Question about Whirlpool LER5636P Electric Dryer
Dryer will not run
Dryer will not start at all. I have checked power, door switch, thermal fuse, start switch.
  • Jfarmer Jun 02, 2008
    It was a loose wire on the timer.
    Thanks...
    Scholar:
  • 110 Answers
Did you check your thermal safety, pwr cord, recepticle, are you getting 220v ?
Posted on May 31, 2008
Kenmore 97478100 dryer will not start (not a heating issue)
HI, check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer or control board
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse
Oct 08, 2009 | Kenmore Dryers
Dryer doesn't start
3. Thermal fuse
Oct 04, 2009 | GE Dryers
Why is my gew9868kq0 not starting?
3. Thermal fuse
Sep 15, 2009 | Whirlpool GEW9868K Electric Dryer
Dryer will not start, worked all day, changed loads, and would no longer start
3. Thermal fuse
4. Timer
Sep 05, 2009 | Dryers
I have a RES7745RQ electric dryer. The timer
3. Thermal fuse
4. Timer
**The most common issue here will be a defective Thermal fuse, but if all is ok with the above stated areas, replace the start switch.
Aug 19, 2009 | Dryers
Dryer will not start when button is pushed. Maytag model # DE 610
3. Thermal fuse
4. Timer
Aug 18, 2009 | Dryers
It will not start. We checked the plug and the circuit breakers and it will not start in any cycle
3. Thermal fuse
4. Timer
Jul 25, 2009 | Dryers
Dryer wont start,
3. Thermal fuse
4. Timer
Jul 24, 2009 | Bosch WTMC652SUC Gas Dryer
Whirlpool electric dryer (Model # LER4634DQO). Dryer won't come on when we push the start button.
The dryer would not start with a broken door switch. Replace the door switch if found defective.
3. Thermal fuse
4. Timer
Jul 08, 2009 | Whirlpool Dryers
Dryer wont start
Check the following to address this issue.
3. Thermal fuse
4. Timer
Jun 03, 2009 | Kenmore Dryers
Whirlpool LER5636P Electric Dryer Logo
37 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
