Question about Freezers
I understand that the drain hose could be blocked in my freezer. But is there another way to unclog from the hose outside the freezer? Just not sure how to locate the hose from the inside.
  • 316 Answers
Well technically you could blow compressed air from the outside, however, whatever is clogging the drain tubing, which is most likely going to be food debris, would then be blown into the freezer. The drain begins underneath the evaporator coil in the freezer. YOu will have to remove any and all ice SAFELY before you can blow compressed air into the drain to remove the obstruction.
Posted on Oct 12, 2010
DRAINAGE IS CLOGGED
There is no part number for the drain. find a piece of copper tube that fits inside the hose and ease it up inside the broken drain hole but only a short way. Silicon seal around underneath it
Apr 19, 2012 | Kenmore Freezers
Water is dripping in side the freezer, and freezing at the bottom of the freezer, where is the hose , so i can check it for blocks in hose???
You have a plugged drain hose. Defrost unit then check drain hole to see if clear. These have a real problem with that. This company is out of buisness now.
Aug 28, 2010 | Woods 201 cu. ft. Upright Freezer V2003RW3
We have a GE 20.3 cu. ft. upright frost free freezer that keeps forming a layer of ice on the bottom, which we assume is happening when it is defrosting. How do we unclog the drain?
I let the ice box thaw out and use a shop vac to open the drain hole. You can find the end of the drain hose above the compressor drain pan.
May 28, 2010 | Freezers
Not cooling, but fan inside running
On a top-freezer when the drain stops up water will back up turning to ice and eventually filling the air ducks with ice blocking airflow to the fresh food section causing it not to cool. You will also see a water leak inside the fresh food section. To fix this, remove the evaporator cover, (back or bottom of freezer) and then remove all the ice. Once all the ice is removed, you need to unclog the drain. I do this by forcing hot water down the drain with a turkey baser but you can use any squirt bottle, I have even used the water hose. Once the drain is clear, mix water and baking soda and pour it down the drain to prevent this from happening again anytime soon.
Apr 06, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Defrost hose plugs
Remove the back cover to access the top of that drain line. Take some table salt in a tablespoon and dump in the tube. Will drain so fast you won't believe it. Might have a big build up of ice blocking the top so get your hair dryer and defrost that big build up. Flush with small amount of water and monitor the drain pan located under neath the freezer. hope this was helpfull
Nov 26, 2008 | Arctic Air 22 cu. ft. Commercial Freezer...
Belling be810
Hi the problem is with a clogged drain hose that's why all the water. to unclog turn off fridge. pull away from the wall . remove back panel. clean all vents . locate drain tube, by the drain tray. clean out the drain . thanks the appliance doc
Oct 06, 2008 | Belling Freezers
Water leaking from underneath the unit
hi thanks for the question is there water inside the fridge or freezer if not then the leak is coming from the drain tray at the back make sure the drain hose is located in the tray not outside the drain tray thanks the appliance doc
Sep 27, 2008 | Freezers
Upright with door lock 13.7 cu. ft.
hi tanks for the question is there water inside on the floor of the freezer.if not check the drain tube under the freezer at the back could have a clogged drain hose thanks the appliance doc
Aug 09, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Upright freezer
the water is coming from the freezer when is defrosts. the drain line is in the back wall of the freezer and may be clogged up with ice. clean out the freezer and pour some hot water in the very back of the freezer, this will hopefully unclog the drain. if not, then you have to take the back wall out of the freezer to get directly to the drain line. there should just be a couple screws holding it; it is just an aluminum or plastic panel.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 14, 2008 | Freezers
Kelvinator fridge
The freezer defrosts every day. the puddle is from that. It is supposed to go into a pan at the bottom and evaporate. You need to look at the pan and determine if it has a hole or the drain hose is leaking somewhere.
Feb 09, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Freezers Logo
79 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
