machine that had a switch in the center of the handwheel and even though it would be in the off position I still had to turn the handwheel till it clicked.
Dec 15, 2008 | Necchi 3537 Mechanical Sewing Machine
Bobbin wont spin
I had the same problem last night but was able to solved it by flipping the plastic bobbin over and re-seating it on the post. This time it clicked in and I was then able to get the post to spin. Good Luck!
Jan 07, 2008 | Janome D'cor Excel 5018
Brother LS-2125 Mechanical Sewing Machine Logo
76 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
