Question about Acer Aspire 5610-4648 Notebook
TOUCHPAD, MANUAL KEY PAD QUESTION
I WENT UNDER YAHOO ANTI-SPY AND INSTALLED THEIR NEW SOFTWARE. THIS IS THE ONLY THING THAT I DID BEFORE MY LAPTOP FAILED TO ALLOW ME TO USE MY TOUCHPAD OR THE MANUAL KEY BOARD TO WORK.
I HAVE TRIED TO PRESS ALT+F10 AT STARTUP TO RESTORE TO FACTORY DEFAULTS. I HAVE REBOOTED SEVERAL DOZEN TIMES. MY COMPUTER COMES UP AND ON THE LOGIN SCREEN WHERE I AM S'POSE TO ENTER MY ADMINISTRATIVE PASSWORD, I PRESS ENTER AND I TRY TO ENTER THE PASSWORD BUT NOTHING IS TYPING.
HELP!!!!!!!!!!!!
  • kubis May 11, 2010
    did you try to press F8 when after ACER logo disappear and choose to start from last known good configuration, or in safe mode? when you talk about restoring into factory settings - do you mean the OS is restored from restore disk (in other words new windows settings)? If it doesn't work even after this...then it has to be very strange if you are able to write from keyboard when you are not in your OS. I would bet it should be OS problem.
    Sergeant:
  • 458 Answers
Boot into safe mode and uninstall the yahoo software that started the problem.Press F8 at start up.
Posted on May 31, 2008
  • T&N Family Electronics Dean and Sherrie Terrell
    If this will not uninstall in safe mode try it in normal mode.
    Can you please let me know if this solved your problem?
    Rate this as a fixya if your problem is solved please.
    If you need more help let me know.
I turned off my touch pad to my acer aspire 5733z and it wont turn bk on
Locate the "Fn" key in the lower right or left corner of the laptop keyboard.
The "Fn" key typically has different colored text on it or the key itself is a different color.
Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works.
Press the combination at any time to disable the touchpad again.
hope this helps
Sep 16, 2012 | Acer Aspire 5733z-4851
Tip
How to Fix Touchpad on a Laptop
<p><span>The touchpad of your laptop is a most important and frequently used input device. If your touchpad stops functioning, it may be difficult for you to use your laptop. Touchpad normally faces following issues. <br /><br /><b>Laptop Problems and Their Solutions</b><br /><br /><b>Problems with the driver</b><br /><br />Computer hardware communicates with your computer through real time software called driver. Drivers control computer hardware. It is possible that virus or human activity may damage the driver. You can check your driver's status through computer's device manager. You'll see a yellow color indication under "Mouse and other pointing devices" heading. You can download new driver form your laptop's manufacturer website. <br /><br /><b>Problems with connection</b><br /><br />Touchpad's connection with motherboard is delicate. It can be broken due to heating and other inner problems. So, if there is no problem with the driver, then the connection of the touchpad to the motherboard may have broken. <br /><br /><b>Misuse</b><br /><br />Touchpad of the laptop is the most delicate input device. Some people tap on it too hard or use a shrill tool as an alternative of a finger. This can damage the pad. <br /><br /><b>Fn Keys</b><br /><br />Touchpad driver is slightly different from the other devices that need drivers to function properly. It came with an operating system that you don't need to re-install it. Laptop keyboard comes with many functions than the common keyboard. It has Fn keys which are called function keys. Sometimes, your laptop's touchpad stops working because you accidentally hit some one of the Fn keys. You can follow these instructions to make your laptop touchpad working again. <br /><br />1- Search for Fn key on your laptop keyboard. It is commonly located next to the Ctrl key. <br />2- Now search for F1 to F12 keys on the laptop keyboard. These keys control sound, brightness of the screen, wifi etc. They are located on top of the keyboard. Look for the key which has icon on it that looks similar to the touchpad. <br />3- Let's take an example of Toshiba laptop. It uses F10 key to enable or disable touch-pad. Hold down Fn key along with F10 key to enable the laptop touch-pad. <br /><br /><b>Cleaning the laptop touch-pad</b><br /><br />It is a good practice to clean your laptop touchpad. To clean it, take a cloth dampened with sprit. Wipe your touchpad off with that cloth. <br />Laptop touchpad work best in moderate temperature and gasping environment. Moisture, excessive heat, can damage it. Try using your laptop with tidy hands. Sweaty and dirty hands can cause problems. <br /><br /></span><span><span> </span></span><br /><span><br /> </span>
on Jan 06, 2011 | Computers & Internet
My touchpad on my compaq laptop will move but will not move in the direction im moving it to instead it goes all over the screen
Try cleaning the touchpad off, and if that does not work talk to the place you bought it from about getting a new touchpad installed. However it could be a software issue, restart your laptop and run an antivirus scan.
Jul 01, 2011 | Compaq (153515-001) Touch Pad
My touch pad on my hp ProBook4520s is shut off and i dont know how to turn it back on
You will probably have to connect a mouse to get there. Go to start -> control panel -> find the mouse/touch pad link (location may vary depending on your operating system). Within there you will find an option to configure your touch pad. If it is showing that it should work, then there is one of two problems. 1. You have a very nasty virus and should run some anti-malware and anti-virus programs. or 2. Your touch pad no longer works and you'll just have to use the mouse until you get a new laptop (the amount of money you'd have to spend to replace the touch pad is nearly the same price as getting a new laptop) If this post was helpful to you, please rate it. Best of luck to you!
May 03, 2011 | HEWLETT-PACKARD HP ProBook 4520s Notebook
The scroll key on the touchpad in my hp compaq
locate the FN key and the touchpad key usually an F key(F1-F12) press and hold down the FN key and the touchpad key together, release the keys and check the touch pads.
Mar 25, 2010 | Compaq Presario CQ60-220US PC Laptop
Compaq Presario CQ60 touchpad problem.
The touchpad on my Compaq Presario CQ60 has stopped responding
Aug 17, 2009 | Compaq Presario CQ60-220US PC Laptop
Acer aspire touchpad over sensitive
Your laptop should have software pre-installed for your touchpad. This should probably be in the Control Panel. Once you find the software there should be options to change the sensitivity. Hope I helped.
iSpearz.
Jan 11, 2009 | Acer Aspire 5500 5570-2609 Laptop
Spy Sweeper with Antivirus
Spy Sweeper is for spyware and that is not the same as anti virus software..If you do not have anti virus software, you should consider a getting one of the more popular types such as McAfee or Trend PC Cillin.these are two readily available types .. It is good to have both spyware and virus protection and they are not the same.. Hope this helps you..
Sep 21, 2008 | Webroot Spy Sweeper (spysweeper) for PC
Acer Laptop
Hard to understand what the problem is but will try.
run anti virus and anti spy ware programs
remove any programs you have installed just prior to the problem occurring.
remove any new peripherals you have connected,
if you are using a mouse make sure to disable the touch pad.
remove clean and re-insert ram chips,
if more than one ,
try one at a time ,as one may have a problem and need replacing.
that's a start,need more help just ask
good luck
Terry
Mar 25, 2008 | Computers & Internet
Laptop Hangs during voice chat.
I’m going to ask you some questions in order to better determine the solution.
Do you have Yahoo IM 8.1 installed which is compatible with Vista (this will also apply to the other software like G-talk, and Skype)?
When you have your software running (Yahoo, G-Talk, Skupe, etc) how much RAM is being used? CRTL-ALT-DEL to Task Manager and Performance Tab, then under PF Usage, tell me how much MB are you using?
Do you get this ‘hang’ with other software?
How many ICONS are in the right-hand corner of the tool-bar?
Nov 12, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 5610-4648 Notebook Logo
37 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
