Question about Fisher Paykel EcoSmart GWL15
Hot and cold water flow in very slow
Dear Sir,
My wash machine is 10 years old. Now it has problem of filling of water.
Before filling water is only take about 3 minutes. Now it takes about half hour. some one said maybe it is water valve problem. If it is where could I buy the valves ?
  • jyunzhoug May 31, 2008
    Dear Premm,
    I cleaned the screen and tried the machine. It still works the same. I tried to take off the inlet valves with solenoids,
    but failed as they tightely fixed in the coner of the machine.
    ( I unscrewed 3 screws) I don't know how to do next step.
    Please help me.
    Thank you for your idea !
    Jyunzhoug
    President:
  • 1,294 Answers
Close your faucet valve & unscrew your hoses to check screens on hoses & machine. Clean out well. Water shd be in good pressure at faucet. Refit, check for leaks. If this is not the problem change your inlet valve, it is easily done. Will tell u shortly where to get spares.
Posted on May 31, 2008
  • prem mathew May 31, 2008
    You can try with a hack-saw or something......
    For spares u can try these sites: (don't forget machine,model)
    espares.co.uk
    RepairClinic.com
    AppliancePartsPros.com
    You can also google 'washer parts (followed by your city name)'
    Pl rate me.....................the blue boxes...?
Water flow slow
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Dec 29, 2010 | Hoover Washing Machines
Hot water fills very slow(30 MIN OR MORE TO FILL) good water flow from spicket to washer, screens are clear. sewems to be something with the washer its self
Might be a bad inlet valve. To confirm, swap the hot and cold hoses to your washer so that the cold water feeds the hot water connection and the hot water feeds the cold water connection. Turn off both hot and cold water faucets. Set the washer for a warm water wash. Turn on the cold water faucet, and check the flow. Then turn off the cold water faucet, and turn on the hot water faucet and check the flow. If the cold water flow fill slowly, then the problem is with the inlet valve.
It an easy part to obtain from an appliance supply house. To install disconnect the hoses to the back of the machine, and remove the back panel to get access to the valve. Should only take a couple of minutes to remove and install. Hope this helps you.
Oct 26, 2010 | Kenmore 24032\24036 Top Load Washer
The flow of the cold water seems to be restricted. The hot water pores into the tub. The cold trickles in. After disconnecting the cold hose, hot water back feeds out of the cold input side of the machine....
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
Aug 16, 2010 | Washing Machines
Washer fills only with hot water
Disconnect cold water hose from machine. Inspect the filter screen on the cold water connection. DO NOT REMOVE SCREEN. If full of debris, use a spray bottle with a hard spray to remove debris. If unable to remove or cold is still slow, replace valve.
Regards,
reg501
Jun 28, 2008 | Washing Machines
Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
Feb 27, 2008 | Washing Machines
Fisher Paykel EcoSmart GWL15 Logo
73 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
