Question about Samsung DLP HL-P5663W 56" TV
I have a samsung dlp model hlr4667wax, when first turned on it makes a whistling noise then a buzzing noise any suggestions?
  • 4 Answers
It could be you color wheel try to go bad, however when it does you will lose the picture. If you can repair or fix a computer you can change your color wheel if it goes. Cost Appox $100 you can search by your TV model #
Good Luck!
Posted on Oct 16, 2010
Buzzing sound on samsung
it sounds that u have a color wheel problem my friend
Jan 19, 2010 | Samsung DLP HL-P5663W 56" TV
My tv is making a loud buzzing noise
Bearings in color wheel going bad and needs to be replaced. Call a local tv repair shop on pricing and availability of color wheel for your model and chassis
number.
Dec 03, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung Model HLR4667WAX/XAA is making a buzzing sound
It is likely the color wheel motor making noise
Check this link
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
If it helps be sure to vote/rate me Thanks
Oct 06, 2009 | Samsung DLP HL-P5663W 56" TV
This TV is horrible. I have the same one and not even a year replaced the light bulb twice. Very disappointing for a Samsung.
Sep 21, 2009 | Samsung DLP HL-P5663W 56" TV
Buzzing noise
COLOR WHEEL OR COOLING FANS
Mar 28, 2009 | Samsung HLN507 50" Rear Projection...
46" Samsung DLP Lines & Freeze up
This is a possible fault in the power supply, and can be a problem with some decoupler caps on some of the boards. The vertical bars and unstability are usually attributed to having high frequency noise and or clocking pulses crosstalking on to the power distribution lines that run through the boards. This can be switching power supply noise, or cross-talk from clocking pulses.
Another thing that can cause your described fault is unstable clocking between the devices that are reading and writing to the data busses. There are a number of data busses running through the set for the boards to be able to communicate with each other.
The tech will use the process of board swapping to service the set, and then do the adjustments as necessary to make sure the new boards match up.
Yes... DLP sets are fairly expensive to service!
This is my personal opinion. If the set is out of warranty, I would change for a Plasma or LCD set. If you compare the performance of these to ther DLP, the difference is very big. From what I am seeing from a service point of view, the DLP's are lower in reliability.
Jerry G.
Apr 03, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung DLP - Model HLR4667WAX/XAA
A stuck color wheel can cause this exact problem.
Feb 26, 2008 | Televison & Video
Buzzing loud noise constantly.
I HAVE A RCA 50 HDTV DLP MODEL #D50LPW134 IT MAKE A BUZZING SOUND AND NO PICTURE i CHANGE THE BULB AND STILL NOT WORKING.
cantrin@hotmail.com
Ken
Dec 12, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Samsung DLP HL-P5663W 56" TV Logo
127 people viewed this question
Henry  Thomas
Henry Thomas
