Question about Kaito KA1103 SW/FM/AM Radio
I can't get it to turn on.
The time is showing. It is plugged in. there are rechargable batteries in it.
I can't get it to do anything. I have had it for a year , it has always worked fine. I just pushed on, and it came on for 1 second. I have pushed reset, it did not help.
  • 3 Answers
First, make sure the batteries are good and capable of being recharged. Before setting the time, depress the 'Reset' then set the time. If set does not come on when the On-Off button is pushed or comes on and immediately turns off - depress the 'Reset' button a couple of times and then reset the clock and try the On-Off button again.
Posted on May 21, 2009
Remington f5151 charges but not working
unplug and replug several times. there is a video on you tube showing how to get rechargeable batteries to charge and it explains the whole thing, but rapidly plugging and replugging can fix the problem with some rechargeable batteries. It is worth a try.
Mar 11, 2013 | Remington R5 Flex&pivot Shaver Washable...
Camera only works when charger is plugged into it, the battery is showing 3.4 volts of charge, is the camera at fault and can it be fixed cheaply?
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 24, 2012 | Pentax Optio Cameras
My Kodak Easyshare M575 digital camera will not turn on. It turns on okay without the battery while plugged to an electrical outlet. I've tried charging the battery and that doesn't work. The...
If unused for any length of time, rechargeable batteries lose their ability to retain a charge. Try it with a brand new, fully-charged battery. FWIW, I recharge all my camera and flashgun batteries monthly.
Nov 07, 2017 | Kodak EasyShare M575 Digital Camera
My zune 4g red will turn on and work when plugged into the charger, but as soon as I unplug it from the charger it goes off and I cannot do anything with it. I haven't tried to restore it, not sure...
Ifthe rechargeable battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 29, 2011 | Audio Players & Recorders
Time/Date stamp doesn't show up...
this camcorder has a built in rechargeable battery for the memory of the date and time, if you do not use it for more than three months, it will discharge all the way; to recharge, you need to plug camera with ac power for 24 hours and the camera turned off. this should charge the internal battery complete.
Oct 08, 2009 | Sony Handycam DCR-TRV250E Digital...
Help!
Seems that the battery is low on power, when the controller is connected to the usb port of the ps3, all leds should start flashing, this show that the battery of the controller is recharging, when done the leds go off.
Note that before the leds start flashing that it can thake up an minute before it starts doing that.
Keep your ps3 on to recharge the controller.
Succes.
Sep 10, 2009 | Sony Playstation 3 (PS3) Console
Camera won't turn on.
Make sure the battery contacts are clean. The rechargable batteries looses their charge even when they are not in use. It is important to fully charge the first time the rechargable batteries.
Dec 14, 2008 | HP Photosmart R707 Digital Camera
PROBLEM WITH PENTAX OPTIO E10
Sounds like battery life is gone. If there rechargeable batteries they might not be holding a charge anymore.
If your camera has a power cord that plug into your camera to charge the battery does it do the same thing?
If it doesn't have a power cord, what happens when you plug the camera into your computer?
Jun 19, 2008 | Pentax Optio E10 Digital Camera
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Visor will Not Turn On
I have a Visor Platinum that has started doing the same.  In my case, two things have helped in the past.  (1) Mine has a built-in lithium battery pack.  The first time the problem happened -- the battery was dead -- I cleaned its contacts and where it mates into the PDA with some rubbing alcohol and a cotton swab and recharged.  (2) Second time it crashed, the problem was with one of the programs that I had installed (some freeware).  The program would cause the PDA to hang during and alarm and make it stay ON till the battery ran down too far.  Solution was to not install the add ons.  To wake the PDA the second time, I placed it on the charger for a minute, took it off and immediately tried the different resets.  Tried the entire process 10-15 times and finally managed to wake up the PDA.  Once awake, let it finish charging before you do anything.  It might prompt you to set the date/time etc, but just wait till it is done charging otherwise it will go back into its coma.
Jul 07, 2007 | Handspring Visor Pro Handheld
Open Questions:
Kaito KA1103 SW/FM/AM Radio Logo
263 people viewed this question
Top Kaito Audio Players & Recorders Experts
alberto55
Level 1 Expert
xxxxxx xxx
Are you a Kaito Audio Player and Recorder Expert? Answer questions, earn points and help others
