I JUST BOUGHT YHIS WIRELESS ROUTER AND IT SAYS CAN'T FIND ETHERNET , WHICH IT IS ON
  • Computers & ... Master
  • 5,660 Answers
Eyeelaine did you set it up correctly?
Wireless router setup,
http://www.youtube.com/watch?v=menFtdWGdHo&feature=related
Posted on Oct 10, 2010
I just bought a laptop computer and I already had a desktop. My internet provider is Hugesnet Satelite. I bought a Netgear N600 wireless dual band router thinking I could just hook it up to my desktop...
The HN9000 should have an ethernet port. You will require two ethernet cables to connect the desktop to the router.
1. Connect the ethernet cable from the Modem to the Ethernet Input port on the Router (It is generally placed away from the other ports on the back of the router.) 2. Connect another ethernet cord from one of the output ports on the router to the desktop computer. 3. On the laptop, turn on your wireless card. The process for this differs from computer to computer. If you were to provide the model of laptop, I could provide you specific instructions. 4. The network setup should be complete.
If you need more help, let me know by replying to this solution. Thank you for using FixYa!
Apr 01, 2011 | NetGear Computers & Internet
I bought a Belkin Basic wireless router. How do I connect it to my modem if there is only one ethernet port in the back?
This is a wireless router. The one Ethernet cable has to be connected to the modem. The computer connects wirelessly. Check to make sure your computer has a wireless card.
Oct 31, 2010 | Arris SURFboard® SB5101 Cable Modem
Bought this netgear rangemax wireless router and don't know where the wires and stuf*** hook up to.the yellow ethernet wire on the back of router where does that go on the back of my computer terminal of...
Take the ethernet cable which is going from your Warner cable modem to your computer, and run it from your cable modem to the input connection of your router. Then take a second ethernet cable and run it from the router (ports 1, 2,3 or 4) to your computer. Log into your router's setup page (see your instruction manual), and set up all the passwords and wireless settings. Please read the instructions for specifics of your particular router.
Jun 26, 2010 | NetGear RangeMax WPN824 Wireless Router
I bought a D-Link DIR-615 wireless router. I have a desktop computer plugged into the wireless router with an Ethernet card, 1 wireless laptop, that can see and use the wireless printer.(no problem there) ...
No problem, you simply need to do is go into the P{C and install a NETWORKED printer, also go to the Printer Properties, and ensure you select "Sharing" . Link for step by step below.
http://support.microsoft.com/kb/814005
Mar 10, 2010 | Computers & Internet
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Ethernet won't reconise modem for xbox live
Once you have everything hooked up:
Ethernet cord going from modem into wireless router in port labelend internet or wan, and an ethernet cord going from the router to the xbox you should try these steps:
Unplug the power cord on the modem and plug it back in- once all the lights come back on
Unplug power cord on router and plug it back in-
Hope this helps.
Apr 07, 2009 | Linksys Wireless-G WRT54GS Router...
Yellow Ethernet Cable
Ethernet cables can come in all colours (very unhelpfully). The cable you need has RJ45 connectors at either end, which are clear.
It goes by many names: you are looking for Cat5e or Cat6, ‘straight’ or ‘patch’ cable, which is used to connect, say, a computer to a router. Do NOT use ‘crossover’ cable.
Netgear has some info here (a little out of date but OK:)
http://kbserver.netgear.com/kb_web_files/n101561.asp
Jan 07, 2009 | NetGear WGR614 Wireless Router
Belkin 4-Port Router
this is because that router is a wired router not a wireless router
Oct 07, 2008 | Belkin (F5D5231V4-SN-PD) Router...
Wireless router needing ethernet connection?
Hi ABVT66 - Didn't your router come with two short cables? It should have. One is the cable that hooks up the modem to your router and the other is the cat5 (ethernet) cable that connects your router to your pc. Let me know if you have these cables. Also, if you check your device manager on your pc, click on the + next to network adapters and it will tell you your network adapter. DON'T RATE THIS 'TIL WE'RE DONE. Thanks.
Jeff
May 22, 2008 | Computers & Internet
I don't no how to hook up my Adsl Gateway
See if maybe this will help. You didn't say what type of router(wired or wireless). Yhis should give you some idea. Hope this helps. Thanks
LinkSys Router Setup Physical Setup of a LinkSys Router Each model of LinkSys router will differ slightly, but the general design is similar across all models. Therefore, the setup is similar across all models.
  1. Attach the antennas to the router (if your LinkSys router support wireless)d
  2. Plug the Ethernet cable from your broadband Internet provider into the port labeled "Internet"
  3. Plug another Ethernet cable into one of the available ports
  4. Plug the other end of that same cable into an Ethernet port on your PC
LinkSys Router Configuration LinkSys routers now ship with a Setup Wizard which is intended to simplfy basic configuration tasks.
We do not recommend the LinkSys Setup Wizard for two reasons:
  1. The Setup Wizard is not significantly easier that the regular configuration menus
  2. If you use the Setup Wizard, you will end up learning two interfaces for your LikSys router instead of just one
Instead, we recommend simply starting your web browser and jumping into the configuration.
Once your web browser is open, go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password.
Logging in to a LinkSys Router
The username is either blank or "admin" and the default password is "admin".
Once you are past the login screen, you are able to access (and change) a plethora of configuration options for your router.
Don't be worried by the enormous number and variety of options, your LinkSys router ships with default settings that enable it to work right out of the box in most environments.
From here the configuration options that you choose are largely up to your own personal preference.
If this is a wireless router, we recommend that you consider setting an SSID to identify the router as your own and configuring WEP to encrypt your wireless traffic.
Feb 18, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
