Question about Mongoose 20-Inch Gravity Games BMX Freestyle Bike
Rear brakes need adjusted how do i do this - Mongoose 20-Inch Gravity Games BMX Freestyle Bike
    Genius:
  • 1,788 Answers
Take it to a bike shop, you are dealing with a trick bike. You do not want to have the brakes fail from a bad adjustment, unless you have the right tools and know how, because you are having to deal with the spacing on the detangler and it takes skill to do it right, do not do it yourself. Someone can get hurt in a diy.
Posted on Oct 10, 2010
Adjust parking cable 99 dodge dakota -drum brakes
Unless you have replaced the cable, it should never need to be adjusted. If you can reach under the vehicle, and when wiggling the parking brake cable, if it is taut (not sagging), then it is probably adjusted properly. What usually causes the parking brake cable to appear mis-adjusted (the parking brake won't hold the vehicle), is that the self-adjusters in the rear drum brakes are not working properly. This is bad because it means that you are not getting proper braking from the rear brakes as well as having the parking brake issue. This can cause premature wear to the front disc brake pads/rotors and affect braking power and control under certain stopping conditions. Front disc brakes work so well that many people never realize that their rear brakes aren't doing their fair share. The purpose of the self-adjusters in the drum brakes is to keep the rear brake shoes at a consistent distance from the drum's inner surface as the shoe lining wears down. If the adjuster works correctly, the parking brake will always stay in adjustment. You CAN adjust the parking brake cable, but if the problem is actually with the self-adjuster, you are masking the real problem, and later on when you need to replace the rear brake shoes, you will find it impossible to put the drum back on over the shoes as the parking brake will have the shoes pushed out too far. Have a mechanic check out the self-adjuster mechanism. It is always a good idea whenever you replace the rear brake shoes to replace all the rear brake hardware as well. You don't replace rear brakes nearly as often as the front ones, and the cost of the hardware is minimal in relation to the satisfaction of knowing that non-corroded parts will work better and provide longer service than the older, gummed-up and rusted hardware that is currently installed.
Sep 11, 2014 | Dodge Dakota Cars & Trucks
How to adjust rear brakes on dodge dakota sport,2000?
if you have never replaced the factory rubber brake hoses , now is a good time to replace them
you probably have a small hydraulic fluid leak in 1 of the rear brake cylinders
May 04, 2014 | 2000 Dodge Dakota - All Dakota models -...
Can i adjust e brake @ handle, or do i need to pull rotors and off to do it?
They should be self adjusting. Why are you trying to adjust them...too tight ? Too loose ?...you may just need new pads as the e-brake uses diff brakes than the hydraulic system brakes. Hope this helps !
Mar 09, 2011 | 2006 Chevrolet Trailblazer
98 Ford Escort, Emergency brake doesn't hold car. Rear brakes okay, adjusted cable to 3 clicks. What am I looking for?
If you have rear rotors that look like a rotor mounted on top of a drum brake, you will have an emergency brake inside the drum portion. The rear brake rotors are not flat like the front rotors for this style.
The E brakes have brake shoes and they have "Star" wheels for adjustment just like the regular drum brake. You really need to take off the rear rotors to inspect the inner drum portion. If you do adjust the E brakes without looking at the drum part, chances are the drum is pitted and rusty and you will be lucky to stop once before the E brake linings are ground off.
The other type of E brake works off the Rotor pads. You will see the brake cable attached to a lever on each wheel. There will be an Equalizing cable connecting both rear wheels with an adjustment point joining the main cable. Although the 3 clicks moves the main cable, to have both rear brakes equally tight you need the Equalizing properly adjusted.
Those are the things you need to look for.
Jun 15, 2010 | 1998 Ford Escort
Adjusting the parking brake on 03 pontiac vibe
If you look under the van on the driver side (usually) you'll see where the two cables from the rear inter-connect with the main cord to the front. Here, you should find an adjustable bolt that you can tighten. If it is not here, it may need to be tightened from there rear tires.
If you have drum brakes in the rear, these are most likely "self-adjusting" brakes, which may interact with the emergency brake. Everytime you back up, and apply the brakes, you are activating the self adjuster (you would have seen this located at the bottom of the brake system between the two brake pads. This is the self adjuster. Try going in reverse at about 5 miles per hour, and hitting the brakes firmly (not slamming on them). Drive forward again, and firmly press the brakes. Go in reverse again, and apply brakes firmly again; (do this about 4 or 5 times to get the rear brakes adjusted). Try the emergency brake again and if still not tighter, purchase or look in your repair manual as to how to adjust the emergency brake.
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
May 29, 2010 | 2003 Pontiac Vibe
Parking Brake doesn't work. I have adjusted the
Check your rear brakes and their adjustment. If parking brake is seperate check them also. The brakes have to work and be adjusted properly then adjust parking brake.
Sep 08, 2009 | 1996 Jeep Grand Cherokee
I need a diagram for the rear drum brake for 2002 Ford Ranger
Copy and paste this into your search window: 2002 ford ranger rear brake diagram
You should see four pictures pop up, select the brake parts diagram or the brake picture.
Sep 03, 2009 | 1993 Ford F150 SuperCab
Need to know how to adjust rear brakes on 1990 gmc pickup
what year is the truck and does is have drum brakes or disk brakes in the rear if it is drum you can go thru the backing plate with a brake adjustment tool and adjust them until you feel drag against the drum when you spin the tire by hand
Apr 22, 2009 | GMC Sierra Cars & Trucks
I need a schematic for the rear brakes on an F150 super cab with 4.6L automatic trans 4wheel drive
Drum, Rear Brake System Standard Rear Brake
Item Part Number Description 1 2069 Brake Shoe Hold-Down Spring Pin 2 — Rear Wheel Cylinder Retaining Bolt (2 Req'd) 3 — Washer (2 Req'd) 4 — Anchor Pin (Part of 2211) 5 — Wheel Cylinder 6 2028 Brake Shoe Anchor Pin Guide Plate 7 2A637 Parking Brake Lever 8 2296 Brake Shoe Retracting Spring (Short) 9 2296 Brake Shoe Retracting Spring (Long) 10 2200 Rear Brake Shoe and Lining (Secondary) 11 — Washer 12 2106 Parking Brake Lever Pin Retainer 13 — Brake Shoe Adjusting Lever Cable Guide 14 2A642 Primary Brake Shoe Parking Brake Lever Link 15 2A601 Parking Brake Link Spring 16 2068 Brake Shoe Hold-Down Spring 17 2A176 Brake Shoe Adjusting Lever 18 2048 Brake Shoe Adjusting Screw Socket 19 2047 Brake Shoe Adjusting Screw Nut 20 2041 Brake Adjusting Screw 21 2049 Brake Shoe Adjusting Screw Spring 22 2200 Rear Brake Shoe and Lining (Primary) 23 2A178 Brake Shoe Adjusting Lever Cable 24 2211 Brake Backing Plate
Heavy Duty Rear Brake
Item Part Number Description 1 — Rear Wheel Cylinder Retaining Bolt 2 00538 Lock Nut 3 2212 Rear Brake Backing Plate 4 2262 Rear Wheel Cylinder 5 2A642 Primary Brake Shoe Parking Brake Lever Link 6 2A601 Parking Brake Link Spring 7 2A637 Parking Brake Lever 8 2106 Parking Brake Lever Pin Retainer 9 — Parking Brake Lever Bolt 10 — Secondary Shoe Assembly 11 2A179 Brake Shoe Adjusting Lever Cable Guide 12 2068 Brake Shoe Hold-Down Spring 13 — Adjusting Lever Pin 14 — Adjusting Lever Return Spring 15 2A176 Brake Shoe Adjusting Lever 16 2047 Brake Shoe Adjusting Screw Nut 17 2049 Brake Shoe Adjusting Screw Spring 18 2041 Brake Adjuster Screw 19 — Primary Shoe Assembly 20 2068 Brake Shoe Hold-Down Spring 21 2200 Rear Brake Shoe and Lining 22 2035 Brake Shoe Retracting Spring 23 2A178 Brake Shoe Adjusting Lever Cable 24 2092 Brake Adjusting Hole Cover 25 2069 Brake Shoe Hold-Down Spring Pin
The rear drum brakes:
  • Have internal shoes that expand against the brake drum (1126).
  • Are a single-anchor type.
  • Are actuated by one rear wheel cylinder (2262).
  • Have two pistons in the rear wheel cylinder (2261). One exerts force against the upper end of the primary shoe; the other exerts force against the upper end of the secondary shoe.
  • Adjust rear brake shoes and linings (2200) automatically.
  • Need manual brake adjustment if the adjusters are not operating properly or after the rear brake shoes and linings have been replaced.
When the brake pedal is applied, hydraulic fluid pressure forces the pistons in the rear wheel cylinder outward, moving the rear brake shoes and linings against the brake drum.
The rear drum brake system includes the parking brake mechanism. Refer to Section 206-05 .
Apr 04, 2009 | 1997 Ford F150 Regular Cab
Mongoose 20-Inch Gravity Games BMX Freestyle Bike  Logo
131 people viewed this question
Top Mongoose Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
Rommel Balcita
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
