Question about Hitachi Travelstar 5K100 HTS541080G9SA00 80GB 5400rpm 150MBps Serial ATA Serial ATA/150 I... (0A26924FT) Hard Drive
My hard is locked, after swipe my finger ID the laptop starts but the windows password is blocked
Satellite M500 Swipe finger to autorize access or press backspace to enter bios password
F2 access requires pressing backspace and entering the password,windows access requires a registered fingerprint.
May 04, 2014 | Toshiba Satellite M500 M511 M512 M505...
Finger swipe
With the HP finger wipe access, it retains your original typed password as a different user.
Have you tried changing users and entering that password ??
Feb 16, 2014 | HP Pavilion dv2000t Notebook
During starting from shutdown, it askes me for BIOS password or figers swipe.It only accepts a finger swipe and not a password, seems i forgot the password, how can i clear the old password for a new one?
for this you need to remove the CMOS battery which would be inside the laptop
and reseat the same
by doing this the bios password will be cleared
Thak you
Jan 06, 2011 | Toshiba Tecra A7-S712 Notebook
How to switch off finger swipe
Go to control panel, and find the user account settings. Here you can tell the computer not to ask for password or finger swipe when it starts up.
Jul 17, 2010 | Acer TravelMate 5720-6635 Notebook
HAVEA TOSHIBA LAPTOP WITH A FINGERPRINT IDENTIFIER TO OPEN WINDOWS, WANT TO CHANGE THE FINGERPRINT TO MY DAUGHTERS. HOW DO WE ACCESS THIS?
dentifying the fingerprint readerA fingerprint reader provides extra security for the PC. The VeriSoft Access Manager by Bioscrypt uses the fingerprint reader to identify the user, and controls access to Windows or other secure systems. Instead of typing a User ID and password, you can move your finger across a sensor to logon or start commonly used applications. Verisoft Access Manager can manage all of your different secure accounts and the required user names and passwords by recognizing your fingerprint.On HP notebook PCs, the fingerprint reader is a small metallic sensor located near the keyboard or display. By swiping your finger perpendicular to the metallic sensor you can logon to the PC, a network, or open a program. c00897920.gifBefore you can use the fingerprint reader, you must set up the fingerprint reader by registering your fingerprint with the Access Manager. Set up the fingerprint reader To set up the fingerprint reader to recognize a user, the user must have a logon account on the PC and the account must have a password. Multiple users can be registered for the fingerprint reader if each has their own user account.
  1. In Windows, double-click the VeriSoft Access Manager icon c00897921.gif in the notification area of the taskbar to open the My Identity window. Alternately, click Start > All programs > Verisoft > My Identity .
  2. Click Log On to open the VeriSoft Logon Wizard. Click Next to begin.
  3. Enter the User's Windows password in the Password field on the Introduce Yourself page, and click Next . If you have successfully logged on to Windows, click Finish to close the wizard.
  4. Click Register Fingerprints on the My Identity window, to open the VeriSoft Logon Wizard. Click Next to begin. c00897922.gif
  5. Select a finger shown on the hand graphic, and then slowly swipe your finger across the sensor. One of the squares below the hand graphic will change color when the scan is accepted. A message displays if the scan is not accepted.
  6. Swipe the same finger across the sensor again until all four squares change color, then clickNext to register the finger print. If you need to start over during the fingerprint registration process, right-click the highlighted finger on the screen and then click Start Over .
  7. If prompted to register a second fingerprint, click a different finger on the hand graphic, and then repeat steps 5 and 6.
  8. After using the Registration Wizard to registered at least 2 fingers, click Finish .
  9. To set up the fingerprint reader for a different Windows user, log on to Windows as that user and then repeat steps 1 through 8.
After registering your fingerprint you can log off and then use your registered fingers to log on to Windows. Using Fingerprint reader before registeringIf you swipe your finger across the fingerprint reader before it is set up, the Access Manager opens a logon wizard window and prompts you for informa
Feb 03, 2010 | HP Pavilion DV5234US Notebook Laptop
Don't have authorized finger swipe or password.
Hi ginamarieanc,
There is always a password associated with the "finger swipe"
If he somehow managed to setup without a password you would be able to hit the enter key with the password bar blank and get in.
If you get an incorrect password error that means there is a password.
If you could get him to let you in once you could change the password. The only other way is to remove the cmos battery and reset the bios, you would need to disassemble the laptop to do that.
If I was a CSI I would be able to tell you how to lift his print off of a glass of water and make a mold of it(just kidding, I don't think that works)
Sorry I couldn't be of more help but let me know if I can help with removal of the cmos battery.
Please rate this solution.
Lone99star
Apr 23, 2009 | Acer TravelMate 5720-6635 Notebook
I have dv9000 notebook computer. how to config there finger print password
1. In Windows, double-click the VeriSoft Access Manager icon in the notification area of the taskbar.
2. On the “My Identity” page, click Log On, located in the upper-left corner of the page.
The VeriSoft Access Manager Logon Wizard opens.
3. On the “Introduce Yourself” page, enter the user's Windows password, if one has been established,
and then click Next.
4. On the “Services and Applications” page, click I want to, and then click Register Fingerprints.
NOTE: By default, VeriSoft Access Manager requires registration of at least 2 different
fingers.
5. When the VeriSoft Access Manager Registration Wizard opens, click Next, and then slowly swipe
NOTE: The right index finger is the default finger for enrolling the first fingerprint. You can
change the default by clicking the finger you want to register first, on either the left hand or
the right hand. When you click a finger, it will be outlined to show it has been selected.
6. Continue swiping the same finger over the fingerprint sensor until the finger on the screen turns
green.
NOTE: The progress indicator advances after each finger swipe. Multiple swipes are
necessary to register a fingerprint.
NOTE: If you need to start over during the fingerprint registration process, right-click the
highlighted finger on the screen and then click Start Over.
7. Click a different finger on the screen to register, and then repeat steps 5 and 6.
NOTE: If you click Finish before registering at least 2 fingers, an error message is
displayed. Click OK to continue.
8. After you have registered at least 2 fingers, click Finish.
Feb 02, 2009 | HP Pavilion dv9000z Notebook
Injuries and Fingerprint Sensor
fingerprint identification is the new vogue for forgetful people
there will still be a area where you put in a password or pin number to get in that is if you can remember that code
anyway the sensor reads the finger print the same as in the police department and things like scars cuts etc do not alter the over all comparison or your original print to what the new print looks like
Jun 12, 2017 | Micro Solutions Fingerprint (501003) 200...
My Toshiba A205 S4777 won't start up and I can't use the recovery media to fix it.
may be u av change background of d system, right click on d desktop go to properties and change it. its just a guess
Jun 05, 2008 | Toshiba Satellite A205-S4777 Notebook
Computers & Internet Logo
55 people viewed this question
Top Hitachi Computers & Internet Experts
AJMAL KHAN
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
