Question about HP Photosmart C4280 Aio Printer
HP C4280 Problem
When I try to connect the printer to my laptop, my laptop just is not reading the new device. It is the only usb port available and I don't know where I problem is. Can you please help me?
  • gsuteu Jun 21, 2008
    HP C4280 Photosmart All-in-one. After a day or two of connecting printer, it won't print and I get a message that there is an error. I usually delete printer and reinsatall by putting in sftware disk to add a printer, which is agravating. How do I get rid of the error, or solve the problem??
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Are these still current issues?
Posted on Aug 20, 2008
Is there any way to install my hp photosmart C4280 without the disk? I recently moved and can't find it. The conncetion point on the actual printer is damaged as well, so I can't simply connect it...
hello Jessica
kindly send me 4 thumbs up
you simply go to this site , select the OS you use and download the drivers for the printer, save on your desktop. make sure the printer is disconnected from your computer . install the drivers after they are downloaded and follow instructions-- very qick and easy
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=ca&dlc=en&lang=en&lc=en&product=3192753&
Aug 15, 2011 | HP PhotoSmart C4280 Laser Printer
My HP Photosmart C4280 all in one printer will not print...can you help?
Do/did you get any error messages?
Check that the printer is online and check the printer queue (Devices and Printers in Win7). Try a new USB cable and plugging the printer into a different port. If you have a print server or USB hub, try connecting directly to the computer.
Reset the printer by unplugging it and the USB cable. (If files are built up in the queue and the printer is online, try deleting them. If they don't delete, you need to stop and restart the printer spooler. In any version of Windows from a command prompt window, type "net stop spooler" without the quotes and hit <enter>. On the next line type "net start spooler" again without the quotes and <enter>. Restart the computer.)
Other issues are possible if there are any error messages that you don't mention.
I hope this helps.
Apr 12, 2010 | HP PhotoSmart C4280 Laser Printer
Can't scan--says usb not connected
Check your cable and ports. If you are running a laptop, make sure it is connected to AC. Plug in a known working device. If using a hub, directly connect the printer to the computer. Try a new USB cable. Check if your USB ports have been disabled for security or power-savings (in the Device manager or advanced power savings areas).
I hope these ideas help.
(sometimes a flaky USB port will see the device if you just unplug it and then plug it back in to the port. However, this will need to be repeated regularly.)
Jan 05, 2010 | HP Photosmart C4280 Aio Printer
Trying to scan a docement and the pc is sayiny no usb coneected and it is connected , And I have just updated from the net.
1.Check from My Computer > Device Manager Check USB Controller ensure Usb Printing Support was installed
2.Control panel add new hardware find driver and install driver again
3. Check USB port on your pc may be damaged
Oct 09, 2009 | HP Photosmart C4280 Aio Printer
HP C4280 does not scan
Hello !
Your print driver may be corrupted. So, give this a try:
Delete your AIO icon from Printers and Faxes
Download the latest driver for your operating system from here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=3192753&
Disconnect your USB printer cable
Restart your computer
Reconnect your USB printer cable
Your computer should see your AIO and install the new driver.
If your computer does not see your AIO, your USB printer cable is faulty or try another USB port on your computer.
Hope this helps.
Sep 16, 2009 | HP Photosmart C4280 Aio Printer
HP PHOTOSMART C4280 ALL IN ONE WHEN USING IMAC 10.5.7, PRINTER SHOWS MESSAGE USB NOT CONNECTED
You need to try isolating the problem first.
1. Try connecting the USB cable into different USB port of your Mac Leopard.
2. Make sure that your computer could detect other USB devices.
3. Try connecting the printer into different computer to see if the printer would be detected or not.
4. Use different USB cable.
If you get the same problem, you need to contact the printer manufacturer. I believe that it is more on physical connection.
Have a great day!
Jun 22, 2009 | HP Office Equipment & Supplies
Connecting USB during install freezes computer
There are many possible reasons why your computer will shut down when your USB is used but most probably your PC power supply might not have enough power, try unplug other devices such as printers, scanners, other input/output devices except the mouse & keyboard.
Apr 23, 2008 | HP Photosmart C4280 Aio Printer
HP Photosmart C4280 Aio Printer Logo
Ben Johnson
